[workaround] Calculating the volume of several walls causes the freecad master to crash
- thomas-neemann
E.g. quantity calculations are necessary for tenders
my freecad crashes in the master
am i making a mistake? if so, how can you do it out-of-the-box in freecad?
https://www.youtube.com/watch?v=qz-qBN4yEdM
ko:
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
ok:
Version: 2021.1015.24301 +4280 (Git) AppImage
Branch: LinkDaily
Hash: 556c87868ea46796242156e9f73eae98259794b7
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
ko:
Qt version: 5.12.9
OCC version: 7.5.3
ok:
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Last edited by thomas-neemann on Fri Jan 07, 2022 12:04 pm, edited 1 time in total.
- thomas-neemann
Re: Calculating the volume of several walls causes the freecad master to crash
workaround:
if you create a fusion, freecad no longer crashes and overlaps are not taken into account. this is also useful for the ifc export and in that case no more work. in my opinion that is exeptable
https://www.youtube.com/watch?v=i2MLJbKWpCo
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Re: [workaround] Calculating the volume of several walls causes the freecad master to crash
can you give a detailed step by step to reproduce the crash?
- thomas-neemann
marioalexis wrote: ↑Fri Jan 07, 2022 3:01 pm can you give a detailed step by step to reproduce the crash?
so that it can be reproduced, i shot a video and uploaded the file
Sorry, but that's not a replacement for a detailed description for several reasons:thomas-neemann wrote: ↑Fri Jan 07, 2022 4:25 pmso that it can be reproduced, i shot a video and uploaded the filemarioalexis wrote: ↑Fri Jan 07, 2022 3:01 pm can you give a detailed step by step to reproduce the crash?
- FreeCAD is a free program while data-octopus youtube is the opposite
- people may not want to support the hunt-for-clicks
- for me your videos are far too fast, it even seems that you speed them additionally; so I stopped watching them.
- Watching a video takes more time than a properly prepared description with images, where you can conentrate on the essentials. This is even more so, with high speed videos which I would have to watch several times, which then isn't really a time saver.
So please, take the time and add detailed descriptions. It is a very economic investment from the community point of view: you have to invest time once, and everyone else saves the time. Such descriptions can of course be accompanied by video.
- thomas-neemann
no problem.
open the file
make windows and doors invisible
click arch survey
select all with edit box selection.
crash
it's still the same with the current version
Version: 0.20.27008 (Git) AppImage
Branch: (HEAD detached at 9162733)
Hash: 91627338a44371fe9a8e815b4900f62558af98a1
Qt version: 5.12.9
OCC version: 7.5.3
Last edited by thomas-neemann on Sun Jan 16, 2022 11:42 am, edited 1 time in total.
Many thanks for the description. Took 10 seconds to read .
I can confirm the crash in master.
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
- thomas-neemann
thanks for the confirmation, also under mac os.
can someone test it under windows?
