Stretch in 3D
eason
Stretch in 3D
Postby eason » Fri Nov 13, 2015 6:02 am
Hi ,
It just can stretch 3d objects.
It can sel many of objects.
It can't work without snap.
it just can one line to touch objects,when you select objects
How to use it ?
import this_py
this_py.showup()
1.showup
2.pick 2 point to choose the objects what you want to stretch.
3.next, pick 2 point to check the direction and distance.
I know there are many of bugs ..
I will make it to be perfact.
Maybe you can give some opinion.
Thanks!
# -*- coding: utf-8 -*-
#    3D
#    2015/10/05 11:35
#          hahaha~
import FreeCADGui, Part
import FreeCAD
import DraftVecUtils
import DraftTrackers
from PySide.QtCore import QObject
from pivy.coin import *
from pivy import coin
import Draft
try:
    _fromUtf8 = QtCore.QString.fromUtf8
except AttributeError:
    def _fromUtf8(s):
        return s
try:
    _encoding = QtGui.QApplication.UnicodeUTF8
    def _translate(context, text, disambig):
        return QtGui.QApplication.translate(context, text, disambig, _encoding)
        return QtGui.QApplication.translate(context, text, disambig)
class Ui_reobsel(object):
    def __init__(self):
        global LCD_CM,LCD_NM
        LCD_CM = []
        LCD_NM = []
        self.setupUi()
        self.view = FreeCADGui.ActiveDocument.ActiveView
        self.stack = []
        self.point = None
        self.p = None
        self.CLG = None
        self.presc = -1
        self.getobj()
        self.aline()
        self.c = self.view.addEventCallback("SoEvent",self.action)
    def action(self,info):
        global LCD_CM,LCD_NM,SSCM,movt,ONMIDOBJ,MD
        if self.stack: lastpoint = self.stack[-1]
        else: lastpoint = None
        self.point = FreeCADGui.Snapper.snap(info["Position"],lastpoint,info["ShiftDown"],info["ShiftDown"],True)  #snap
        #~ FreeCAD.Console.PrintMessage('\nself.point:'+str(self.point))
        if info["Type"] == "SoKeyboardEvent":
            if info["Key"] == 'ESCAPE':  #  ESC
                self.reob()
        elif info["Type"] == "SoLocation2Event" : #    move
            if len(self.stack) == 1:
                p1 = [self.stack[-1][0],self.stack[-1][1],self.stack[-1][2]]
                p2 = [self.point[0],self.point[1],self.point[2]]
                diagonal = self.point.sub(self.stack[-1])
                p3 = self.stack[-1].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.v))
                p4 = self.stack[-1].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.u))
                p3 = [p3[0],p3[1],p3[2]]
                p4 = [p4[0],p4[1],p4[2]]
                pt = [p1,p3,p2,p4]
                self.coords1.point.setValues(pt)
                self.lines1.coordIndex.setValues(0,5,[0,1,2,3,0])
            if len(self.stack) == 3:
                #~ prf('SSCM',SSCM)
                #~ for i in SSCM:
                    #~ FreeCADGui.ActiveDocument.getObject(i.Name).Visibility = False
                self.coords2.point.setValues([[self.stack[-1][0],self.stack[-1][1],self.stack[-1][2]],[self.point[0],self.point[1],self.point[2]]])
                self.lines2.coordIndex.setValues(0,2,[0,1])
                MD = self.point.sub(self.stack[-1])
                self.p.move(MD)
                self.DCL1.setText(str(round(MD[0],4)))
                self.DCL2.setText(str(round(MD[1],4)))
                self.DCL3.setText(str(round(MD[2],4)))
                self.DCL12.setText(str(round(MD.Length,4)))
                self.DCL12.setFocus()
                self.DCL12.selectAll()
        elif info["Type"] == "SoMouseButtonEvent":#   click
            if info["State"] == 'DOWN' and info["Button"] == "BUTTON1":#DOWN
                self.stack.append(self.point)
                if len(self.stack) == 1: #point1
                    FreeCAD.Console.PrintMessage("\nplease pick 1 point!")
                elif len(self.stack) == 2: #point2
                    self.label9.setText(QtGui.QApplication.translate("Form", "pls pick 2 point ", None,QtGui.QApplication.UnicodeUTF8))
                    self.sg1.removeChild(self.no1) #remove
                    p1 = self.stack[0] # point1
                    p2 = self.stack[1] # point2
                    diagonal = self.stack[1].sub(self.stack[0])
                    p3 = self.stack[0].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.v))
                    p4 = self.stack[0].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.u))
                    FreeCAD.ActiveDocument.openTransaction("3D Stretch-cut") # undo
                    LCD_CM,LCD_NM = cutobj(p1,p3,p2,p4) # cut
                    FreeCAD.ActiveDocument.commitTransaction() # undo
                    self.presc = 0 # esc
                    SSCM = []
                    prf("LCD_CM",LCD_CM)
                    for i in LCD_CM:
                        for ii in i:
                            SSCM.append(ii)
                    prf('SSCM',SSCM)
                    for i in ONMIDOBJ:
                        SSCM.append(i)
                    self.p=DraftTrackers.ghostTracker(SSCM) # trackers  give my obj
                    self.p.on() # trackers   on !
                elif len(self.stack) == 4:
                    self.sg2.removeChild(self.no2) # close  line
                    self.precs = 1
                    movt = self.stack[-1].sub(self.stack[-2]) # move_distance
                    self.CKDS()
    def accept(self): # accept
        self.CKDS()
    def reject(self):  # cancel
        self.reob()
    def reob(self):#close
        global LCD_NM,LCD_CM,FACELIST
        if self.p: self.p.off() # close tracker
        FreeCADGui.Snapper.off()  #close snap
        FreeCAD.Console.PrintMessage("\nStretch  quit...!")
        self.view.removeEventCallback("SoEvent",self.c)  #close Observer
        prf('close self.c')
        FreeCADGui.Control.closeDialog()
        prf(self.presc)
        if self.presc == 0:
            prf('press ESC ... visibility => True')
            try:
                for ii in FACELIST:
                    prf('ii',ii)
                    FreeCADGui.ActiveDocument.getObject(ii[0].Name).Visibility = True
                    prf(ii[0].Name)
                prf("LCD_CM",LCD_CM[0][0].Name)
                prf("LCD_NM",LCD_NM[0][0].Name)
                for i in LCD_CM:
                    for ii in i:
                        FreeCAD.ActiveDocument.removeObject(ii.Name)
                for i in LCD_NM:
                    for ii in i:
                prf("del ok..!")
