Trying to make walls then adjust - Crash!
robinh
Postby robinh » Sat May 03, 2014 8:10 pm
I have used sketcher to make a simple L-shaped wall two orthogonal lines, constrain it with lengths and close sketcher. Then I switch to arch select arch workbench and add a wall. ok so far.
Now I want to change the size of the wall. So I go back to sketcher, select the sketch and click the edit icon. Now I get:
Exception (Sat May 03 15:06:37 2014): Not enough memory available
<type 'exceptions.Exception'>: FreeCAD exception thrown (Not enough memory available)
Stack Trace: Traceback (most recent call last):
Is this a bug?
Also changing wall offset seems to do nothing & wall length is 1mm.
My FreeCAD
OS: Windows
Platform: 32-bit
Version: 0.14.3389
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Windows Version: Microsoft Windows 8 (build 9200), 64-bit
Processor: Intel(R) Core(TM) i7 CPU 970 @ 3.20GHz
Graphics Card: AMD Radeon R9 200 Series
Total RAM: 18.0 GB
jmaustpc
Re: Trying to make walls then adjust - Crash!
Postby jmaustpc » Sun May 04, 2014 12:48 am
its working perfectly here
OS: Ubuntu 14.04 LTS
Platform: 64-bit
Version: 0.14.3536 (Git)
Hash: 9238d8ff43ca81de7c6e2a34e9029bcc2cc32b54
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
yorik
Site Admin
Postby yorik » Sun May 04, 2014 2:55 pm
Works normally for me too...
robinh wrote:Also changing wall offset seems to do nothing & wall length is 1mm.
If you base your wall on an underlying 2D object, then the length property is not used. The offset is used only if your base 2D object is an axis, and alignment is "Right" or "Left".
robinh
Postby robinh » Thu May 08, 2014 10:52 am
Thanks for the explanation. I'll try again later.
