Reversed closed Draft_BSpline has different shape?
You can reverse a Draft_BSpline with Draft_Edit. If you reverse an open BSpline the shape seems to stay the same. But for a closed BSpline this is not the case: the shape changes considerably. Why is that? And it there a way to avoid that?
- bspline-rev.png (4.32 KiB) Viewed 1132 times
- bspline-rev.FCStd
- (8.66 KiB) Downloaded 18 times
- thomas-neemann
Re: Reversed closed Draft_BSpline has different shape?
I can confirm that, but according to my understanding, the recerse only makes sense with an open contour. what is it used for with a closed spline?
The direction of a closed curve has an impact in certain situations f.e. when using Arch_Structure:
https://forum.freecadweb.org/viewtopic.php?f=23&t=58643
- thomas-neemann
thank you, that's good to know
