[solved]Draft Non-parametric array
xianyu
Post by xianyu »
I know I may repeat the topic.But, I have searched for several days and still haven't found a solution.
There is very little information about the non parametric array. (For my code, the Parametric array is OK, but this is not OK)
My question is this:
When I use "App:: PropertyLinkList" to link three objects. When I array, I only get the parent object, but not the three child objects.
https://forum.freecadweb.org/viewtopic.php?f=3&t=74100
obj.addProperty('App::PropertyLinkList', 'Links', 'Lens', 'FreeCAD objects to be lenses').Links = [front_Surface, rear_Surface, edge_Surface]
xianyu wrote: Fri Dec 02, 2022 8:19 am array(objectslist, xvector, yvector, zvector, xnum, ynum, znum).
I tried a variety of "objectslist". This seems a bit difficult to solve.
I'm sorry I can't provide ". FCStd" because it doesn't work
edit: I made a similar example, just change the "Draft. array (obj,)" in "def NonParametric_array (self, obj):"
Copy the code to the python console, and select "NonParametric" from the array's Power
import FreeCAD as App
import Part
import Draft
import FreeCAD, FreeCADGui, Part
def create():
    Object creation method
    obj = App.ActiveDocument.addObject('Part::FeaturePython', "name")
    objCylinder = Part.show(Part.makeCylinder(5,10))
    box(obj, objCylinder)
    ViewProviderBox(obj.ViewObject)
    return obj
class box():
    def __init__(self, obj, objCylinder):
        Default constructor
        self.Type = 'box'
        self.objCylinder = objCylinder
        obj.addProperty("App::PropertyEnumeration","Power","Array","Lens Array").Power=["Off",  "NonParametric"]
        obj.addProperty('App::PropertyLength', 'Length', 'Dimensions', 'Box length').Length = 10
        obj.addProperty('App::PropertyLength', 'Width', 'Dimensions', 'Box width').Width = 10
        obj.addProperty('App::PropertyLength', 'Height', 'Dimensions', 'Box height').Height = 10
        obj.addProperty('App::PropertyLinkList', 'Links', 'Lens', 'FreeCAD objects to be lenses').Links = [objCylinder]
        obj.Proxy = self
    def execute(self, obj):
        Called on document recompute
        obj.Shape = Part.makeBox(obj.Length, obj.Width, obj.Height)
    def onChanged(self, obj, prop):
        if prop == "Power":
            if obj.Power == "NonParametric":
                self.NonParametric_array(obj)
    def NonParametric_array(self, obj):
        objlist = [obj, self.objCylinder]
        Draft.array(obj,FreeCAD.Vector(20, 0, 0),
                        FreeCAD.Vector(0, 20, 0),
                        FreeCAD.Vector(0, 0, 0),
                        3,3,1)
class ViewProviderBox(object):
    def __init__(self, vobj):
        Set this object to the proxy object of the actual view provider
        self.Object = vobj.Object
        vobj.Proxy = self
    def attach(self, vobj):
        Setup the scene sub-graph of the view provider, this method is mandatory
        self.onChanged(vobj, '')
    def updateData(self, fp, prop):
        If a property of the handled feature has changed we have the chance to handle this here
        pass
    def getDisplayModes(self,obj):
        Return a list of display modes.
        return []
    def getDefaultDisplayMode(self):
        Return the name of the default display mode. It must be defined in getDisplayModes.
        return "Shaded"
    def setDisplayMode(self,mode):
        Map the display mode defined in attach with those defined in getDisplayModes.
        Since they have the same names nothing needs to be done.
        This method is optional.
        return mode
    def onChanged(self, vp, prop):
        Print the name of the property that has changed
        pass
    def onDelete(self, feature, subelements):
        '''Here we can do something when the feature will be deleted'''
        return True
    def claimChildren(self):
        '''Return a list of objects that will be modified by this feature'''
        return self.Object.Links
    def getIcon(self):
        Return the icon in XMP format which will appear in the tree view. This method is optional and if not defined a default icon is shown.
        return """
            /* XPM */
            static const char * ViewProviderBox_xpm[] = {
            "16 16 6 1",
            "    c None",
            ".   c #141010",
            "+   c #615BD2",
            "@   c #C39D55",
            "#   c #000000",
            "$   c #57C355",
    def __getstate__(self):
        Called during document saving.
        return None
    def __setstate__(self,state):
        Called during document restore.
        return None
create()
Freecad novice, A Python enthusiast
Re: Draft Non-parametric array
This looks rather like a Python topic. Should I move it?
xianyu
Post by xianyu »
chrisb wrote: Tue Dec 06, 2022 7:11 am This looks rather like a Python topic. Should I move it?
No problem, this is really a script problem.Thank
Moved.
Roy_043
Post by Roy_043 »
In NonParametric_array you create an objlist that you then do not use.
IMO it does not make sense to create a non-parametric array in this context.
xianyu
Post by xianyu »
Roy_043 wrote: Tue Dec 06, 2022 9:14 am In NonParametric_array you create an objlist that you then do not use.
Yes, that list is only for my testing.
For me, after the array, each Lens can be modified independently. Only non parameter arrays can achieve this function (parameter arrays are all modified uniformly).
Or there are other ways to copy the parent object and child object?
xianyu
Post by xianyu »
I think I should have found the key to the problem
https://forum.freecadweb.org/viewtopic. ... 29#p426329
You may also consider use 'with_dependencies' as the default behavior. When App::Link is found in the dependencies, copyObject() with_dependency will not include the linked object, but it will duplicate the link itself. In case you do want to duplicate everything including the linked object, you can manually call App.getDependentObjects(obj) to obtain the full dependency list, and pass the returned list of objects to copyObject().
Is this the solution?
Roy_043
Re: [solved]Draft Non-parametric array
Post by Roy_043 »
I do not know what you want to achieve. An array (in CAD) means a repetition of the same object. If you want individual elements you should not use an array.
