DraftView positioning and TechDraw
paullee
Re: DraftView positioning and TechDraw
Post by paullee »
(mess up posting, this should be after of below post :oops: )
paullee wrote: Fri Oct 08, 2021 6:14 pm Strangely, while attempt to do something that may not be 'orthodox' - putting a few Layer in Group...
(as there is only 1 Layers object, but many Group objects can be created)
Not knowing if there is any side effects, seems working ... :)
yorik wrote: Ping
draft-and-tech-draw-issue_ r2.FCStd
(23.11 KiB) Downloaded 68 times
Screenshot from 2021-10-09 02-13-37.png (201.18 KiB) Viewed 2541 times
paullee
Post by paullee »
(mess up posting, this should be in front of above post :oops: )
find putting a Group into a DraftView by Gui does not works
Need to click Source in an existing DraftView and select the desirable Group to put in :!:
Screenshot from 2021-10-09 02-05-06.png (200.46 KiB) Viewed 2539 times
Screenshot from 2021-10-09 02-13-04.png (157.99 KiB) Viewed 2539 times
stanluk
Post by stanluk »
Thank You all for posting answers. My problem is now solvable however i'm a but unsatisfied of the solution :)
Let me go back to problem definition. As I mentioned in first post I have N layers, and I want to draw M tech draws. In each tech draw there can be up to two layers on the drawing simultaneously. However the same layers can be repeated in other TechDraw also!.
As I correctly understood the solution, You proposed is to make single DrawView instead of two to workaround placing issue. However I can't make the same object bo be contained in many groups without making deep copy, or is it possible?
I've attached other file to better diagnose the problem.
draft-and-tech-draw-issue-updated.FCStd
(63.68 KiB) Downloaded 56 times
stanluk
Post by stanluk »
Ok, I've just found Link feature, however linking the Layers and putting links in the group also doesn't work (nothing appears in TechDraw)
Roy_043
Post by Roy_043 »
chrisb wrote: Fri Oct 08, 2021 5:07 pm It seems to be my config. It works with a plain vanilla config. Any idea which parameter may cause this?
Edit → Preferences... → Draft → General settings → Use Part Primitives when available
paullee
Post by paullee »
It seems putting Links in a Group, then DraftView point to the Groups works ?
draft-and-tech-draw-issue-updated_ r.FCStd
(67.54 KiB) Downloaded 53 times
Screenshot from 2021-10-09 12-58-48.png (238.68 KiB) Viewed 2277 times
Screenshot from 2021-10-09 13-00-00.png (244.59 KiB) Viewed 2277 times
stanluk
Post by stanluk »
Nice one, however I think You hacked my example a bit. Consider that in real project (the one that I cannot share unfortunately) I have hundreds of wires in each layer. When I make a link to a layer instead of single wire the TechDraw do not show anything.
I've tried additionally to exchange Layers with groups however with same effect. (The exception is throw additionally)
Roy_043 wrote: Fri Oct 08, 2021 11:35 pm Edit → Preferences... → Draft → General settings → Use Part Primitives when available
Thanks, that helped. When it is on, "Insert Draft Workbench Object" fails. If it is off, it works. Is this worth a ticket?
paullee
Post by paullee »
stanluk wrote: Sat Oct 09, 2021 7:24 am Nice one, however I think You hacked my example a bit. Consider that in real project (the one that I cannot share unfortunately) I have hundreds of wires in each layer. When I make a link to a layer instead of single wire the TechDraw do not show anything.
Indeed. Had tried a combination of LinkGroup and Layer under Group / Group under Layer, not good :)
Maybe you can file a Feature Request in Mantis BugTracker.
Hope others have more idea.
draft-and-tech-draw-issue-updated_ r2.FCStd
(71.97 KiB) Downloaded 54 times
Screenshot from 2021-10-09 17-04-56.png (304.08 KiB) Viewed 2161 times
Roy_043
Post by Roy_043 »
chrisb wrote: Sat Oct 09, 2021 8:36 am
AFAIK this is correct behavior. Some Draft commands can create Part objects. The TechDraw_DraftView command is not intended to handle them.
