[done] Open source tiny house as a community project?
- thomas-neemann
- thomas-neemann
Re: Open source tiny house as a community project?
the roof can be moved up and down in one piece with the linear motors. when the roof is up, folding supports can be folded up and the roof is then supported by a small downward movement of the linear motors
sounds very interesting -
I could contribute interior and furniture design work.
I would love to learn more about this ?
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
- thomas-neemann
Yes gladly. what information is required?
here is a suggestion for an exterior design.
@Everyone
if someone has wide suggestions, feel free to post
like a :
project brief / scope
schedule
location
target group
and so forth
schedule
location
target group
and so forth
Designer | Faculty
Designer | Faculty
- thomas-neemann
a well known of mine has a carpentry business. from next year he wants to build tiny houses. it should be a standard basic system, which can be individually designed inside.
it should be pulled by tractor 25 kmh, because then inexpensive chassis with overrun brakes can be used, also used ones.
i think you can save a lot of people time and money with such an open source project. I see companies as a target group who want to build tiny houses, but also private people who want to build their own tiny house.
Construction kits as a cut are also conceivable
- thomas-neemann
if you enlarge the lift from the roof you can even use something like that,
which makes the construction a lot easier.
In Germany, an asuming permit for 3 meter wide loads is possible, so I will use the external dimensions of the floor of 9850 x 3000 mm and a height of the house, roof down, of 2700 mm
- thomas-neemann
making of floor slab, wall and ceiling first floor
https://www.youtube.com/watch?v=L6oEErnEhgI
with ifc file
with ifc file
- thomas-neemann
- thomas-neemann
2nd floor part 1
edit
the models are still in the design phase. They are not yet suitable for building a house with them
edit
