Extrude Wire along normal is not working
In the attached model, the intention is to create a variable height wall.
I have created three wires => extrude along normal (100 mm for all 3 walls) => convert to wall
All good except Extrude Wire002 along normal is not working (strange extrusion in plan – Image 1 & Image 2)
It will work if the custom direction is used along X: 100mm
Am I missing something or is it possible bug? Can someone confirms please
One more Question: is their any approach to model the variable wall height better than my approach I have used
- Image 1.jpg (295.68 KiB) Viewed 1349 times
- Image 2.jpg (397.8 KiB) Viewed 1349 times
- Variable Height Wall.FCStd
- (18.42 KiB) Downloaded 21 times
Re: Extrude Wire along normal is not working
Oops, it is Part Extrude problem, @kunda any idea who to ping to have a a look please ?
Alternatively, use Arch Panel to directly 'thicken' the Wire Face you make without the need of using Part Extrude
- thomas-neemann
It is not Part workbench alone. If I downgrade+upgrade I get again a wire and it can be extruded along normal. If I convert it to a sketch, it can be extruded as well.
Can it be a problem that the wire has only 3 edges, and not 4?
The problem is caused by this portion of the Part code:
https://github.com/FreeCAD/FreeCAD/blob ... #L197-L203
It is assumed that the shape of a Part_Part2DObject always lies on the XY plane defined by its Placement. For a Draft_Wire that need not be the case.
Test code:
Test code:
import FreeCAD as App
import Draft
doc = App.ActiveDocument
pts = [App.Vector (0.0, 0.0, 0.0),
App.Vector (5.0, 0.0, 3.0),
App.Vector (5.0, 5.0, 0.0)]
wire1 = Draft.make_wire(pts)
wire1.Closed = True
wire1.MakeFace = False
doc.recompute()
extr1 = doc.addObject("Part::Extrusion", "Extrude_wire1")
extr1.Base = wire1
extr1.DirMode = "Normal"
extr1.LengthFwd = 2.0
extr1.Solid = True
doc.recompute()
Roy_043 wrote: ↑Sat Aug 20, 2022 2:42 pm It is assumed that the shape of a Part_Part2DObject always lies on the XY plane defined by its Placement. For a Draft_Wire that need not be the case.
The rest of 2 wires do not lie on XY plane either but have no problem ?