            except:
                prf("DELERROR")
        close()
    def getobj(self):# sel
        self.sg1 = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
        ma = coin.SoBaseColor()
        ma.rgb = (1,0,0)
        self.coords1 = coin.SoCoordinate3()
        self.lines1 = coin.SoIndexedLineSet()
        self.no1 = coin.SoSeparator()
        self.no1.addChild(self.coords1)
        self.no1.addChild(ma)
        self.no1.addChild(self.lines1)
        self.sg1.addChild(self.no1)
    def aline(self):# a line
        self.sg2 = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
        ma.rgb = (0,0,1)
        self.coords2 = coin.SoCoordinate3()
        self.lines2 = coin.SoIndexedLineSet()
        self.no2 = coin.SoSeparator()
        self.no2.addChild(self.coords2)
        self.no2.addChild(ma)
        self.no2.addChild(self.lines2)
        self.sg2.addChild(self.no2)
    def setupUi(self):
        widget1 = QtGui.QWidget()
        widget1.setWindowTitle(QtGui.QApplication.translate("Form", "3D Stretch", None,QtGui.QApplication.UnicodeUTF8))
        self.layout = QtGui.QGridLayout(widget1)
        self.layout.setSpacing(5)
        self.layout.setColumnMinimumWidth(0,10)
        self.form = [widget1]
        self.getK = QtGui.QPushButton(widget1)
        self.getK.setObjectName(_fromUtf8("getK"))
        self.layout.addWidget(self.getK,1,0)
        self.OK = QtGui.QPushButton(widget1)
        self.OK.setObjectName(_fromUtf8("OK"))
        self.layout.addWidget(self.OK,6,1)
        self.label1 = QtGui.QLabel(widget1)
        self.label1.setObjectName(_fromUtf8("label1"))
        self.layout.addWidget(self.label1,2,0)
        self.DCL1 = QtGui.QLineEdit(widget1)
        self.DCL1.setObjectName(_fromUtf8("DCL1"))
        self.layout.addWidget(self.DCL1,2,1)
        self.label2 = QtGui.QLabel(widget1)
        self.label2.setObjectName(_fromUtf8("label2"))
        self.layout.addWidget(self.label2,3,0)
        self.label = QtGui.QLabel(widget1)
        self.label.setObjectName(_fromUtf8("label"))
        self.layout.addWidget(self.label,5,0)
        self.DCL12 = QtGui.QLineEdit(widget1)
        self.DCL12.setObjectName(_fromUtf8("DCL12"))
        self.layout.addWidget(self.DCL12,5,1)
        self.DCL2 = QtGui.QLineEdit(widget1)
        self.DCL2.setObjectName(_fromUtf8("DCL2"))
        self.layout.addWidget(self.DCL2,3,1)
        self.label3 = QtGui.QLabel(widget1)
        self.label3.setObjectName(_fromUtf8("label3"))
        self.layout.addWidget(self.label3,4,0)
        self.label4 = QtGui.QLabel(widget1)
        self.label4.setObjectName(_fromUtf8("label4"))
        self.layout.addWidget(self.label4,6,0)
        self.label5 = QtGui.QLabel(widget1)
        self.label5.setObjectName(_fromUtf8("label5"))
        self.layout.addWidget(self.label5,8,0)
        self.label9 = QtGui.QLabel(widget1)
        self.label9.setObjectName(_fromUtf8("label9"))
        self.layout.addWidget(self.label9,9,0)
        self.DCL3 = QtGui.QLineEdit(widget1)
        self.DCL3.setObjectName(_fromUtf8("DCL3"))
        self.layout.addWidget(self.DCL3,4,1)
        QtCore.QObject.connect(self.OK, QtCore.SIGNAL("clicked()"), self.CKDS)
        QtCore.QObject.connect(self.getK, QtCore.SIGNAL("clicked()"), self.getKK)
        QtCore.QObject.connect(self.DCL12, QtCore.SIGNAL(_fromUtf8("editingFinished()")), self.norgetpos)
        self.DCL1.setText("0.00")
        self.DCL2.setText("0.00")
        self.DCL3.setText("0.00")
        self.DCL12.setText("0")
        self.DCL1.setEnabled(False)
        self.DCL2.setEnabled(False)
        self.DCL3.setEnabled(False)
        self.label.setText(QtGui.QApplication.translate("Form", "Distance:", None,QtGui.QApplication.UnicodeUTF8))
        self.label1.setText(QtGui.QApplication.translate("Form", "X Distance:", None,QtGui.QApplication.UnicodeUTF8))
        self.label2.setText(QtGui.QApplication.translate("Form", "Y Distance:", None,QtGui.QApplication.UnicodeUTF8))
        self.label3.setText(QtGui.QApplication.translate("Form", "Z Distance:", None,QtGui.QApplication.UnicodeUTF8))
        self.label9.setText(QtGui.QApplication.translate("Form", "pls sel obj", None,QtGui.QApplication.UnicodeUTF8))
        self.OK.setText(QtGui.QApplication.translate("reobsel", "move", None, QtGui.QApplication.UnicodeUTF8))
        self.getK.setText(QtGui.QApplication.translate("reobsel", "restart", None, QtGui.QApplication.UnicodeUTF8))
    def CKDS(self):
        global LCD_CM,LCD_NM,SSCM,ONMIDOBJ
        if LCD_CM == LCD_NM == []: return(errorDialog("please selection obj first!"))
        prf("GOGOGO")
        x=float(self.DCL1.text())
        y=float(self.DCL2.text())
        z=float(self.DCL3.text())
        mov = FreeCAD.Vector(x,y,z)
        FreeCAD.ActiveDocument.openTransaction("3D Stretch-move") # undo
        prf('ONMIDOBJ',ONMIDOBJ)
        for i in ONMIDOBJ:# move!
            Draft.move(i,mov,copy=False)
        ssobj(LCD_CM,LCD_NM,mov) # stretch!
        self.reob()
    def getKK(self): # close and open
            self.reob()
            showup()
    def norgetpos(self):
        global MD
        d=float(self.DCL12.text())
        cd = MD.normalize()*d
        prf('cd',cd)
        self.DCL1.setText(str(round(float(cd[0]),4)))
        self.DCL2.setText(str(round(float(cd[1]),4)))
        self.DCL3.setText(str(round(float(cd[2]),4)))
def isBoxIntersection(s1,s2):
    b1=s1.BoundBox
    b2=s2.BoundBox
    if b1.intersect(b2):
        prf("isBoxIntersection True!!!!!!")
        return(True)
    elif b2.closestPoint(b1.Center).sub(b1.closestPoint(b2.Center)).Length < 0.0005:
        return(True)
    else:
        prf("isBoxIntersection False")
        return(False)
def cutobj(a1=[],a2=[],a3=[],a4=[]): # give 4 vec ... make a ..Shell ... cut obj ... return 2 list...
