Suggest tools like Column and Beam to also generate analytic model
johnwang
Post by johnwang »
For steel frame, it is handy that tools like Column and Beam could generate analytic model in one go.
The model tree could have two group nodes: 3d model & analytic model. When you add a column, 3d solid goes into 3d model. Single line model goes into analytic model at the same time.
BIM_Column & BIM_beam are inside BimStructure.py. The real function is inside ArchStructure.py.
def makeStructure(baseobj=None,length=None,width=None,height=None,name="Structure"):
    _Structure(obj)
Maybe add something like:
def makeStructureAnalytic(baseobj=None,length=None,name="StructureAnalytic"):
    _StructureAnalytic(obj)
When you call makeStructure, also call makeStructureAnalytic.
Cheers,
John
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
ebrahim raeyat
Re: Suggest tools like Column and Beam to also generate analytic model
Post by ebrahim raeyat »
johnwang wrote: Fri Jan 28, 2022 11:27 am Hi,
Hi. Columns and Beams in BIM WB have Nodes property, that you can use it for creating analytical model.
johnwang
Post by johnwang »
ebrahim raeyat wrote: Fri Jan 28, 2022 6:47 pm Hi. Columns and Beams in BIM WB have Nodes property, that you can use it for creating analytical model.
Yes, that what I can use. I hope BIM_Columns could write out that into an analytical model.
balrobs
Post by balrobs »
johnwang wrote: Fri Jan 28, 2022 11:18 pm Yes, that what I can use. I hope BIM_Columns could write out that into an analytical model.
Hi @johnwang,
Actually using the IFC exporter (with Preferences/Import,Export/IFC export/Export type=structural analysis) it should be possible to write geometrical informations (no section info, no slab thickness, no material) for beams, columns and slabs to IFC. (see also https://forum.freecadweb.org/viewtopic.php?f=39&t=54286)
Is this what you are looking for?
Hope it helps :D
ebrahim raeyat
balrobs wrote: Sat Jan 29, 2022 8:33 am (see also https://forum.freecadweb.org/viewtopic.php?f=39&t=54286)
Thanks balrobs. very nice link. any work continues on it? I am very interested the ability to create analysis model from Arch model. what is the source code for import and export ifc in FreeCAD? I see ifcopenshell, but what is specific code to import/export model from/to FreeCAD?
johnwang
Post by johnwang »
balrobs wrote: Sat Jan 29, 2022 8:33 am Actually using the IFC exporter (with Preferences/Import,Export/IFC export/Export type=structural analysis) it should be possible to write geometrical
The problem for me is that I don't have a fea software which could read IFC.
johnwang
Post by johnwang »
ebrahim raeyat wrote: Sat Jan 29, 2022 12:05 pm but what is specific code to import/export model from/to FreeCAD?
There is ArchIFC.py.
Maybe could modify that file to export case file for a fea program directly, like case file for Mystran.
balrobs
Post by balrobs »
Some times ago I worked on the IFC exporter to enable slab export. Unfortunately I managed to export walls only via a hack, since til now they miss a proper node system.
As a next step I thought to write FreeCAD's material properties to IFC but then I stoped working on it because some things regarding the material definitions in IFC format (architectural model vs. structural model) were not clear to me.
johnwang
Post by johnwang »
Maybe just put the CBAR item under the Column item, same level as the UB item.
johnwang
Post by johnwang »
balrobs wrote: Sat Jan 29, 2022 7:05 pm Some times ago I worked on the IFC exporter
IFC is a hidden layer of analytic model.
Here the Column in Model is linked to the CBAR in Analytic.
