9" two plate centrifugal clutch
Re: 9" two plate centrifugal clutch
Postby chrisb » Sat Apr 13, 2019 6:54 pm
japie wrote:
Sat Apr 13, 2019 10:23 am
ping
I have merged the topics, so we have one nice engine building topic. You should edit the first post and change the subject to something generic describing the machine
Re: PSA DW10 rods
Postby chrisb » Sat Apr 13, 2019 7:03 pm
NormandC wrote:
Sat Apr 13, 2019 5:17 pm
Edit: question unclear after the merging of multiple topics
Sorry, Normand. I still think it is better like this.
Postby NormandC » Sat Apr 13, 2019 7:11 pm
No problem with me, just wanted to edit my reply to avoid confusion.
japie
Re: PSA DW10 rods
Postby japie » Sun Apr 14, 2019 10:33 am
Did you manufacture them the rods yourself, or is this a reproduction?
I notice that the FCStd model is in one part, while the real-life rods are in two parts. I suppose that the lost thickness due to the cutting process does not matter? (I know nothing about engines)
The first four where made ourselfes, later version where CNC produced by a friend (I am an aluminium welder so we "exchange" skills ;-)
This drawing isn't finished due to production process steps, the 2 parts are screwed together at 60Nm after that the hole is milled else due to internal material tensions it isn't round.
mike_262
Postby mike_262 » Sun Apr 14, 2019 11:04 pm
I love the intake plenum after the intercooler. How thick is the aluminum you used there?
Mike
japie
Postby japie » Mon Apr 15, 2019 4:25 pm
Mike
All my sheet metal works are 2mm don't draw stuff like that, use cardboard for the base shape and copy those to sheet metal, some hammering, bending and the old English wheel and off you go... ;-)
Sami91
Postby Sami91 » Fri Apr 19, 2019 12:34 pm
You have cast the parts or you have lathe??
japie
Postby japie » Mon Apr 22, 2019 5:19 pm
You mean the bellmouth?
On the lathe but not how you think; a piece of tube, brute force, grease, some heat from a torch and a screaming fire alarm :D
abdullah
Postby abdullah » Mon Apr 22, 2019 5:40 pm
Amazing!! :D :D :D
Something I would like to do in my next life...