    global name,lcolor,pcolor,scolor,mygroup,commonFace,FACELIST,DELII,ONMIDOBJ
    DELII = []
    prf('p1 = FreeCAD.Vector('+str(a1[0])+','+str(a1[1])+','+str(a1[2])+')')
    prf('p2 = FreeCAD.Vector('+str(a2[0])+','+str(a2[1])+','+str(a2[2])+')')
    prf('p3 = FreeCAD.Vector('+str(a3[0])+','+str(a3[1])+','+str(a3[2])+')')
    prf('p4 = FreeCAD.Vector('+str(a4[0])+','+str(a4[1])+','+str(a4[2])+')')
    if a1==a2==a3==a4==[]:
        a1=FreeCAD.Vector(10,0,0)
        a2=FreeCAD.Vector(-10,20,0)
        a3=FreeCAD.Vector(10,30,0)
        a4=FreeCAD.Vector(30,0,0)
    shape=Part.Face(Part.makePolygon([a1,a2,a3,a4], True)) # shape
    nor = shape.normalAt(0,0) # nor
    dd = 200 # nor**
    v1po = a1+nor*dd
    v2po = a2+nor*dd
    v3po = a3+nor*dd
    v4po = a4+nor*dd
    v1ne = a1-nor*dd
    v2ne = a2-nor*dd
    v3ne = a3-nor*dd
    v4ne = a4-nor*dd
    shape1=Part.Face(Part.makePolygon([v1po,v2po,v3po,v4po], True))
    shape2=Part.Face(Part.makePolygon([v1ne,v2ne,v3ne,v4ne], True))
    shape3=Part.Face(Part.makePolygon([v1po,v2po,v2ne,v1ne], True))
    shape4=Part.Face(Part.makePolygon([v2po,v3po,v3ne,v2ne], True))
    shape5=Part.Face(Part.makePolygon([v3po,v4po,v4ne,v3ne], True))
    shape6=Part.Face(Part.makePolygon([v1po,v4po,v4ne,v1ne], True))
    shape_list = [shape1,shape2,shape3,shape4,shape5,shape6]
    shell_shape=Part.Shell([shape1,shape5,shape3,shape4,shape6,shape2])
    BOXSHAPE = Part.makeSolid(shell_shape)
    shellPt = Part.Vertex(shell_shape.CenterOfMass)
    shape_sum = 0
    cutobj = None
    commonFace = None
    mygroup = []
    FACELIST = []
    ONMIDOBJ = []
    NUM=1
    NUM1=len(FreeCAD.ActiveDocument.Objects)
    bar_showup()
    for i in FreeCAD.ActiveDocument.Objects: # all obj
        QQ=0
        setvalue(NUM*100/NUM1)
        NUM+=1
        if QQ == 0:
            if FreeCADGui.ActiveDocument.getObject(i.Name).Visibility == True:
                try:
                    for j in shape_list:
                        FreeCAD.Console.PrintMessage('\ni:'+str(i.Name)+'   j:'+str(j)+'  =>  '+str(len(i.Shape.common(j).Faces)))
                        if len(i.Shape.common(j).Faces) >= 1:
                            commonFace = i.Shape.common(j).Faces # Face
                            cutobj = i
                            objbaseshape = j
                            shape_sum += 1
                            prf('objName',cutobj.Name)
                            TRA = FreeCADGui.ActiveDocument.getObject(cutobj.Name).Transparency   # get Transparency
                            scolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).ShapeColor  # get shape color
                            lcolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).LineColor  # get line color
                            pcolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).PointColor  # get point locor
                            try:
                                C_GRP = cutobj.GROUP
                                C_ID = cutobj.ID
                            except:
                                C_GRP = []
                                C_ID = []
                                prf("NO~~~group  id")
                            if cutobj.InList <> []:  # get group
                                groupname = cutobj.InList[0].Name
                                mygroup = FreeCAD.ActiveDocument.getObject(groupname)
                            name = cutobj.Label # get name
                            prf("Transparency",TRA)
                            prf('scolar',scolar)
                            prf('lcolar',lcolar)
                            prf('pcolar',pcolar)
                            prf('mygroup',mygroup)
                            prf('name',name)# cut)obj  Base_face  common_face  Transparency shape.. point line shape group group id
                            FACELIST.append([i,j,commonFace,TRA,scolar,lcolar,pcolar,mygroup,name,C_GRP,C_ID])
                    try: # find obj in mid
                        if i.Shape.common(BOXSHAPE).Area == i.Shape.Area: #in mid
                            ONMIDOBJ.append(i)
                            prf('Area SAME')
                        else:
                            prf('Area NOT SAME . . . !  ')
                    except:
                        prf('MID FIND ERROR...')
                except: prf('\nNo Shape.')
    if shape_sum == 0:
        return(errorDialog("GET NO OBJECTS!"))
    #find GROUP
    C_CM=[]
    C_NM=[]
    CMOBJLIST = []
    NMOBJLIST = []
    NUM=1
    NUM1=len(FACELIST)
    bar_showup()
    for i in FACELIST: # cut)obj  Base_face  common_face
        NUM+=1
        #   i[0] = cutobj
        #   i[1] = objbaseshape
        #   i[2] = commonFace
        objbase = mkObj(i[1])
        objnor = commonFace[0].normalAt(0,0) # obj nor
        #Extrude..
        EXT = FreeCAD.ActiveDocument.addObject("Part::Extrusion","Extrude")
        EXT.Base = objbase
        EXT.Dir = objnor*0.0001*-1
        EXT.Solid = (True)
        FreeCAD.ActiveDocument.recompute()
        #CUT
        mycut = FreeCAD.ActiveDocument.addObject("Part::Cut","Cut")
        mycut.Base = i[0]
        mycut.Tool = EXT
        DOW = Draft.downgrade([mycut],delete=True)
        prf('DOW',DOW   ) # cut obj
        T_CM=[]
        T_NM=[]
        for ii in DOW[0]:
            prf('common der Face:',len(BOXSHAPE.common(ii.Shape).Solids))
            if len(BOXSHAPE.common(ii.Shape).Solids) ==1:
                T_CM.append(ii) # MOVE
                prf("MOVE")
            else:
                T_NM.append(ii)# NO MOVE
                prf("NO MOVE")
        C_CM.append(T_CM)
        C_NM.append(T_NM)
        for ii in DOW[0]:
            FreeCADGui.ActiveDocument.getObject(ii.Name).Transparency = i[3]   # give Transparency
            FreeCADGui.ActiveDocument.getObject(ii.Name).ShapeColor = i[4]    # give shape color
            FreeCADGui.ActiveDocument.getObject(ii.Name).LineColor = i[5]      # give line color
            FreeCADGui.ActiveDocument.getObject(ii.Name).PointColor = i[6]     # give point locor
        prf('del objbase',objbase.Name)
        FreeCAD.ActiveDocument.removeObject(objbase.Name)
        #~ prf("i[0].Name",i[0].Name)
        DELII.append(i[0].Name) # find the objs will stretch
        prf("EXT.Name",EXT.Name)
        FreeCAD.ActiveDocument.removeObject(EXT.Name) # remove
        prf("C_CM",C_CM)
        prf("C_NM",C_NM)
    close()
    return(C_CM,C_NM)
def ssobj(CO_CM,CO_NM,MOV):
    prf("FACELIST",FACELIST)
    num=0
    DELLIST=[]
    KED = 0
    LENN = MOV.Length
    LEN = MOV.Length+0.0015
    objnor = MOV.normalize() # obj nor
    MMOV = objnor*LENN
    bar_showup()
    NUM=1
    NUM1=len(FACELIST)
    for ii in FACELIST: # N  [  [obj,obj,[face,face,face],tra,pc,lc,sc,group,name,grp,id] , [...] , [...] , [...]  ]
        NUM+=1
        CLOUD9=[] # obj need to Fuse
        TPA=[]
        for i in ii[2]:# commonface
            TPA.append(mkObj(i))
            AEXT = FreeCAD.ActiveDocument.addObject("Part::Extrusion","Extrude") # Face __ Extrude
            AEXT.Base = TPA[-1]
            AEXT.Dir = objnor*(LEN)
            AEXT.Solid = (True)
            for j in CO_NM[num]: # Judge cut or fuse
                if AEXT.Shape.common(j.Shape).Area > 0.1:
                    KED = 1
            CLOUD9.append(AEXT)
            Draft.move(AEXT,objnor*-0.0005,copy=False)#stretch obj avoid ..0.0005..
