[done] Open source tiny house as a community project?
thomas-neemann
Re: Open source tiny house as a community project?
Post by thomas-neemann »
I propose to only use 12 volt dc in a tiny house. this saves energy and can be installed by anyone and there is no risk of electric shock.
In addition, the electrosmog is minimized.
here is an example with explanations
https://www.youtube.com/watch?v=IHCaY6Ni6pk
phpBB [video]
edit
further suggestions for hot water, heating and additional power supply to the solar cells
thomas-neemann wrote: Mon Aug 23, 2021 10:57 am I propose to only use 12 volt dc in a tiny house. this saves energy
Are you sure? As soon as you will need additional energy from the official 230V (or whatever) you will have to transform it with some energy loss.
Again, are you sure? You have much higher currents in these cases.
thomas-neemann
chrisb wrote: Wed Aug 25, 2021 5:08 am
the proposal and the video refer to a house without 220 volts
source
https://www.hamburg.de/emf-info/143502/faq/
...With direct current and low-frequency alternating current, the magnetic and electrical fields are bound to the generating system or line. They only occur in the immediate vicinity of devices and cables and decrease very quickly with distance......
thomas-neemann wrote: Wed Aug 25, 2021 6:34 am https://www.hamburg.de/emf-info/143502/faq/
According to the link this holds for 230V / 50Hz as well, and they say nothing about voltage or current dependencies. As an extreme example: I have a point welder with very low voltage and very high current. If it is switched on, it will attract magnetic things up to a distance of 5cm or perhaps even 10. No such thing happens in the primary circuit, where of course (at least) the same electrical power is transported.
thomas-neemann
chrisb wrote: Wed Aug 25, 2021 7:31 am
that's right. but if you e.g. compares the electrical smog that arises with a 5 watt led lamp with pure direct current operation compared to a voltage converter, which converts from 12 volts to 220 volts, the radiation of the line and the radiation of the transformer alternating current to direct current for the led lamp, it is a significant difference
thomas-neemann
source
https://baubiologie-magazin.de/photovol ... ektrosmog/
....Alternating fields are considered to be much more damaging to the organism than constant fields.....
....According to the SBM, a magnetic constant field of up to 2 μT is considered a weak anomaly (µT = magnetic flux density in microtesla).....
.....In addition, constant electrical fields are only considered to be hazardous to health above a high voltage. According to the standard of building biology measurement technology (SBM), a constant electrical field of up to 500 V / m is considered a weak anomaly (V / m = electrical field strength in volts per meter)....
this also corresponds to my observations. i have been dealing with the topic for over 15 years
thomas-neemann
here are some suggestions for interior work.
In the toilet you can reuse the handwashed water for flushing
https://forum.freecadweb.org/viewtopic. ... er#p478009
phpBB [video]
thomas-neemann
on the subject of insulation and windows, dew point, etc. i have spoken to many people and read a lot. here the result:
Solid wood walls are offered with a guarantee of up to 50 years against mold growth. Single-pane wooden windows with condensation drainage prevent excessive moisture in the walls.
What is your opinion?
Roy_043
Post by Roy_043 »
You need to explain those, not very energy efficient, choices. Solid wood is not a good insulation material. And single pane windows are quite uncomfortable. Even caravans have double glazing these days.
thomas-neemann
Roy_043 wrote: Thu Aug 26, 2021 7:46 pm
the walls are very thick. the costs for more heating with single-pane glazing are lower than the costs for mold. apart from damage to health caused by mold
