Stretch in 3D
Re: Stretch in 3D
Postby chrisb » Tue Dec 06, 2016 11:59 am
easyw-fc wrote:here the files in a single zipped
s3d.zip
The file is not available, could you please edit your last post? I wonder what's in this s3d.py.
I can't get the X, Y, Z, fields editable, only the distance.
easyw-fc
Re: Stretch in 3D
Postby easyw-fc » Tue Dec 06, 2016 2:00 pm
chrisb wrote: The file is not available, could you please edit your last post? I wonder what's in this s3d.py.
it is strange, I can download the file also when not logged...
anyway I have put the code in the post
with s3d.py you can assign the macro to a toolbar ...
chrisb wrote: I can't get the X, Y, Z, fields editable, only the distance.
me too
Maurice
Re: Stretch in 3D
Postby chrisb » Tue Dec 06, 2016 3:00 pm
Meanwhile I could download your files - strange.
I realized that you translated the chinese comments and you see me in awe.
However, I removed the setEnabled(False)-statements, I even tried to enter fixed values - all to no avail. I am still getting loads of error mesages, too many for me to enjoy continuing yet.
jrdrukin
Re: Stretch in 3D
Postby jrdrukin » Thu Jan 03, 2019 2:48 am
Hello and Happy New Year <eason> :)
Your work on the 3D stretch tool is very intriguing.
I am wondering if you have made any further progress with it?
Perhaps this may be a difficulty if the reference is correct:
https://acronyms.thefreedictionary.com/GSCAD
Appears to be a proprietary file from Dassault Systemes???
Maybe some code from Catia or Solidorks???
Best wishes for safe, happy and prosperous new year.
Jerry/jrdrukin
thotbuilds
Re: Stretch in 3D
Postby thotbuilds » Fri Oct 30, 2020 8:59 am
Hi Guys,
My first post here! Freecad has been the best thing for about a month now! Been using if for BIM project. Migrated from sketchup so really missing the steretch and push pull tools :lol: So i am a FreeCAD noob :D Any updates on this tool ? Has it been integrated somewhere ? I am using the following version on FC. Google this but could not find any answers
OS: Zorin OS 15.3 (zorin:GNOME/zorin)
Version: 0.19.22756 (Git) AppImage
Hash: ce87f586ee36ffe8ebcdcd3947ced4ab389ae795
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: English/India (en_IN)
Re: Stretch in 3D
Postby chrisb » Fri Oct 30, 2020 9:07 am
I haven't heard of anything new, the author never responded.
Re: Stretch in 3D
Postby Kunda1 » Fri Oct 30, 2020 12:52 pm
eason wrote:
Fri Nov 13, 2015 6:02 am
:bell:
johnwang
Re: Stretch in 3D
Postby johnwang » Sun Nov 01, 2020 2:36 am
I use Part, throw in a cube object, then switch to Draft. Change to view x-y plane.
Saved version 1 as a py file. At the end, I added:
showup()
Then run the py file in the python console. There are a few errors.
1. Could I change this:
                            if cutobj.InList <> []:  # get group
to:
                            if cutobj.InList >0:  # get group
2. Commented out #import DraftTrackers
3. Could I change this:
        widget1.setWindowTitle(QtGui.QApplication.translate("Form", "3D Stretch", None,QtGui.QApplication.UnicodeUTF8))
to:
        widget1.setWindowTitle(QtGui.QApplication.translate("Form", "3D Stretch", None))
I think this written in QT4. Need a QT5 version.
After these changes, I got the window up. Trying to figure out the next step.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
johnwang
Re: Stretch in 3D
Postby johnwang » Sun Nov 01, 2020 3:10 am
Next step:
1. Click two points to form the red rectangle. (It should be in x-y plane.)
2. Click two points to draw the blue line to define distance and direction.
Then FC crashed.
I think the program is to use the red rectangle to cut the cube object into two parts. Then move one part according to the blue line. Then generate new part from the cut plane. Then fuse all parts together as one single new part.
johnwang
Re: Stretch in 3D
Postby johnwang » Sun Nov 01, 2020 10:26 am
Stretched!