        # CM obj move ..
        Draft.move(CO_CM[num],MMOV,copy=False)
        prf('MOV',MOV)
        if KED == 1:    #  cut
            prf("cut")
            if len(CLOUD9) > 1:
                MuCut = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","myEXXXX")
                MuCut.Shapes = CLOUD9
            else:
                MuCut = CLOUD9[0]
                MuCut.Label = 'myEXXXX'
            DELLIST.append(MuCut.Name)
            if len(CO_NM[num]) > 1: # CUT BASE
                SECut = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","CUTBAS")
                SECut.Shapes = CO_NM[num]
            else:
                SECut = CO_NM[num][0]
                SECut.Label = 'CUTBASE'
            DELLIST.append(SECut.Name)
            C9Cut = FreeCAD.ActiveDocument.addObject("Part::Cut","Cut") #cut!
            C9Cut.Base = SECut
            C9Cut.Tool = MuCut
            DELLIST.append(C9Cut.Name)
            Draft.move(C9Cut,objnor*-0.0012,copy=False)
            COO = [] # fuse_obj
            COO.append(C9Cut)
            for k in CO_CM[num]:
                COO.append(k)
            Mu = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","Fusion")
            Mu.Shapes = COO
            #~ if ii [9] <> []:
                #~ from GsCad.c1_std import addpro
                #~ Mui = addpro.addpro(Mui,ii[8],ii[9],ii[10],'    ',[[0,0,0]],ii[5],ii[6],ii[4])[0]
            #~ else:
            Mui = mkObj(Mu.Shape)
            Mui.Label = ii[8]    #name
            if ii[7]: mygroup.addObject(Mui)  #grp
            FreeCADGui.ActiveDocument.getObject(Mui.Name).Transparency = ii[3]   # Transparency
            FreeCADGui.ActiveDocument.getObject(Mui.Name).ShapeColor = ii[4]  # shape
            FreeCADGui.ActiveDocument.getObject(Mui.Name).LineColor = ii[5]      # line
            FreeCADGui.ActiveDocument.getObject(Mui.Name).PointColor = ii[6]   # point
            DELLIST.append(Mu.Name) # fuse_obj
            for iii in CO_NM[num]:
                CLOUD9.append(iii)
            for iii in CO_CM[num]:
                CLOUD9.append(iii)
            for ww in CLOUD9:
                DELLIST.append(ww.Name)
            for ww in TPA:
                DELLIST.append(ww.Name) # face
            num+=1
        else:    #  stretch
            prf("stretch")
            for i in CO_NM[num]:
                CLOUD9.append(i)
            for i in CO_CM[num]:
                CLOUD9.append(i)
            Mu.Shapes = CLOUD9
            #~ if ii [9] <> []:
            #~ else:
            if ii[7]: mygroup.addObject(Mui)  # grp
            DELLIST.append(Mu.Name) # fuse obj
            for ww in TPA:
            for ww in CLOUD9:
                DELLIST.append(ww.Name) # face obj_A obj_B
            num+=1
    close()
    prf("DELLIST",DELLIST)
    for i in DELLIST:
        try:
            FreeCAD.ActiveDocument.removeObject(i)
        except:
            prf("DEL repeat!")
    prf("DELII",DELII)
    for i in DELII:
        try: FreeCAD.ActiveDocument.removeObject(i)
        except: prf("DELII no",i)
def showup():
    global reobsel
    reobsel = Ui_reobsel()
    FreeCADGui.Control.showDialog(reobsel)
def isPtOnEdge(pt,edge) : # find is point on edge
    v = Part.Vertex(pt)
    d = v.distToShape(edge)
    if d:
        if d[0] < 0.01:
            return True
    return False
def mkObj(shape):  # make obj
    obj = FreeCAD.ActiveDocument.addObject("Part::Feature",'Temp')
    obj.Shape = shape
    return(obj)
def errorDialog(msg): # message
    unicode_str =  unicode(msg,'utf-8')
    diag = QtGui.QMessageBox(QtGui.QMessageBox.Warning, 'Error MessageBox', unicode_str)
    diag.setWindowModality(QtCore.Qt.ApplicationModal)
    diag.exec_()
def prf(m,p=0):
    if p==0: FreeCAD.Console.PrintMessage('\n'+str(m))
    else: FreeCAD.Console.PrintMessage('\n'+str(m)+':'+str(p))
class Ui_Bar():
    def setupUi(self, MainWindow):
        MainWindow.setObjectName("MainWindow")
        MainWindow.resize(240, 138)
        self.centralWidget = QtGui.QWidget(MainWindow)
        self.centralWidget.setObjectName("centralWidget")
        self.progressBar = QtGui.QProgressBar(self.centralWidget)
        self.progressBar.setGeometry(QtCore.QRect(10, 40, 211, 23))
        self.progressBar.setProperty("value", 0)
        self.progressBar.setObjectName("progressBar")
        self.label = QtGui.QLabel(self.centralWidget)
        self.label.setGeometry(QtCore.QRect(30, 10, 267, 17))
        self.label.setObjectName("label")
        MainWindow.setCentralWidget(self.centralWidget)
        self.menuBar = QtGui.QMenuBar(MainWindow)
        self.menuBar.setGeometry(QtCore.QRect(0, 0, 240, 25))
        self.menuBar.setObjectName("menuBar")
        MainWindow.setMenuBar(self.menuBar)
        self.mainToolBar = QtGui.QToolBar(MainWindow)
        self.mainToolBar.setObjectName("mainToolBar")
        MainWindow.addToolBar(QtCore.Qt.TopToolBarArea, self.mainToolBar)
        self.statusBar = QtGui.QStatusBar(MainWindow)
        self.statusBar.setObjectName("statusBar")
        MainWindow.setStatusBar(self.statusBar)
        self.retranslateUi(MainWindow)
        QtCore.QMetaObject.connectSlotsByName(MainWindow)
        screen=QtGui.QDesktopWidget().screenGeometry()
        size=MainWindow.geometry()
        MainWindow.move((screen.width()-size.width())/2, (screen.height()-size.height())/2)
    def retranslateUi(self, MainWindow):
        MainWindow.setWindowTitle(QtGui.QApplication.translate("MainWindow", "A progress bar", None, QtGui.QApplication.UnicodeUTF8))
        self.label.setText(QtGui.QApplication.translate("MainWindow", "please wait...", None, QtGui.QApplication.UnicodeUTF8))
def close():
    bbbarui.close()
def setvalue(v):
    Barui.progressBar.setProperty("value", v)
bbbarui = QtGui.QMainWindow()
Barui = Ui_Bar()
def  bar_showup():
    Barui.setupUi(bbbarui)
    bbbarui.show()
yorik
Site Admin
Re: Stretch in 3D
Postby yorik » Fri Nov 13, 2015 5:45 pm
Wow, nice! I had plans to do something like that too ( issue #1163 ) but never had time to start...
