(SOLVED) Can you set (increase) the calculation accuracy of freecad?
Roy_043
Re: (SOLVED) Can you set (increase) the calculation accuracy of freecad?
Post by Roy_043 »
thomas-neemann wrote: Mon Sep 26, 2022 9:02 pm here is the video
That is a not a very accurate way of creating a tangential line.
thomas-neemann
Post by thomas-neemann »
Roy_043 wrote: Tue Sep 27, 2022 7:15 am ...
that's right. do you know a more precise way?
Roy_043
Post by Roy_043 »
At the moment, No.
Finding the tangent at a point on a curve is possible, we have the tangentAt method for that. But finding the tangent on a curve that passes through a given ('from') point is a different matter. Programming a solution for circles would obviously be doable, but for other curves I would not know of a direct method. An 'indirect' method would be to test multiple solutions and then accept the 1st solution within an acceptable tolerance.
thomas-neemann
Roy_043 wrote: Tue Sep 27, 2022 7:51 am ...
Thanks for the feedback. I suspect that it will soon be possible in the sketcher.
thomas-neemann wrote: Tue Sep 27, 2022 7:22 am that's right. do you know a more precise way?
Didn't you ask this quite recently with another spring?
thomas-neemann
chrisb wrote: Tue Sep 27, 2022 12:02 pm ...
Yes, I started a challenge.
https://forum.freecadweb.org/viewtopic. ... 19#p628719
when trying to create solutions, i came across the question why draft sometimes does not produce an intersection at a tangent. (this thread).
one suggested solution didn't work, which is why i used the spiral here as an example
mfro
Re: Can you set (increase) the calculation accuracy of freecad?
Post by mfro »
Roy_043 wrote: Tue Sep 27, 2022 7:12 am
mfro wrote: Mon Sep 26, 2022 8:54 pm FreeCAD does not even try to calculate it because it thinks as the bounding boxes don't overlap the entities can't intersect.
I am aware of that.
I know you are ;)
Remember the discussion.
But others probably aren't.
Cheers,
Markus
thomas-neemann wrote: Tue Sep 27, 2022 12:13 pm Yes, I started a challenge.
That's not what I meant. I thought of this https://forum.freecadweb.org/viewtopic.php?f=3&t=70290, where you got quite some good answers. So why start it all over again? Did I miss something?
thomas-neemann
chrisb wrote: Wed Sep 28, 2022 8:09 am ...
Yes, sorry, I forgot about that. but this additional information came from roy_043.
in the end it was worth it