22:01:16
please pick 1 point!Picked first point. Please pick second point.
22:01:18  Please pick the second point.
22:01:23  Picked 2 points.
22:01:23  Cutting object...
22:01:23
p1 = FreeCAD.Vector(-1.6510096788406372,6.496427059173584,0.0)
22:01:23
p2 = FreeCAD.Vector(-1.6510096788406372,11.250450134277344,0.0)
22:01:23
p3 = FreeCAD.Vector(11.400130271911621,11.250450134277344,0.0)
22:01:23
p4 = FreeCAD.Vector(11.400130271911621,6.496427059173584,0.0)
22:01:23
Object i:Box  Shape 1  =>  0
Object i:Box  Shape 2  =>  0
Object i:Box  Shape 3  =>  0
Object i:Box  Shape 4  =>  0
Object i:Box  Shape 5  =>  0
Object i:Box  Shape 6  =>  1
objName:Box
22:01:23
NO~~~group  id
22:01:23  []
22:01:23
Transparency
22:01:23
scolar:(0.800000011920929, 0.800000011920929, 0.800000011920929, 0.0)
22:01:23
lcolar:(0.09803921729326248, 0.09803921729326248, 0.09803921729326248, 0.0)
22:01:23
pcolar:(0.09803921729326248, 0.09803921729326248, 0.09803921729326248, 0.0)
22:01:23
mygroup:[]
22:01:23
22:01:23
Area NOT SAME . . . !
22:01:23  ----------------
22:01:23  Downgrade objects
22:01:23  Found 1 multi-solids compound: exploding it
22:01:23
DOW:([<Part::PartFeature>, <Part::PartFeature>], [])
22:01:23
common der Face:
22:01:23
NO MOVE
22:01:23
common der Face::1
22:01:23
MOVE
22:01:23
del objbase:Temp
22:01:23
EXT.Name:Extrude
22:01:23
C_CM:[[<Part::PartFeature>]]
22:01:23
C_NM:[[<Part::PartFeature>]]
22:01:23
LCD_CM:[[<Part::PartFeature>]]
22:01:23
SSCM:[<Part::PartFeature>]
22:01:23  Object cutted.
22:01:23
22:01:23
22:01:23
22:01:23  Please pick two points to define the move distance and direction.
22:01:23
22:01:27  Third point picked. Please pick the fourth point.
22:01:30
cd:Vector (0.2690954213158132, 3.9467369388175424, 0.0)
22:01:30  Move distance and direction defined. Please click Move button to stretch.
22:01:34
GOGOGO
22:01:34
ONMIDOBJ:[]
22:01:34
FACELIST:[[<Part::PartFeature>, <Face object at 000001E8D4B5A920>, [<Face object at 000001E8DA7C0670>], 0, (0.800000011920929, 0.800000011920929, 0.800000011920929, 0.0), (0.09803921729326248, 0.09803921729326248, 0.09803921729326248, 0.0), (0.09803921729326248, 0.09803921729326248, 0.09803921729326248, 0.0), [], 'Cube', [], []]]
22:01:34
MOV:Vector (0.06802560372540664, 0.9976835757081471, 0.0)
22:01:34
stretch
22:01:34
DELLIST:['Fusion', 'Temp', 'Extrude', 'Solid', 'Solid001']
22:01:34
DELII:['Box']
22:01:34
Stretch  quit...!
close self.c
22:01:34
0
22:01:34
press ESC ... visibility => True
22:01:34
ii:[<Part::PartFeature>, <Face object at 000001E8D4B5A920>, [<Face object at 000001E8DA7C0670>], 0, (0.800000011920929, 0.800000011920929, 0.800000011920929, 0.0), (0.09803921729326248, 0.09803921729326248, 0.09803921729326248, 0.0), (0.09803921729326248, 0.09803921729326248, 0.09803921729326248, 0.0), [], 'Cube', [], []]
22:01:34
DELERROR