I'll have a look at this ASAP!
cox
Re: Stretch in 3D
Postby cox » Fri Nov 13, 2015 10:51 pm
Cool, eason
Nice work, and thanks for sharing
Godspeed on your journey for perfection :D
godblessfq
Re: Stretch in 3D
Postby godblessfq » Thu Nov 26, 2015 8:38 pm
Looks like the sychronous modelling in solid edge. It would be nice to add position control of sketch mapped to faces parallel to the stretch direction, such as bottom alligned, centered and top aligned.
Thank you for sharing.
eason
Re: Stretch in 3D
Postby eason » Thu Jun 02, 2016 7:24 am
Here is version 2.0
  1. Add progress bar.
  • You can select what you want to stretch.
  • You can Select many objects.
#    3D拉昇功能                      #
#    2015/10/05 11:35               #
#               version 2.0             #
#           by    Eason               #
import FreeCADGui, Part,FreeCAD,DraftVecUtils,DraftTrackers,Draft
import FreeCADGui as Gui
from GsCad.fc_cmd import view
global FACELIST , linkobj
linkobj = []
FACELIST = []
try:
    def _fromUtf8(s):
        return s
try:
# bar
global Barui
value = 0
class Ui_Bar():
        MainWindow.setWindowTitle(QtGui.QApplication.translate("MainWindow", "progress bar", None, QtGui.QApplication.UnicodeUTF8))
        self.label.setText(QtGui.QApplication.translate("MainWindow", "Program execution. Please wait ...", None, QtGui.QApplication.UnicodeUTF8))
def bar_close():
    bbbarui.close()
def bar_setvalue(v):
Barui = Ui_Bar()
def  bar_showup():
    bbbarui.show()
# bar
# view
global sg,ma,coords,lines,no
def view_open():
    開啟動畫效果
    sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
    ma.rgb = (1.0,0.0,1.0)
    coords = coin.SoCoordinate3()
    lines = coin.SoIndexedLineSet()
    no = coin.SoSeparator()
    no.addChild(coords)
    no.addChild(ma)
    no.addChild(lines)
    sg.addChild(no)
def view_close():
    global sg,coords,lines,no,ma
    關掉動畫效果
    no.removeChild(coords)
    no.removeChild(lines)
    no.removeChild(ma)
    #sg.removeChild(coords)
def view_set(pts,num):
    設定線 set(pts,num)
    pts: [ [p1] , [p2] , [p3] ....]
    num: [0,1,-1,2,3 ....]
    -1表示隔開
    0,1 表示連接0&1兩點的線段
    coords.point.setValues(pts)
    lines.coordIndex.setValues(0,len(num),num)
def view_clear():
    list1 = []
    list2 = []
    for i in range(100):
        list1.append(0)
        list2.append([0,0,0])
    coords.point.setValues(list2)
    lines.coordIndex.setValues(0,len(list1),list1)
# view
    def __init__(self):
        global LCD_CM,LCD_NM,linkobj,change_sel_mode,change_sel_mode,grid_mode
        change_sel_mode = 1 # 選取物件模式
        linkobj = []
        LCD_CM = []
        LCD_NM = []
        self.setupUi()
        self.stack = []
        view_open()
        self.point = None
        self.p = None
        self.CLG = None
        self.presc = -1
        global linkobj
        global LCD_CM,LCD_NM,SSCM,movt,ONMIDOBJ,MD,change_sel_mode
        if self.stack:
            else:
                lastpoint = None
        else:
            lastpoint = None
        if change_sel_mode == 2: # 選取物件完才執行
            self.point = FreeCADGui.Snapper.snap(info["Position"],lastpoint,info["CtrlDown"],info["ShiftDown"],True)  #鎖點
        if info["Type"] == "SoKeyboardEvent":   #  鍵盤按下事件
            if info["State"] == 'UP':
                if info["Key"] == 'RETURN' or info["Key"] == 'PAD_ENTER':  #  按下ENTER
                    if change_sel_mode == 1 :
                        prf('ENTER UP')
                        self.label12.setText(QtGui.QApplication.translate("Form", "", None,QtGui.QApplication.UnicodeUTF8))
                        self.label9.setText(QtGui.QApplication.translate("Form", "<font color=red style='font-size:14pt'><b>Pleasr selete the range</b></font>", None,QtGui.QApplication.UnicodeUTF8))
                        change_sel_mode += 1
            if info["Key"] == 'ESCAPE':  #  按下ESC關掉所有東西
                self.reob()
        elif info["Type"] == "SoLocation2Event" : #  滑鼠移動事件   move
            if len(self.stack) == 1:  #框框示意圖
                pt = [p1,p3,p2,p4]
                view_set(pt,[0,1,2,3,0])
            if len(self.stack) == 3: #拉昇示意圖
                pts=[[self.stack[-1][0],self.stack[-1][1],self.stack[-1][2]],[self.point[0],self.point[1],self.point[2]]]
                view_set(pts,[0,1])
                self.p.move(MD)
        elif info["Type"] == "SoMouseButtonEvent":#  滑鼠點擊事件  click
                if info["State"] == 'DOWN' and info["Button"] == "BUTTON1":#滑鼠DOWN下去
                    self.stack.append(self.point)  #每點一下 都會把點紀錄到self.stack
                    if len(self.stack) == 1: #點第一下
                        FreeCAD.Console.PrintMessage("\n點第一點!")
                    elif len(self.stack) == 2: #點第二下
                        view_clear()
                        FreeCAD.Console.PrintMessage("\n框選完畢")
                        self.label9.setText(QtGui.QApplication.translate("Form", "<font color=red style='font-size:14pt'><b>Starting stretch!</b></font>", None,QtGui.QApplication.UnicodeUTF8))
                        #~ self.sg1.removeChild(self.no1) #移除框框效果
                        p1 = self.stack[0] # 第一點
                        p2 = self.stack[1] # 第二點
                        p3 = self.stack[0].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.v)) # 計算框框兩點
                        p4 = self.stack[0].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.u)) # 計算框框兩點
                        FreeCAD.ActiveDocument.openTransaction("3D拉昇-切割") # undo
                        LCD_CM,LCD_NM = cutobj(p1,p3,p2,p4) # 切割物件
                        if LCD_CM == LCD_NM == 0: # 沒找到物件 從開
                            self.reob()
                            showup()
                        else:
                            self.presc = 0
                            SSCM = []
                            for i in LCD_CM:
                                for ii in i:
                                    SSCM.append(ii)
                            prf('SSCM',SSCM)
                            for i in ONMIDOBJ:
                                SSCM.append(i)
                            prf('...ok!')
                            self.p=DraftTrackers.ghostTracker(SSCM) # 動畫效果..移動物件
                            self.p.on() # 啟動動畫效果
                        #~ self.sg2.removeChild(self.no2) # 結束動畫效果..線
                        #~ self.precs = 1
                        movt = self.stack[-1].sub(self.stack[-2]) # 移動量
                        self.label9.setText(QtGui.QApplication.translate("Form", "<font color=red style='font-size:14pt'><b>Please click 'OK' to finish</b></font>", None,QtGui.QApplication.UnicodeUTF8))
    def accept(self): # 確定
        global change_sel_mode
            self.CKDS()
        if change_sel_mode == 1:
            prf('ENTER UP')
            self.label9.setText(QtGui.QApplication.translate("Form", "<font color=red style='font-size:14pt'><b>Please Select the range what you want to stretch.</b></font>", None,QtGui.QApplication.UnicodeUTF8))
    def reject(self):  # 取消
        self.reob()
    def reob(self):#通通關掉
        global LCD_NM,LCD_CM,FACELIST , StaSel
        if self.p: self.p.off() # 結束動畫效果..移動物件
        view_close()
        FreeCADGui.Snapper.off()  #鎖點解除
        FreeCAD.Console.PrintMessage("\n拉昇結束...!")
        self.view.removeEventCallback("SoEvent",self.c)  #關掉Observer
        prf('close self.c')
        #~ FreeCADGui.Selection.removeObserver(StaSel)
        if self.presc == -1: prf('沒選東西')
        if self.presc == 0:
    def showobj(self):
        Gui.Selection.clearSelection()
        obj=FreeCAD.ActiveDocument.getObjectsByLabel(str(self.listins.currentItem().text()))
        Gui.Selection.addSelection(obj[0])
    def setupUi(self):
        self.label10 = QtGui.QLabel(widget1)
        self.label10.setObjectName(_fromUtf8("label10"))
        self.layout.addWidget(self.label10,6,0)
        self.label11 = QtGui.QLabel(widget1)
        self.label11.setObjectName(_fromUtf8("label11"))
        self.layout.addWidget(self.label11,6,1)
        self.label12 = QtGui.QLabel(widget1)
        self.label12.setObjectName(_fromUtf8("label12"))
        self.layout.addWidget(self.label12,12,1)
        self.listins = QtGui.QListWidget(widget1) # 放物件
        self.listins.setObjectName(_fromUtf8("listins"))
        self.listins.setFixedWidth(115)
        self.layout.addWidget(self.listins,12,0)
        self.sel1 = QtGui.QPushButton(widget1) # 選取
        self.sel1.setObjectName(_fromUtf8("sel1"))
        self.layout.addWidget(self.sel1,10,0)
        self.sel2 = QtGui.QPushButton(widget1) # 刪除
        self.sel2.setObjectName(_fromUtf8("sel2"))
        self.layout.addWidget(self.sel2,10,1)
        self.sel3 = QtGui.QPushButton(widget1) # 顯示
        self.sel3.setObjectName(_fromUtf8("sel3"))
        self.layout.addWidget(self.sel3,11,0)
        self.sel4 = QtGui.QPushButton(widget1) # 取消
        self.sel4.setObjectName(_fromUtf8("sel4"))
        self.layout.addWidget(self.sel4,11,1)
        QtCore.QObject.connect(self.sel1, QtCore.SIGNAL("clicked()"), self.addsel1)
        QtCore.QObject.connect(self.sel2, QtCore.SIGNAL("clicked()"), self.addsel2)
        QtCore.QObject.connect(self.sel3, QtCore.SIGNAL("clicked()"), self.addsel3)
        QtCore.QObject.connect(self.sel4, QtCore.SIGNAL("clicked()"), self.addsel4)
        QtCore.QObject.connect(self.listins, QtCore.SIGNAL("clicked(QModelIndex)"), self.showobj)
        self.DCL1.setText("0.0000")
        self.DCL2.setText("0.0000")
        self.DCL3.setText("0.0000")
        self.DCL12.setText("0.0000")
        self.sel1.setText(QtGui.QApplication.translate("Form", "Selsct", None,QtGui.QApplication.UnicodeUTF8))
        self.sel2.setText(QtGui.QApplication.translate("Form", "Delete", None,QtGui.QApplication.UnicodeUTF8))
        self.sel3.setText(QtGui.QApplication.translate("Form", "Display", None,QtGui.QApplication.UnicodeUTF8))
        self.sel4.setText(QtGui.QApplication.translate("Form", "Delete all", None,QtGui.QApplication.UnicodeUTF8))
        self.label.setText(QtGui.QApplication.translate("Form", "distance:", None,QtGui.QApplication.UnicodeUTF8))
        self.label1.setText(QtGui.QApplication.translate("Form", "Global X:", None,QtGui.QApplication.UnicodeUTF8))
        self.label2.setText(QtGui.QApplication.translate("Form", "Global Y:", None,QtGui.QApplication.UnicodeUTF8))
        self.label3.setText(QtGui.QApplication.translate("Form", "Global Z:", None,QtGui.QApplication.UnicodeUTF8))
        self.label9.setText(QtGui.QApplication.translate("Form", "<font color=red style='font-size:14pt'><b>Please select objects</b></font>", None,QtGui.QApplication.UnicodeUTF8))
        self.label10.setText(QtGui.QApplication.translate("Form", "<font color=blue style='font-size:14pt'><b>——————</b></font>", None,QtGui.QApplication.UnicodeUTF8))
        self.label11.setText(QtGui.QApplication.translate("Form", "<font color=blue style='font-size:14pt'><b>————————</b></font>", None,QtGui.QApplication.UnicodeUTF8))
        self.label12.setText(QtGui.QApplication.translate("Form", "\
1.Check your working plane!\n2.Click objects you want to stretch.\n\
3.Click 'Select'.\n4.Click Enter to start.\n\
PS.If you click Enter without seleting anything..\nAll objects selected by default!"\
        #~ self.OK.setText(QtGui.QApplication.translate("reobsel", "設定工作面", None, QtGui.QApplication.UnicodeUTF8))
    def addsel1(self): # 選取
        global linkobj
        if change_sel_mode == 1: # 選物件
            sel = Gui.Selection.getSelection()
            for i in sel:
                if i not in linkobj:
                    linkobj.append(i)
            self.listins.clear()
            for i in linkobj:
                self.listins.addItem(str(i.Label))
            for i in linkobj:
                FreeCADGui.Selection.addSelection(i)
    def addsel2(self): # 刪除
        global linkobj
            for i in sel:
                if i in linkobj:
                    linkobj.remove(i)
            for i in linkobj:
            #for i in linkobj:
                #FreeCADGui.Selection.addSelection(i)  #慧芸要求不需顯示
    def addsel3(self): # 顯示
        global linkobj
            FreeCADGui.Selection.clearSelection()
            for i in linkobj:
    def addsel4(self): # 取消
        global linkobj
    def setgrid(self): # 設定工作面
        global grid_mode
        if grid_mode == 0:
            grid_mode = 1
        else:
            grid_mode = 0
            if len(FreeCADGui.Selection.getSelection()) == 0:
                errorDialog('請選擇一個面!')
            else:
                sel = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]
                if issubclass(type(sel),Part.Face):
                    FreeCAD.DraftWorkingPlane.alignToPointAndAxis()
                    FreeCADGui.Snapper.setGrid()
                else:
                    errorDialog('請選面!')
    def CKDS(self):
        if LCD_CM == LCD_NM == []: return(errorDialog("請先選擇物件!"))
        FreeCAD.ActiveDocument.openTransaction("3D拉昇-移動") # undo
        for i in ONMIDOBJ:# 移動!
        ssobj(LCD_CM,LCD_NM,mov) # 拉昇!
        self.reob()
    def getKK(self): # 關掉在開
            self.reob()
            showup()
        global MD
        prf('cd',cd)
    b1=s1.BoundBox
    b2=s2.BoundBox
        return(True)
        return(True)
    else:
        return(False)
def cutobj(a1=[],a2=[],a3=[],a4=[]): # 給4個座標 ... 畫出一個Shell ... 切割物件 ... 返回兩個物件
    global name,lcolor,pcolor,scolor,mygroup,commonFace,FACELIST,DELII,ONMIDOBJ,linkobj,cutline
    DELII = []
    dd = 200 # nor向量加成
    v1po = a1+nor*dd
    v2po = a2+nor*dd
    v3po = a3+nor*dd
    v4po = a4+nor*dd
    v1ne = a1-nor*dd
    v2ne = a2-nor*dd
    v3ne = a3-nor*dd
    v4ne = a4-nor*dd
    #~ Part.show(shell_shape)
    #~ BOX_W = v1po.sub(v2po).Length
    #~ BOX_L = v2po.sub(v3po).Length
    #~ BOX_H = v1po.sub(v1ne).Length
    #~ BOX_P = (a1+a2+a3+a4)*0.25-nor*dd+a2.sub(a1)*0.5+a3.sub(a2)*0.5
    #~ BOX_D = nor
    #~ BOXSHAPE = Part.makeBox(BOX_L,BOX_W,BOX_H,BOX_P,BOX_D)
    #~ Part.show(BOXSHAPE)
    shape_sum = 0
    cutobj = None
    commonFace = None
    mygroup = []
    FACELIST = []
    ONMIDOBJ = []
    NUM=1
    cutline = []
    bar_showup()
    if linkobj == []:
        allOBJ = FreeCAD.ActiveDocument.Objects
    else:
        allOBJ = linkobj
    for i in allOBJ: # 全部的物件
        sel_line_up2 = 0
        QQ=0
        bar_setvalue(NUM*100/NUM1)
        NUM+=1
        if QQ == 0:
                try:
                    if i.Shape.Shells <> []: #必須為3D物件
                        if fix == 1: errorDialog('物件:'+str(i.Label)+'\n')
                        if fix == 1: errorDialog(str(shape_list))
                            if fix==1: errorDialog('\ni:'+str(i.Label)+'   j:'+str(j)+'  =>  '+str(len(i.Shape.common(j).Faces)))
                            if len(i.Shape.common(j).Faces) >= 1: # 取得各種資訊
                                if fix==1: errorDialog('get FACELIST~')
                                sel_line_up2 += 1
                                cutobj = i
                                objbaseshape = j
                                shape_sum += 1
                                TRA = FreeCADGui.ActiveDocument.getObject(cutobj.Name).Transparency   # 取得透明度
                                scolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).ShapeColor  # 取得形狀顏色
                                lcolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).LineColor  # 取得線顏色
                                pcolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).PointColor  # 取得點顏色
                                try:
                                    C_ID = cutobj.ID
                                except:
                                    C_GRP = []
                                    C_ID = []
                                if cutobj.InList <> []:  #取得所在資料夾位置
                                name = cutobj.Label #取得名稱
                                prf('name',name)# 要被切的物件  Base的面  common面  透明度 顏色 點 線 形狀 資料夾 group id
                        try: # 在中間的物件
                            if i.Shape.common(BOXSHAPE).Area == i.Shape.Area: #在中間
                                ONMIDOBJ.append(i)
                                prf('Area SAME')
                            else:
                        except:
                    elif len(i.Shape.Edges) == 1: # 線
                        cutgroup = []
                        if i.InList <> []:  #取得所在資料夾位置
                            groupname = i.InList[0].Name
                            cutgroup = FreeCAD.ActiveDocument.getObject(groupname)
                        L_v1 = i.Shape.Vertex1.Point
                        L_v2 = i.Shape.Vertex2.Point
                        if shell_shape.BoundBox.isInside(L_v1):
                            cutline.append([i,L_v1,L_v2,cutgroup])
                        else:
                            cutline.append([i,L_v2,L_v1,cutgroup])
                # 兩個面touch....
                prf('FACELIST',FACELIST)
                prf('sel_line_up2',sel_line_up2)
                if sel_line_up2 == 2:
                    prf('FASELIST[-1]',FACELIST[-1])
                    prf('FASELIST[-2]',FACELIST[-2])
                    FACELIST[-1].append(2)
                    FACELIST[-1].append(1)
                    FACELIST[-2].append(2)
                elif sel_line_up2 == 1:
                elif sel_line_up2 > 2:
                    FACELIST[-1].append(3)
    if shape_sum == 0:
        errorDialog("沒有找到物件!")
        bar_close()
        return(0,0)
    #收尋GROUP
    C_CM=[]
    C_NM=[]
    CMOBJLIST = []
    NMOBJLIST = []
    NUM=1
    NUM1=len(FACELIST)
    bar_showup()
    for i in FACELIST: # 要被切的物件  Base的面  common面  透明度 (顏色)點 線 形狀 資料夾 group id 2or1 2or1
        if i[-1] == 2: # 一個物件切到兩個面
            prf("物件切到兩面 忽略~")
            bar_setvalue(100)
        elif i[-1] > 2:
            prf('物件切超過兩個面 忽略~')
            bar_setvalue(100)
        else:
            NUM+=1
            #長出薄片
            EXT.Base = objbase
            EXT.Solid = (True)
            #物件與薄片切割
            mycut.Base = i[0]
            mycut.Tool = EXT
            prf('DOW',DOW   ) # 切出來的東西...
