calculations with sun and shadows
lambda
Post by lambda »
I wrote a few simple functions to calculate whether an objects shadow touches a given point at some times of the day. (Or generally whether some fixed point in space (like the sun) is or isn't visible. You want to listen in on NASA's deep space probes, you can calculate your time windows here.)
Maybe somebody else finds this helpful or even gets inspired to write better tools.
You use it like this:
doc = App.ActiveDocument
axis = north3D(doc.Site)
sun_summer = sun_direction(doc.Site, 6, 21).multiply(doc.Box.Shape.BoundBox.DiagonalLength)
vCone = visibilityCone(FreeCAD.Vector(0,0,0), sun_summer, axis)
Part.show(vCone, "SunSummer")  # For debugging or visualisation only
getShadowTimes(vCone, doc.Box.Shape)
The last line returns a list of tuples. Each tuple has the start/end time in hours when there is shadow. In my example I got
[(4.065269158869852, 4.995921816460562), (19.00407818353943, 19.934730841130147)]
Here is the definition of the functions:
def north3D(site):
        "Direction of the earth axis in the local coordinate System of Arch Site"
        from math import cos, sin, pi
        from FreeCAD import Vector
        lat = site.Latitude * pi / 180
        decl = site.Declination.Value * pi / 180
        return Vector(cos(lat)*sin(-decl), cos(lat)*cos(-decl), sin(lat))
def sun_direction(site, month, day):
        from pysolar.solar import datetime, get_altitude_fast
        dt = datetime.datetime(2000, month, day, 0, tzinfo=datetime.timezone.utc)
        latitude = App.ActiveDocument.Site.Latitude
        alt = get_altitude_fast(latitude, 0, dt) * pi / 180
        decl = App.ActiveDocument.Site.Declination.Value * pi / 180
        return Vector(cos(alt)*sin(-decl), cos(alt)*cos(-decl), sin(alt))
def visibilityCone(pnt, dir, axis, cutBelowHorizon=True):
        "Sweep direction along the path it takes by earth rotation"
        import Part
        dirline = Part.makeLine(pnt, pnt + dir)
        cone = dirline.revolve(pnt, axis, 360)
        if not cutBelowHorizon:
                return cone
        air_len = 4 * dir.Length
        air = Part.makeBox(air_len, air_len, air_len, pnt + air_len/2 * Vector(-1, -1, 0))
        return cone.common(air).Faces[0]
def add_times(ts, start, end):
        if not ts:
                ts.insert(0, (start, end))
                return ts
        for i, (s, e) in enumerate(ts):
                if start <= s:
                        break
                if end <= e:  # Case within
                        return ts
                if start <= e:
                        break
        if end < s:  # Case total left
                ts.insert(i, (start, end))
                return ts
        if start > e:  # Case total right
                ts.insert(i + 1, (start, end))
                return ts
        if start <= s:
                ts[i] = (start, e)
        if end >= e:
                ts[i] = (ts[i][0], end)
        while i < len(ts) - 1 and ts[i+1][0] <= ts[i][1]:
                ts[i] = (ts[i][0], max(ts[i+1][1], ts[i][1]))
                del ts[i+1]
        return ts
def getShadowTimes(vCone, shape):
        from math import pi
        xs = vCone.common(shape)
        times = []
        for f in xs.Faces:
                (umin, umax, vmin, vmax) = f.ParameterRange
                shadow_start = umin * 12 / pi
                shadow_end = umax * 12 / pi
                add_times(times, shadow_start, shadow_end)
        return times
Edit: changed the title to better reflect where this ended up going
paullee
Re: shadows for calculations
Post by paullee »
Sound interesting :)
Not having pysolar, can't try; can you post some screencapture to illustrate how does it works ?
[EDIT] - First thing noted is it needs the Arch Site object, that Latitude and Longitude.
lambda
Post by lambda »
Hm, pysolar is part of most distribution. Would a dependency on ladybug be better? The calculation of the sun's position is involved enough, that I don't want to do that myself. Though for energy planning applications you don't need quite as precise values as pysolar calculates.
There isn't much to show on screen. There are no GUI tools, right now this is just calculations, that only are usable from the python console. But if somebody uses this to build GUI tools, that would be awesome. I myself probably will work on more calculations, but not on tools.
Post by Kunda1 »
Didn't yorik deprecate use of pysolar and used ladybug instead for Arch ?
lambda
Post by lambda »
I have extend the code a bit. There still isn't any visualization, but at least you can interact with it from TreeView / PropertyEditor now. Also I have an example file, where you can test the code on:
Open the file and you can try this example session:
>>> import sunandshadows as sns
>>> # Gui.Selection.clearSelection()
>>> # Gui.Selection.addSelection('PV_Sulz','Roof','Face3',4062.01,3713.72,7404.89)
>>> obj = sns.makeSNSResults('PV')
>>> summer_chimney = obj.Proxy.calculate(obj, 6, 21, [App.ActiveDocument.Structure])
>>> sns.summaryV(summer_chimney.shadows)
array([['0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00'],
       ['0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.24', '0.74', 'None', 'None', '3.17', '3.55'],
       ['0.00', '0.00', '0.00', '0.16', '0.41', '0.73', '1.02', '1.25', '1.61', 'None', 'None', '5.27', 'None'],
       ['0.27', '0.47', '0.60', '0.68', '0.77', '0.89', '0.94', '0.87', '0.77', '0.60', '0.30', '0.00', '0.00'],
       ['0.52', '0.57', '0.60', '0.52', '0.43', '0.31', '0.16', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00'],
       ['0.31', '0.23', '0.13', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00'],
       ['0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00', '0.00']], dtype='<U4')
You can also inspect 'summer_chimney.shadows' for the exact times of shadows. Or you can add the neighboring houses to the list of obstacles and get a combined analyses.
I might work on radiation intensity next. Then I could combine radiation intensity with shadowing and calculate the total received energy over a day or even year for any given point.
sunandshadows.py
(7.19 KiB) Downloaded 23 times
PV-Sulz.FCStd
(70.71 KiB) Downloaded 22 times
ragohix769
Re: calculations with sun and shadows
Post by ragohix769 »
lambda wrote: Fri Aug 26, 2022 2:45 pm
Absolutely INTERESTING! I opened the fcad file, but I don't understand how to use the script. I have to install pysolar? But Yorik not said that it's depecrecated?
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough :-(
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same :-)
lambda
Post by lambda »
Most functions in the module work completely independent from pysolar. But yes: To reproduce the example session above, you would need to have pysolar installed. However, I only use it to get the sun's postion. It will be easy to port to ladybug. I only used pysolar, because it is part of Debian and ladybug isn't.
Is there anything else you need, to try the code?
ragohix769
lambda wrote: Sat Aug 27, 2022 11:46 am
I'll try it
