[Solved] Help to offset a line in Arch WB
In Arch WB:
1. I drew a Line
2. Selected it
3. Click Offset tool
Why it tells me: Either Part.Wire or Part.Edges should be provided, returning None
The line is: FreeCAD.ActiveDocument.addObject("Part::Line", "Line")
How do I change Part::Line to Part.Wire?
or which tool draws Part.Wire directly?
Regards,
John
In Arch WB:
1. I drew a Line
2. Selected it
Regards,
John
Re: Help to offset a line in Arch WB
You probably need to uncheck: Edit → Preferences... → Draft → General settings → Use Part Primitives when available
But IMO the Draft_Offset command should be able to handle a Part_Line. So that would need to be fixed.
Wow, that's quick
I overwrote that two py files. Got this message:
09:05:29 Loading GUI of Sketcher module... done
09:05:29 ----------------
09:05:29 GuiCommand: Line
09:05:29 Pick first point
09:05:29 Pick next point
09:05:40 ----------------
09:05:40 GuiCommand: Offset
09:05:40 Pick distance
09:05:42 the offset tool is currently unable to offset a non-Draft object directly - Creating a copy
09:05:42 something wrong with firstDir
09:05:42 Traceback (most recent call last):
File "H:\FreeCAD_0.20.26155_Win-LPv12.5.4_vc17.x-x86-64\Mod\Draft\draftutils\todo.py", line 167, in doTasks
Gui.doCommand(string)
File "H:\FreeCAD_0.20.26155_Win-LPv12.5.4_vc17.x-x86-64\Mod\Draft\draftfunctions\offset.py", line 136, in offset
newobj.Shape = DraftGeomUtils.offsetWire(obj.Shape,delta,occ=True)
TypeError: {'sclassname': 'class Base::TypeError', 'sErrMsg': "type must be 'Shape', not NoneType", 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': "type must be 'Shape', not NoneType", 'btranslatable': False, 'breported': False}
09:05:42 ToDo.doTasks, Unexpected error:
<class 'TypeError'>
in ['offst = Draft.offset(FreeCAD.ActiveDocument.Line, FreeCAD.Vector(-10.67492775865126, 18.22273918977719, 30.16078215968867), copy=True, occ=True)', 'FreeCAD.ActiveDocument.recompute()']
OS: Windows 10 Version 2009
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
The problem is caused by occ=True and not related to this PR.
https://wiki.freecadweb.org/Draft_Offset wrote:OCC-style ... only works for planar Draft objects with at least two straight edges.
Where is this occ setting? I can't find it under Draft Preferences.
BTW: I was trying Design456. It has one line 'import occ' and my system reports there is no module named occ. Maybe my FC version has problem with occ not setting right.
I saw this 'occ=True':
>>> Gui.runCommand('Draft_Offset',0)
>>> offst = Draft.offset(FreeCAD.ActiveDocument.Line, FreeCAD.Vector(-7.045367820091163, 10.100797605951575, 17.52369468323241), copy=True, occ=True)
- task-panel-occ-style.png (7.31 KiB) Viewed 1690 times