            T_CM=[]
            T_NM=[]
            for ii in DOW[0]:
                    prf("MOVE")
                else:
                    prf("NO MOVE")
            C_CM.append(T_CM)
            C_NM.append(T_NM)
            for ii in DOW[0]:
                FreeCADGui.ActiveDocument.getObject(ii.Name).Transparency = i[3]   # 透明度
                FreeCADGui.ActiveDocument.getObject(ii.Name).ShapeColor = i[4]  # 形狀顏色
                FreeCADGui.ActiveDocument.getObject(ii.Name).LineColor = i[5]      # 線顏色
                FreeCADGui.ActiveDocument.getObject(ii.Name).PointColor = i[6]   # 點顏色
            DELII.append(i[0].Name) # 找到的需要拉昇物件
            FreeCAD.ActiveDocument.removeObject(EXT.Name) # 薄片實體
            prf("C_CM",C_CM)
            prf("C_NM",C_NM)
    bar_close()
    return(C_CM,C_NM)
global fix
fix = 0
from GsCad.fc_cmd import s3d
reload(s3d)
#~ s3d.showup()
p1 = FreeCAD.Vector(-15.0,5.0,0.0)
p2 = FreeCAD.Vector(15.0,5.0,0.0)
p3 = FreeCAD.Vector(15.0,15.0,0.0)
p4 = FreeCAD.Vector(-15.0,15.0,0.0)
a,b=s3d.cutobj(p1,p2,p3,p4)
s3d.ssobj(a,b,FreeCAD.Vector(0,5,0))
    global name,lcolor,pcolor,scolor,mygroup,commonFace,FACELIST,DELII,oklist
    global fix , cutline
    # 線段移動
    if cutline:
        for i in cutline:
            cutline1 = Draft.makeLine(i[1]+MOV,i[2])
            FreeCAD.ActiveDocument.removeObject(i[0].Name)
            if i[3]: i[3].addObject(cutline1)
    # 增加的面積
    oklist = []
    num=0
    DELLIST=[]
    KED = 0
    LENN = MOV.Length
    MMOV = objnor*LENN
    bar_showup()
    NUM=1
    NUM1=len(FACELIST)
    for ii in FACELIST: # N個物件  [  [obj,obj,[face,face,face],tra,pc,lc,sc,group,name,grp,id] , [...] , [...] , [...] ,1or2 ]
        if fix == 1: errorDialog('FACELIST 迴圈')
        ii[0].Label = 'temp'
        NUM+=1
        CLOUD9=[] # 需要融合的物件
        TPA=[]
        sel_2_face = 0
        if ii[-2] == 2 :# 有兩個面跟物件碰到........
            if ii[-1] == 2: # 第二個面開始工作時...
                sel_2_face = 1
        for i in ii[2]:# commonface (基準面)
            if fix == 1: errorDialog("Extrude")
            AEXT = FreeCAD.ActiveDocument.addObject("Part::Extrusion","Extrude") # Face長出實體
            AEXT.Base = TPA[-1]
            AEXT.Solid = (True)
            for j in CO_NM[num]: # 判斷切 或是 融合
                    KED = 1
            if KED == 1:    #  縮
                AEXT.Dir = objnor*(LEN-0.0011)
            else: #   拉
            CLOUD9.append(AEXT)   #  把長出的實體丟到C9
            Draft.move(AEXT,objnor*-0.0005,copy=False)#拉昇obj 微移動 避免小縫隙
        # CM物件移動
        prf('MOV',MOV)
        if KED == 1:    #  縮
            prf("縮")
            if fix == 1: errorDialog('縮')
            ############################ CLOUD9 = 切面長出的實體
            if len(CLOUD9) > 1:  #  長出的實體
            else:
                MuCut = CLOUD9[0]
                SECut = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","CUTBASE")
            else:
            if fix == 1: errorDialog('CUT')
            C9Cut = FreeCAD.ActiveDocument.addObject("Part::Cut","Cut") # 切!
            C9Cut.Base = SECut # 不移動的主體
            C9Cut.Tool = MuCut # 長出的實體
            #~ Draft.move(C9Cut,objnor*-0.0012,copy=False) # ?
            COO = [] # 融合物件
            COO.append(C9Cut)
                COO.append(k)
            if fix == 1: errorDialog('Fusion')
            Mu.Shapes = COO
            if ii[7]: mygroup.addObject(Mui)  #群組
            FreeCADGui.ActiveDocument.getObject(Mui.Name).Transparency = ii[3]   # 透明度
            FreeCADGui.ActiveDocument.getObject(Mui.Name).ShapeColor = ii[4]  # 形狀顏色
            FreeCADGui.ActiveDocument.getObject(Mui.Name).LineColor = ii[5]      # 線顏色
            FreeCADGui.ActiveDocument.getObject(Mui.Name).PointColor = ii[6]   # 點顏色
            oklist.append(Mui)
            DELLIST.append(Mu.Name) # 融合物件
                CLOUD9.append(iii)
                CLOUD9.append(iii)
            for ww in CLOUD9:
            for ww in TPA:
                DELLIST.append(ww.Name) # 薄片的面
            num+=1
            Mui.Label = ii[8]    #名稱
        else:    #  拉
            prf("拉")
                CLOUD9.append(i)
                CLOUD9.append(i)
            if fix == 1:
                errorDialog('拉..  Fusion')
                c999 = []
                for k in CLOUD9:
                    c999.append(k.Label)
                errorDialog('CLOUD9.Label'+str(c999))
                return()
            Mu.Shapes = CLOUD9
            if ii[7]: mygroup.addObject(Mui)  # 群組
            oklist.append(Mui)
            for ww in TPA:
            for ww in CLOUD9:
                DELLIST.append(ww.Name) # 薄片 物件A 物件B
            num+=1
    bar_close()
    for i in DELLIST:
        try:
        except:
            prf("DEL 重複!")
    prf("DELII",DELII)
    for i in DELII:
def showup():
    global reobsel , StaSel
    #~ StaSel = StandSelObserver()
    #~ FreeCADGui.Selection.addObserver(StaSel)
    v = Part.Vertex(pt)
    if d:
        if d[0] < 0.01:
            return True
    return False
    obj.Shape = shape
    return(obj)
    diag.exec_()
def prf(m,p=0):
1. import and showup()
2.select what you want to stretch.
If you select nothing, it will select all objects by default.(If there are many things, it cost you much time)
3.Click'Enter'.
4.Determine your scope which you want to stretch.
5.Starting stretch. Decide if you want to move away from.
6.Fanily, click 'OK' to finish it.
eason
Re: Stretch in 3D
Cuyabeno
Re: Stretch in 3D
Postby Cuyabeno » Sun Oct 30, 2016 6:24 pm
Hello eason,
I am interested in your tool and install this macro, but I get on Ubuntu the message when I start it:
<type 'exceptions.ImportError'>: No module named GsCad.fc_cmd
Can you help me where I can found the module GsCAD.fc_cmd?
bernd
Re: Stretch in 3D
Postby bernd » Wed Nov 16, 2016 7:56 am
very cool tool !
Re: Stretch in 3D
Postby chrisb » Wed Nov 16, 2016 7:11 pm
Cuyabeno wrote:Hello eason,
I have the same problem, but bernd seems to have a running version, since I guess that is comment
bernd wrote:very cool tool !
was not an answer to the GsCad.fc_cmd-problem ;) .
@bernd: could you please look in your python search-path, if some 3rd party workbench or some other macro provides this file.
(same on freecad-daily, and MacOS 0.16.6707)
OS: Ubuntu 14.04.5 LTS
Version: 0.16.6703 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
bernd
Re: Stretch in 3D
Postby bernd » Thu Nov 17, 2016 6:31 pm
Sorry guys I just saw the pictures. Since the CAD we gone use at work has such a tool, and I have been missing the tool in FreeCAD I was quite excited without even test it. But since you guys have been answered I had to test it. Same here. In line 12 it trys to import a module I have never heard about:
and I get the same error than you guys.
if I just comment this line nothing happens, no error no task view just nothing.
