[TechDraw DraftView Bug] - Can't select Group Object Creating Draft View
paullee
Post by paullee »
Seems to be a bug :)
Step to produce
  1. Create a draft object, say a Line, then a Group
  2. Make a TechDraw page
  3. Try select the Group Object then Draft View - return Error message (see screencapture 1)
  4. Select the Line, then Draft View, OK
  5. Then, in the Source, change the target to the Group - then OK
Expected Behaviour
- Can select a Group object and create the Draft View
Test_ TechDraw-DraftView_Group-Bug_2022-07-06.FCStd
(22.24 KiB) Downloaded 10 times
Screenshot from 2022-07-06 23-12-13.png (174.9 KiB) Viewed 503 times
Screenshot from 2022-07-06 23-12-47.png (194.32 KiB) Viewed 503 times
Screenshot from 2022-07-06 23-12-55.png (177.48 KiB) Viewed 503 times
Screenshot from 2022-07-06 23-13-09.png (176.72 KiB) Viewed 503 times
OS: Fedora 34 (Workstation Edition) (GNOME/gnome)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Curves 0.4.3
  * DynamicData 2.46.0
  * Assembly4 0.11.12
  * ArchTextures
yorik
Founder
Re: [TechDraw DraftView Bug] - Can't select Group Object Creating Draft View
Post by yorik »
Indeed the TechDraw DraftView command expects a Draft object. That is indeed too restrictive, as the Draft svg output system can work with almost anything. I think we can simply remove this restriction
*EDIT* Done with git commit c38e88c61b
paullee
Post by paullee »
yorik wrote: Thu Jul 07, 2022 8:09 am Indeed the TechDraw DraftView command expects a Draft object. That is indeed too restrictive, as the Draft svg output system can work with almost anything. I think we can simply remove this restriction
Thanks !
Indeed this behaviour is mentioned in the DraftView wiki right at the beginning :D
- "...inserts a view of a selected Part-based or Group object into a drawing page ..."
This is also mentioned in Option below
- " ... The Draft View also supports all Draft objects that are not Part-based, such as dimensions and texts ..."
Maybe just mention it altogether at the beginning of the wiki ... ?
