controling shear punching of Foundation
Re: controling shear punching of Foundation
Post by Kunda1 »
Any progress on this WB ?
ebrahim raeyat
Post by ebrahim raeyat »
Kunda1 wrote: Tue Aug 27, 2019 11:52 am Any progress on this WB ?
yes, I complete it now for column but not for shear wall. i create a Punch object with some properties:
also I add export to pdf, png and add a button for update workbench from github:
I want to add some preferences for punch, it works perfectly, but my problem is that icon for punch did not appear:
thanks.
ebrahim raeyat
You can now create a report for all punches in .docx format, if ratio to be more than 1, the color of punch get red:
The model in CSI SAFE software:
punch model and result in FreeCAD:
docx report:
bitacovir
Post by bitacovir »
Have you presented your work in OSArch community?
I think they will be interested on see your tools and workbenches for FreeCAD. Also, you could find some developers there interested on collaboration.
https://community.osarch.org/
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
ebrahim raeyat
bitacovir wrote: Sat Aug 07, 2021 1:52 pm Have you presented your work in OSArch community?
No, thanks for your comment, I will do it.
ebrahim raeyat
ebrahim raeyat
now punch can be calculated directly from CSI ETBAS software with only some clicks. It uses ETABS API for this:
ebrahim raeyat
Creating foundation model now is possible. User Imports informations from CSI ETABS software. user can brings some beams of any story in structure model into OSAFE and then create the foundation model. abilities:
1- brings columns and beams from etabs model and create input *.F2k safe file
2- Create Base Foundation automatically, user can adjust align of each Base Foundation:
ebrahim raeyat
3- create foundation from Base Foundation automatically:
4- create Design strip for strip and mat foundation automatically:
5- bring openings from ETABS model
6- calculate punches for all columns and export to png, pdf and word document and excel format:
ebrahim raeyat
7- creating Base Plate in Steel structures easily, user can align and rotate Base Plate according to location of column and rotation angle of it:
8- finally export the model into *.f2k file that can import into the CSI SAFE software:
