[Arch] Suspicious duplicated code
chennes
Post by chennes »
In ArchPanel.py, the function getWires() begins:
1088        tag = None
1089        outl = None
1090        inl = None
1091        if not hasattr(self,"outline"):
1092            self.execute(obj)
1093        if not hasattr(self,"outline"):
1094            return None
1095        outl = self.outline.copy()
1096        if hasattr(self,"tag"):
1097            tag = self.tag.copy()
1098        if tag:
1099            tag.Placement = obj.Placement.multiply(tag.Placement)
1100
1101        outl = self.outline.copy()
1102        outl.Placement = obj.Placement.multiply(outl.Placement)
Lines 1095 and 1101 are the same (which means that the variable outl is overwritten before first use, the one on line 1095 is never used -- which is how I find myself looking at this code, because static analyzers don't like that). So: is that double copy correct? It's easy enough to silence the warning by changing 1095 to _ = self.outline.copy(), but I don't want to silence the warning if there is in fact something wrong here.
Chris Hennes
Pioneer Library System
carlopav
Re: [Arch] Suspicious duplicated code
Post by carlopav »
Thanks for the finding and for the detailed explanation. I never used much the Arch_Panel tool, but i suspect it wont be a problem to refactor it. Hereafter a proposed refactor of the whole function:
    def getWires(self, obj):
        """getWires(obj): returns a tuple containing 3 shapes
        that define the panel outline, the panel holes, and
        tags (engravings): (outline,holes,tags). Any of these can
        be None if nonexistent"""
        # compute outl and inl
            self.execute(obj)
            return None
        inl = None
        if len(outl.Wires) > 1:
            # separate outline
            d = 0
            ow = None
            for w in outl.Wires:
                if w.BoundBox.DiagonalLength > d:
                    d = w.BoundBox.DiagonalLength
                    ow = w
            if ow:
                inl = Part.Compound([w for w in outl.Wires if w.hashCode() != ow.hashCode()])
                outl = Part.Compound([ow])
        else:
            inl = None
            outl = Part.Compound([outl.Wires[0]])
        # compute tag
        tag = getattr(self, "tag", None)
        if tag:
        return (outl, inl, tag)
Anyway better to have some more feedback!
