[Arch] starting point for modeling the first floorplan
Re: [Arch] starting point for modeling the first floorplan
I now played a bit more with the Arch/BIM WB, but I have a few questions:
1. Should I use the BIM or Arch WB?
2. How can I place doors/windows very precisly at a specific relative position to room edges and also directly on the wall instead of before the wall?
3. How do I structure walls buildings, garden, inventory, ... in the tree on the left?
- thomas-neemann
I have some questions about starting working with FreeCAD as well, hope you dont mind if i hijack this thread.
1)What is best way to model (performance wise) alot similar elements(Beams,column,bolts .... )
I'm thinking large warehouse ~5000 square meters with 10000+ DocumentObjects?
All objects should be parametric(with option to change profile and change alignment, start and end points)
From what i have read here that performance drops when alot of DocumentObjects get added to Tree view,
so is splitting model up and linking parts together is the best way ? Or is there another workflow ?
2)What is prefered workflow to add furniture to the model to 3d view improve performance(fps)?
3)How to handle assemblies in Architectural/Structural model(Beam with welded plates and other profiles) ?
I know there are similar Assembly workbenches, but they seem ment for other things, and might be to heavy, for simple structure Assemblies
- thomas-neemann
gbParametric wrote: ↑Thu Jul 07, 2022 3:39 pm ...
here are examples
https://www.youtube.com/watch?v=DuAdWlztqEw
https://www.youtube.com/watch?v=Z6IlID00YyQ
So you calculate the delta from a wall edge to (0,0,0) yourself and then enter the number? But isn't there a more parametric approach?thomas-neemann wrote: ↑Thu Jul 07, 2022 3:17 pm
I do it as you can see from min 1:25
https://www.youtube.com/watch?v=HKMfJ-DOZVM
- thomas-neemann
here is a suggestion from min 1:42 until placing the windows it is parametric
https://www.youtube.com/watch?v=Y3yep0aZkew
- ragohix769
Thanks for sharing Thomas.thomas-neemann wrote: ↑Thu Jul 07, 2022 6:02 pm
I don't understand why you prefer to use an array of points essentially to have some snapping, when you have snapping tools available. This is not the first time that you use this technik, I was always curious about it. It's a choice with some practical advantage or it's only your personal taste?
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
ArchWB is the core built-in FreeCAD. Yorik develop the BIM WB as add-on to provide more user friendly tools, like windows manager, for ease of BIM workflow, and as add-on, it could be updated more frequently than the FreeCAD release cycle itself - Search for Yorik's blog on BIM development which provides more details
Search there are several available tutorials / youtube video.
This is to me one area to improve indeed If you are brave enough, you have have a look and try the experimental WB I try to develop, or you are programmer and can develop something ?
[ Comments Request /PR ] Intuitive Automatic Windows/Doors + Equipment Placement
https://github.com/paullee0/FreeCAD_SketchArch
There are many models / workflow example available with different approaches for reference, I am learning from them
Random search
https://forum.freecadweb.org/viewtopic.php?p=520687
https://forum.freecadweb.org/viewtopic.php?f=24&t=21106
https://wiki.osarch.org/index.php?title ... w_Examples
https://wiki.osarch.org/index.php?title ... in_FreeCAD
https://www.google.com/search?q=freecad ... nt=gws-wiz
