(WORKAROUND) Zoom to fit freeze 3d window?
thomas-neemann
Post by thomas-neemann »
if i switch to draft in the weekly version after restart, click top and point, x=100mm y=100mm, and click enter point and then click zoom to fit, my 3d window freezes.
Can anybody confirm this?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28918 (Git) AppImage
Branch: (HEAD detached at 69a4963)
Hash: 69a4963ebfdbdda0d069347d013f28f2d6ba687a
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Last edited by thomas-neemann on Mon May 23, 2022 8:24 am, edited 1 time in total.
thomas-neemann
Re: Zoom to fit freeze 3d window?
workaround: create a working plane proxy before the point or before zoom to fit
Roy_043
Post by Roy_043 »
The scenario is not 100% clear. I assume that by "Top" you mean a face of the navigation cube, that "Point" refers to the Draft_Point command, and that the point is still selected during the zoom action. If that is correct then I cannot confirm.
OS: Windows 8.1 (6.3)
Hash: e1f2685734
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
thomas-neemann
Roy_043 wrote: Mon May 23, 2022 8:24 am The scenario is not 100% clear. ...
Here you can see the individual steps
https://www.youtube.com/watch?v=OfwQNX8TLrA
phpBB [video]
thomas-neemann
Re: (WORKAROUND) Zoom to fit freeze 3d window?
in 0.19.3 it still worked
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Roy_043
Post by Roy_043 »
There is indeed something wrong.
Roy_043
Post by Roy_043 »
The same problem can be triggered in V0.19: disable the grid, select the point and press Std_ViewFitSelection.
thomas-neemann
Roy_043 wrote: Mon May 23, 2022 9:56 am There is indeed something wrong.
thanks for testing
yorik
Founder
Post by yorik »
I think what is happening here is that by zooming to a single point, the camera is so close to it that it is closer than the bias value (in all opengl apps, there is a "safe distance", or clipping zone, around the camera where objects are not displayed. So basically the camera doesn't see anything anymore... You see that dragging the mouse still registers that the view is rotating (the navicube rotates), so the view is not frozen. Doing a "view all" command might solve, but maybe not if there is only one point in the document.
Not sure what could be done here, it's quite a corner case
thomas-neemann
yorik wrote: Mon May 23, 2022 2:00 pm ...
thank you for the effort. it could be helpful to point out that it works in 0.19.3
