Feature Request #7257 - When using Draft to Mirror a Part can keep the same color
xsuper9988
Post by xsuper9988 »
When I use assembly objects it is often necessary to mirror
But after mirroring, the color of each object will become white
And the color cannot be changed
Can anyone help with this please?
Thank you very much
PS: Reference topic
https://forum.freecadweb.org/viewtopic.php?f=3&t=69860
My Ver.
OS: Windows 10 (10.0)
Version: 0.21.29283 (Git)
Hash: 15e3e86c5a683f3b2e5c7b95d4b26cd719ab367a
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Chinese/Taiwan (zh_TW)
Installed mods:
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * Assembly4 0.11.12
  * Curves 0.4.4
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners 0.3.43
  * lattice2 1.0.0
  * parts_library
  * pcb
  * sheetmetal 0.2.49
DrafMirrorColor.FCStd
(20.86 KiB) Downloaded 17 times
Reason: Added GH ticket number to thread title
yorik
Founder
Re: Request Update Feature "Draft Mirror Keeps the Same Color"
Post by yorik »
The Draft mirror tool uses the Part mirror tool internally, which apparently doesn't map colors.
An easy fix we could do directly in Draft, is, after the object has been mirrored, copy over the colors from the original object to the mirrored object. But I am not sure the faces order is kept by the mirroring operation.. If faces order gets shuffled, face colors won't be correctly mapped.
Could you try something like this, see if we get correct results? That would help us to see if the above method would work. In the python console, enter this:
FreeCAD.ActiveDocument.Body002.ViewObject.DiffuseColor = FreeCAD.ActiveDocument.Body001.ViewObject.DiffuseColor
(Use your actual object names instead of Body002 and Body001, if different)
xsuper9988
yorik wrote: Thu Jun 30, 2022 9:47 am The Draft mirror tool uses the Part mirror tool internally, which apparently doesn't map colors.
Sorry,I don't understand console mode
I have test your command
it seems to fail
But I found that its order is regular
Bady has 18 edges
Bady001 has 3 edges
Bady002 has 3 edges
Edge12 on both sides are mirrored
My original topic has a file attached
you can test it
thanks a lot for you help
Roy_043
Post by Roy_043 »
The Part_Mirror operation works on the Shape of the Std_Part. That is why the mirrored object is a compound of 3 solids and the numbering of its subelements is completely different from the original objects in the St_Part. Since the Std_Part does not have color properties we probably end up with a white result.
xsuper9988
Roy_043 wrote: Thu Jun 30, 2022 11:40 am The Part_Mirror operation works on the Shape of the Std_Part. That is why the mirrored object is a compound of 3 solids and the numbering of its subelements is completely different from the original objects in the St_Part. Since the Std_Part does not have color properties we probably end up with a white result.
I have a question
Array_Pattern is a similar function
But Array_Pattern can keep the same color
Is there no way for Mirror to keep the same color?
Thank you very much for your reply
DrafArrayColor.FCStd
(20.9 KiB) Downloaded 16 times
xsuper9988
Hi ROY
I found that maybe I got the definition of "Mirror" wrong
I shouldn't be "Request Update"
I should be "Request New Function"
The name of the new feature is "Mirror_Pattern"
It is inherited from the "Arrray_Patten" framework
Because I found that there is "Scale" in the parameter of "Arrray_Patten"
What do you think of this idea?
PS: I found that the "Scale" of "Arrray_Patten" will also turn black, so it should not be a problem with the Link object, it should be related to the "Scale" in the library, I will go to modify that topic
xsuper9988
@Roy_043 @yorik
I found that the Draft mirror in the LinkBranch version is colored... XD
Excuse me @realthunder
Can you help reply to this difference?
LinkBranch Ver.
OS: Windows 10 Version 2009
Version: 2022.430.28641 (Git)
Branch: LinkStage3
Hash: a77045488092c24ece25d63c91f362cbd2181d36
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
yorik
Founder
Post by yorik »
Thanks for testing @xsuper9988 I'll have a better look at your file...
The body's DiffuseColor has been fixed recently IIRC. I'll have a better look here. But indeed, a quick workaround solution might be to make individual mirrors of the different subcomponents..
xsuper9988
yorik wrote: Mon Jul 04, 2022 7:07 am The body's DiffuseColor has been fixed recently IIRC. I'll have a better look here. But indeed, a quick workaround solution might be to make individual mirrors of the different subcomponents..
Thank you very much for your contribution and help
xsuper9988
Do I need to create a Feature Request on Github for "Draft Mirror Keeps the Same Color"?
