Integration of BlenderBIM Features : FreeCAD Arch/BIM - Native IFC
chennes
Re: Integration of BlenderBIM Feaures : FreeCAD Arch/BIM
Post by chennes »
@Kunda1 can you try to drop in the file from this PR and see if it resolves your issue, or sheds any further light on it? https://github.com/FreeCAD/FreeCAD/pull/7634/files
Chris Hennes
Pioneer Library System
Post by Kunda1 »
chennes wrote: Sun Oct 23, 2022 7:06 pm @Kunda1 can you try to drop in the file from this PR and see if it resolves your issue, or sheds any further light on it? https://github.com/FreeCAD/FreeCAD/pull/7634/files
Sure...if I can figure out where in my filesystem to do so... :lol:
Post by Kunda1 »
I need to rebuild the snap locally to test it. I say merge the change and then I can trigger a snap edge build and test it that way
chennes
Post by chennes »
Kunda1 wrote: Sun Oct 23, 2022 7:28 pm I need to rebuild the snap locally to test it. I say merge the change and then I can trigger a snap edge build and test it that way
OK, then -- I merged the proposed fix, let's see if it at least gives you a more verbose error message :) .
Chris Hennes
martin15135215
Post by martin15135215 »
paullee wrote: Sun Oct 23, 2022 5:29 pm
martin15135215 wrote: Sun Oct 23, 2022 3:24 pm i also did install the addon and did successfully open an ifc model, however there was no pop up dialog to chose a importer.
Thanks for the confirmation :)
Seems you import in about 2 min, can you indicates your PC / CPU configuration please.
Intel(R) Core(TM) i7-9850H CPU with 6 CPU cores
https://www.intel.com/content/www/us/en ... tions.html
Post by Kunda1 »
chennes wrote: Sun Oct 23, 2022 8:25 pm OK, then -- I merged the proposed fix, let's see if it at least gives you a more verbose error message :) .
Progress! I get an error but the Addon Manager doesn't hang and reports success :lol:
(of course it's not in my workbench dropdown when i restart FC)
pip timed out
Noneb'pip 22.3 from /snap/freecad/379/lib/python3.8/site-packages/pip (python 3.8)\n'pip 22.3 from /snap/freecad/379/lib/python3.8/site-packages/pip (python 3.8)
Command '['/snap/freecad/379/bin/python3', '-m', 'pip', 'install', '--disable-pip-version-check', '--target', '/home/beast/snap/freecad/common/AdditionalPythonPackages', 'ifcopenshell']' returned non-zero exit status 1.Command '['/snap/freecad/379/bin/python3', '-m', 'pip', 'install', '--disable-pip-version-check', '--target', '/home/beast/snap/freecad/common/AdditionalPythonPackages', 'ifcopenshell']' returned non-zero exit status 1.
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.21.30724 (Git) Snap 379
Hash: c7b427e69797c6750c561b81995829fc7167a415
Python 3.8.10, Qt 5.15.5, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Installed mods:
  * TabBar
  * ExtremeProDark 2.3.3
  * FreeCAD-BlenderBIM 2022.10.20
Edit: Also I'd like to note that the Addon Manager isn't displaying the markdown of the BlenderBIM workbench. I see the raw text source instead of it being interpreted as Mardown.
chennes
Post by chennes »
OK, so now let's try (on the FreeCAD console):
import subprocess
import addonmanager_utilities as utils
python_exe = utils.get_python_exe()
args = [python_exe, '-m', 'pip', 'install', '--disable-pip-version-check', '--target', '/home/beast/snap/freecad/common/AdditionalPythonPackages', 'ifcopenshell']
subprocess.run(args)
Chris Hennes
Post by Kunda1 »
chennes wrote: Mon Oct 24, 2022 2:17 pm OK, so now let's try (on the FreeCAD console):
>>> import subprocess
CompletedProcess(args=['/snap/freecad/381/bin/python3', '-m', 'pip', 'install', '--disable-pip-version-check', '--target', '/home/beast/snap/freecad/common/AdditionalPythonPackages', 'ifcopenshell'], returncode=1)
Version: 0.21.30733 (Git) Snap 381
Hash: f1c03bc2333a127dd1e29c001a647a068fab5095
Installed mods:
  * TabBar
chennes
Post by chennes »
OK, then let's try tweaking it to get some more output:
import subprocess
proc = subprocess.run(args)
print(proc.stdout.decode())
print(proc.stderr.decode())
Chris Hennes
paullee
Post by paullee »
Latest version requires about 6 min to import the same ifc on my i3.
A number of warning/error is noted in the report view, attached below :)
Now, it is about 50mB saving the model in FCStd format.
BB_import_report.txt
(255.1 KiB) Downloaded 28 times
Screenshot from 2022-10-26 07-51-25.png (260.39 KiB) Viewed 1188 times
