[Arch] Suspicious unused variable
chennes
Post by chennes »
In ArchRebar.py, the main execute() function has the following few lines of code:
428            if obj.OffsetStart.Value:
429                baseoffset = DraftVecUtils.scaleTo(axis,obj.OffsetStart.Value)
430            else:
431                baseoffset = None
That variable, baseoffset, is never used, despite being carefully set to None in the else branch. Should it be getting used someplace? If not, I'll rewrite to:
                _ = DraftVecUtils.scaleTo(axis,obj.OffsetStart.Value)
Chris Hennes
Pioneer Library System
carlopav
Re: [Arch] Suspicious unused variable
Post by carlopav »
I'm not commenting on the code, but may I ask (out of curiosity) why in this particular case you would have renamed the variable to "_" and not have deleted the whole code?
chennes
Post by chennes »
I was just assuming that DraftVecUtils.scaleTo(axis,obj.OffsetStart.Value) had some kind of side effect. I figured it was safer to keep it than to risk not performing some necessary operation.
Chris Hennes
carlopav
Post by carlopav »
Hmmm:
https://github.com/FreeCAD/FreeCAD/blob ... ls.py#L242
The function doesnt seem to manipulate the given object, but just to return a new Vector. Am i right?
