Shapestring move behavior
carlopav
Re: Shapestring move behavior
Post by carlopav »
thomas-neemann wrote: Mon Oct 18, 2021 12:48 pm
carlopav wrote: Thu Sep 30, 2021 9:57 am ...
If so please report them. Those are problems indeed
here is the next one
after draft downgrade with this message
7.86e-07 <App> Document.cpp(3439): Recursive calling of recompute for document Unnamed
95 pillow block.stp.zip
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.25997 (Git) AppImage
Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Please open a dedicated topic... Thx
You can tag me if you want, but i have no time to dedicate to bug fixing now, sorry
bluebaer
Post by bluebaer »
Hi
actually I found another way to reproduce with a combination of partdesign and draft:
1. Generate a 10 / 10 / 10 box in Partdesign a 0 / 0 / 0
2. Mark the box
3. Execute "Draft.move([FreeCAD.ActiveDocument.Body, FreeCAD.ActiveDocument.Box], FreeCAD.Vector(-10.0, -10.0, 0.0), copy=False)"
=> you will see the box is relocated -20 /-20 / 0
I checked this with:
OS: Windows 10 Version 2009
Version: 2021.1015.24301 +3962 (Git)
Branch: LinkStage3
Hash: c6cb39697eb439caf7e5bd0208ca3082a7820547
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
carlopav
Post by carlopav »
bluebaer wrote: Fri Oct 22, 2021 8:03 pm 3. Execute "Draft.move([FreeCAD.ActiveDocument.Body, FreeCAD.ActiveDocument.Box], FreeCAD.Vector(-10.0, -10.0, 0.0), copy=False)"
Looks correct to me because you are moving the body and the container box too...
bluebaer
Post by bluebaer »
Hi
please try the following, so you can trace my perception:
1. Generate a new body
2. Generate a 10 / 10 / 10 box in Partdesign a 0 / 0 / 0
3. blank the body
4. Generate a new body
5. Generate a 10 / 10 / 10 box in Partdesign a 0 / 0 / 0
6. Mark the 2. box
7. Execute "Draft.move([FreeCAD.ActiveDocument.Body, FreeCAD.ActiveDocument.Box], FreeCAD.Vector(-10.0, -10.0, 0.0), copy=False)"
8. unblank frist body
The result is follwing file:
test Cube move.FCStd
(12.15 KiB) Downloaded 31 times
My perception is that the part was actually moved 20 / 20 / 0. Can you trace?
I tested this with following version. The funny thing is now that you can not undo the Draft.move.
OS: Windows 10 (10.0)
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
Sinusvag
Post by Sinusvag »
The same (?) problem persists in the newest appimage for linux, info below.
When an object is selected in Draft and moved, the operation is performed twice and the object is moved double the amount. The following error is displayed:
21:56:41 1125.06 <App> Document.cpp(3428): Recursive calling of recompute for document plaanritning_freecad
As is said in another thread, the "solution" is to turn off the recomputes, which in turn makes for a rather messy workflow.
Cheers!
OS: Ubuntu 20.10 (KDE/plasma)
Version: 0.19.24365 (Git) AppImage
Branch: (HEAD detached at d200959)
Hash: d2009595cb09a1d134cdea4cbe0e4e994e93d8db
Qt version: 5.12.9
OCC version: 7.5.3
Sinusvag
Post by Sinusvag »
Edit: Problem still there in latest weekly appimage build. Same error message and double translation of object.
11:59:29 19.8166 <App> Document.cpp(3440): Recursive calling of recompute for document plaanritning_freecad
Version: 0.20.26498 (Git) AppImage
Branch: (HEAD detached at 1895593)
Hash: 18955931c7f0926a4cd9d2719be5a433b49ae56e
Qt version: 5.12.9
OCC version: 7.5.3
Roy_043
Post by Roy_043 »
We really need a reproducible scenario:
Attach a simple file.
And provide step-by-step instructions.
Note that double moves can happen if you select a nested object and its container.
