controling shear punching of Foundation
amrit3701
Re: controling shear punching of Foundation
Post by amrit3701 »
ebrahim raeyat wrote: Fri Nov 09, 2018 1:42 am Hello. I loaded source codes to github .
excuse me, it's not so clean.
Hi Ebrahim,
Nice work so far. :) One thing I noticed that before using FreeCAD GUI first make sure that it is up. This enables the user to run your code even in FreeCADCmd mode.
if FreeCAD.GuiUp:
	import FreeCADGui
Are you also think to add reinforcement in structural elements?
Thanks,
Amritpal Singh
Github, Like my work, sponsor me!
ebrahim raeyat
Post by ebrahim raeyat »
amrit3701 wrote: Tue Nov 13, 2018 12:15 pm
Hi Ebrahim,
if FreeCAD.GuiUp:
	import FreeCADGui
very thanks for your hint.
amrit3701 wrote: Tue Nov 13, 2018 12:15 pm Are you also think to add reinforcement in structural elements?
Thanks,
yes, but probaply for foundation at first!
ebrahim raeyat
I also give it a try with python3 in command line, for oblique foundation this happen appeard:
I had been want to produce two version of foundation:
1) as above for drawing section that all rebars are present
2) one rebar as representative of all for drawing plan and then for text that must include size and number of rebars, i read those from step 1
but it was heavy and time consuming for adding section cuts to drawing those on techdraw WB.
ebrahim raeyat
I develop punch software and convert it to "punch" object. I want to add punch faces to punch object as a property, but i don't know what kind of property i must to use for it. my faces are type of "Part.Face"
this is output error:
AttributeError: Attribute (Name: facess) error: 'type in list must be 'DocumentObject', not Part.Face'
what means this properties ?!! i searched about those, it seems those are magical !!
App::PropertyLink
App::PropertyLinkChild
App::PropertyLinkGlobal
App::PropertyLinkSub
App::PropertyLinkSubChild
App::PropertyLinkSubGlobal
App::PropertyLinkList
App::PropertyLinkListChild
App::PropertyLinkListGlobal
App::PropertyLinkSubList
App::PropertyLinkSubListChild
App::PropertyLinkSubListGlobal
when the program load, i able to add faces to punch object by click on faces property and select them. thanks
ebrahim raeyat
ebrahim raeyat
i can add those by this code, but this way when i want to use them, i must to obtain them by name from the ActiveDocument. i want to know is there an easier way to do this?
faces = []
for f in intersection_faces:
    face = App.ActiveDocument.addObject("Part::Feature", "face")
    face.Shape = f
    faces.append(face.Name)
punch.faces = faces
when i want to use them:
for face_name in obj.faces:
    f = FreeCAD.ActiveDocument.getObject(face_name)
intersection_faces are type of Part.Face
Last edited by ebrahim raeyat on Sun Jun 23, 2019 12:44 pm, edited 1 time in total.
Post by Kunda1 »
I suggest we keep the technical developing discussions confined to a separate thread as this is the Users Showcase subforum where people show their final products. Is that Ok with you @ebrahim raeyat ?
ebrahim raeyat
Kunda1 wrote: Sun Jun 23, 2019 12:44 pm I suggest we keep the technical developing discussions confined to a separate thread as this is the Users Showcase subforum where people show their final products. Is that Ok with you @ebrahim raeyat ?
yes, I wanted, but i think that it may be more understand to be continued. ok, i continue it from separate forum. thanks
Post by Kunda1 »
ebrahim raeyat wrote: Sun Jun 23, 2019 12:47 pm yes, I wanted, but i think that it may be more understand to be continued. ok, i continue it from separate forum. thanks
So, what do you think about linking to the discussion thread from in here. And every so often you can update this thread with new news? But the main discussion makes sense to happen on a different thread, is that Ok?
ebrahim raeyat
Kunda1 wrote: Sun Jun 23, 2019 5:57 pm
yes. i got it. thanks
