How to make precise 3d? [SOLVED] [Not FC issue]
Is der a way to make precise 3d in FreeCAD ? I hv a lot of errors. For example the image is plan view of colmn & beam, slab is fine but flooring is away from edge by 25.9 micrometers. Is dis snapin issue? Is there a way to increase precise making of objects? My BIM model shows lots of errors when made into CAD drawin.
- Capture.PNG (28.01 KiB) Viewed 621 times
- ragohix769
Re: How to make precise 3d?
Please upload the project, or the portion needed to test it.freecadnewbee wrote: ↑Mon May 30, 2022 1:24 pm Is der a way to make precise 3d in FreeCAD ? I hv a lot of errors. For example the image is plan view of colmn & beam, slab is fine but flooring is away from edge by 25.9 micrometers. Is dis snapin issue? Is there a way to increase precise making of objects? My BIM model shows lots of errors when made into CAD drawin.
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
sorry for a v late reply
I cnt post 3d here because of NDA, we havnt been able to zero in on the source or error, but suspect its frm the tracing on 2d CAD drawings in FC. for now all corrections are done manual, and clashes hv been checked and resolvd. Thnx for ur reply.
