translation of the GUI stuck for Arch workbench
david69
Post by david69 »
Like for Draft workbench
here are a list of commands or wording which are stuck for Arch workbench:
&Arch
&Arch/Utilities
&Arch/Structure tools
&Arch/Structure tools/Structure
&Arch/Structure tools/Structural System
&Arch/Structure tools/Multiple Structures
&Arch/Axis tools/Grid (I don"t find this word under Arch.ts)
&Arch/Panel tools
&Arch/Material tools
&Arch/Pipe tools
&Arch/Cut with a line
&Draft
&Draft/Creation
&Draft/Creation/Arc tools (I don"t find this word under Arch.ts, but I guess it is share with Draft workbench)
&Draft/Creation/Bezier tools (I don"t find this word under Arch.ts, but I guess it is share with Draft workbench, should be Bézier)
&Draft/Annotation
&Draft/Modification
&Draft/Modification/Array tools
&Draft/Modification/Array tools/Array
&Draft/Modification/Array tools/Polar array
&Draft/Modification/Array tools/Circular array
&Draft/Utilities
&Draft/Utilities/Added a new name group (this command is inside Draft.ts and not in Arch.ts)
&Draft/Utilities/Move to group (this command is inside Draft.ts and not in Arch.ts)
&Draft/Facebinder, Facebinder is not inside Arch.ts but in the Glossary.
the command "None" on the GUI itself is not translate too. it is for "Autogroup off". This command is shared by Arch and Draft workbenches.
Capture du 2022-01-15 15-14-13.png (14.12 KiB) Viewed 2559 times
chennes
Re: translation of the GUI stuck for Arch workbench
Post by chennes »
Yorik and I discovered a problem with the updatets.py script, it was not recursing correctly: I think it’s going to fix a lot of these issues. Yorik is testing the change now.
Chris Hennes
Pioneer Library System
Roy_043
Post by Roy_043 »
Thanks for the list David. I have checked all items:
Most issues have already been addressed. See:
https://github.com/FreeCAD/FreeCAD/pull/5301/files
https://github.com/FreeCAD/FreeCAD/pull/5370/files
https://github.com/FreeCAD/FreeCAD/pull/5371/files
This does not seem to be a problem. Both the menu text and the tooltip are already translated (I have checked fr and pl).
&Draft/Facebinder
Idem.
This was missed.
This was missed.
I made a mistake with this one. I used "Draft_Array" as the context, but it should be "Draft_OrthoArray".
should be Bézier
OK.
I'll do a PR for the last 4 issues.
david69
Post by david69 »
Thank you Chennes and Roy for your feedback/work.
that one, I was not sure because in French, it is the same word. For sure, the two other commands below are not translate.
&Draft/Facebinder
it's well translate. My remark was more about the place to find the original text, under Glossary file. Is it normal?
Roy_043
Post by Roy_043 »
david69 wrote: Sun Jan 16, 2022 10:14 am For sure, the two other commands below are not translate.
That should be fixed with one of the mentioned PRs.
david69
Post by david69 »
in the top menu, we have Arch and Draft.
the underlined letters are the shortcuts, right?
what happen to the shorcut if in a translation, we don't have the underlined letter in English? For example, in French, Draft would become Épure.
Roy_043
Post by Roy_043 »
The character after & determines which key (combined with Alt) will open the menu.
Ideally using the same character for several menus should be avoided.
For example:
Switch to French
Switch to the Arch WB.
There are now 3 menu that use A as the "menu access key" (not sure if this is the correct term): Affichage, Arch and Aide.
To open the Aide menu you would have to use Alt+A 3 times.
david69
Post by david69 »
what will happen to languages like Chinese, Russian, Polish?
Roy_043
Post by Roy_043 »
I do not understand your question. Each language version is separate in this regard (I think).
For the French translation you might do this:
&Draft -> É&pure
This would mean that Alt+P can be used to open the menu if French is the language.
david69
Post by david69 »
now I get it. the missing word for my understanding is "independant".
