Shapestring move behavior
bluebaer
Post by bluebaer »
I encountered an unexpected shapestring behavior in connection with translation functions.
- generate a default shapestring
- move the shape string from 2 random points
- the move operation will be executed twice => shapestring is move the double distance!
- you have to rewind the second operation to get the expected result
see gif attached.
OS: Windows 10 (10.0)
Version: 0.20.25844 (Git)
Hash: 1b20118dfa3fb9f127f0e4fb122701f7fcdaa9fc
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
Can anybody reproduce?
Best regards
Thomas
move shape_string_error105.gif (890.39 KiB) Viewed 4103 times
thomas-neemann
Re: Shapestring move behavior
Post by thomas-neemann »
bluebaer wrote: Wed Sep 29, 2021 9:20 pm
I have observed such effects in other places as well. e.g. downgrade of step files. if you know it is not a problem in my opinion
carlopav
Post by carlopav »
I'll have a look.
thomas-neemann wrote: Thu Sep 30, 2021 7:48 am I have observed such effects in other places as well. e.g. downgrade of step files.
If so please report them. Those are problems indeed
thomas-neemann
carlopav wrote: Thu Sep 30, 2021 9:57 am ... please report them. Those are problems indeed
the next time it happens I'll report about it
Roy_043
Post by Roy_043 »
bluebaer wrote: Wed Sep 29, 2021 9:20 pm Can anybody reproduce?
No, works fine here. Looking at the GIF it seems there is an error BEFORE you add the ShapeString.
OS: Windows 8.1 (6.3)
Qt version: 5.12.9
OCC version: 7.5.2
bluebaer
Post by bluebaer »
Update: I investaged a bit further:
1. Yes there is an error in starting freecad of the weekly build. But thats not the point.
2. I can reproduce the effect on 2 further versions on windows (see below).
The point is that the move operation seems to be executed 2 times.
If you do "undo" there are to enteries that you can rewinded. If you undo one, then everything is the way it should be.
3. With the most recent "20.04.2 LTS" see below I can not reproduce.
For me this seems as the glitch has been around a while. I definitly is connected only to "shapestring" element....
OS: Windows 10 Version 2009
Version: 2021.922.24301 +3888 (Git)
Branch: LinkStage3
Hash: 399863d7e37b354fea6687767605e661beace504
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
and an old V19 version.
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Ubuntu 20.04.2 LTS
OS: Ubuntu 20.04.2 LTS
Version: 0.20.25844 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Roy_043
Post by Roy_043 »
I have tried to closely follow the animation (snaps, stylesheet, initial zoom, calling Fit all from the context menu, selection bounding box) but I still cannot reproduce the problem. Either with V0.20 or V0.19. Have you tried renaming user.cfg?
Version: 0.19.24291 (Git)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
bluebaer
Post by bluebaer »
Nop. renameing "user.cfg" does not solve to issue. Any other ideas? Logs...?
thomas-neemann
carlopav wrote: Thu Sep 30, 2021 9:57 am I'll have a look.
today it happened again. here is the message
21:39:41 GuiCommand: Verschieben
21:39:41 Startpunkt wählen
21:39:43 Endpunkt wählen
21:39:45 562.431 <App> Document.cpp(3815): Recursive calling of recompute for document _158
and here the video
https://www.youtube.com/watch?v=nO1yrK6UU8g
phpBB [video]
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2021.922.24301 +4188 (Git) AppImage
Branch: LinkDaily
Hash: 3de879c7a2ba7111cc769d98636eb6d43189459d
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
thomas-neemann
here is the next one
after draft downgrade with this message
7.86e-07 <App> Document.cpp(3439): Recursive calling of recompute for document Unnamed
95 pillow block.stp.zip
(172.23 KiB) Downloaded 54 times
Version: 0.20.25997 (Git) AppImage
Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3
Qt version: 5.12.9
OCC version: 7.5.2
