- s3d3.jpg (5.07 KiB) Viewed 599 times
- s3dm.jpg (11.29 KiB) Viewed 599 times
I seldom use AddonManager.
import DraftTrackers
from draftguitools import gui_trackers
.At the end i addedCode: Select all
showup()
So , based on your experiments, should this change be done or not?It seems thatshould change toCode: Select all
ModuleNotFoundError: No module named 'DraftTrackers'
import draftguitools.gui_trackers as DraftTrackers
I made the changes that were in this thread, some errors were related to utf8 and qt5. To import the tool, you can put the "stretcher_u8.py" file in your bin folder and then "import stretcher_u8", or something like this with another filepath.
import types
import importlib.machinery
loader = importlib.machinery.SourceFileLoader('stretch', '/home/watsug/Documents/freeCAD/stretch_u8.py')
mod = types.ModuleType(loader.name)
loader.exec_module(mod)
# -*- coding: utf-8 -*-
# 3D
# 2015/10/05 11:35
# hahaha~
import FreeCADGui, Part
import FreeCAD
import DraftVecUtils
#import DraftTrackers
from PySide.QtCore import QObject
from pivy.coin import *
from pivy import coin
import Draft
try:
_fromUtf8 = QtCore.QString.fromUtf8
except AttributeError:
def _fromUtf8(s):
return s
try:
_encoding = QtGui.QApplication.UnicodeUTF8
def _translate(context, text, disambig):
return QtGui.QApplication.translate(context, text, disambig, _encoding)
return QtGui.QApplication.translate(context, text, disambig)
class Ui_reobsel(object):
def __init__(self):
global LCD_CM,LCD_NM
LCD_CM = []
LCD_NM = []
self.setupUi()
self.view = FreeCADGui.ActiveDocument.ActiveView
self.stack = []
self.point = None
self.p = None
self.CLG = None
self.presc = -1
self.getobj()
self.aline()
self.c = self.view.addEventCallback("SoEvent",self.action)
def action(self,info):
global LCD_CM,LCD_NM,SSCM,movt,ONMIDOBJ,MD
if self.stack: lastpoint = self.stack[-1]
else: lastpoint = None
self.point = FreeCADGui.Snapper.snap(info["Position"],lastpoint,info["ShiftDown"],info["ShiftDown"],True) #snap
#~ FreeCAD.Console.PrintMessage('\nself.point:'+str(self.point))
if info["Type"] == "SoKeyboardEvent":
if info["Key"] == 'ESCAPE': # ESC
self.reob()
elif info["Type"] == "SoLocation2Event" : # move
if len(self.stack) == 1:
p1 = [self.stack[-1][0],self.stack[-1][1],self.stack[-1][2]]
p2 = [self.point[0],self.point[1],self.point[2]]
diagonal = self.point.sub(self.stack[-1])
p3 = self.stack[-1].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.v))
p4 = self.stack[-1].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.u))
p3 = [p3[0],p3[1],p3[2]]
p4 = [p4[0],p4[1],p4[2]]
pt = [p1,p3,p2,p4]
self.coords1.point.setValues(pt)
self.lines1.coordIndex.setValues(0,5,[0,1,2,3,0])
if len(self.stack) == 3:
#~ prf('SSCM',SSCM)
#~ for i in SSCM:
#~ FreeCADGui.ActiveDocument.getObject(i.Name).Visibility = False
self.coords2.point.setValues([[self.stack[-1][0],self.stack[-1][1],self.stack[-1][2]],[self.point[0],self.point[1],self.point[2]]])
self.lines2.coordIndex.setValues(0,2,[0,1])
MD = self.point.sub(self.stack[-1])
self.p.move(MD)
self.DCL1.setText(str(round(MD[0],4)))
self.DCL2.setText(str(round(MD[1],4)))
self.DCL3.setText(str(round(MD[2],4)))
self.DCL12.setText(str(round(MD.Length,4)))
self.DCL12.setFocus()
self.DCL12.selectAll()
elif info["Type"] == "SoMouseButtonEvent":# click
if info["State"] == 'DOWN' and info["Button"] == "BUTTON1":#DOWN
self.stack.append(self.point)
if len(self.stack) == 1: #point1
FreeCAD.Console.PrintMessage("\nplease pick 1 point!")
elif len(self.stack) == 2: #point2
self.label9.setText(QtGui.QApplication.translate("Form", "pls pick 2 point ", None))
self.sg1.removeChild(self.no1) #remove
p1 = self.stack[0] # point1
p2 = self.stack[1] # point2
diagonal = self.stack[1].sub(self.stack[0])
p3 = self.stack[0].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.v))
p4 = self.stack[0].add(DraftVecUtils.project(diagonal,FreeCAD.DraftWorkingPlane.u))
FreeCAD.ActiveDocument.openTransaction("3D Stretch-cut") # undo
LCD_CM,LCD_NM = cutobj(p1,p3,p2,p4) # cut
FreeCAD.ActiveDocument.commitTransaction() # undo
self.presc = 0 # esc
SSCM = []
prf("LCD_CM",LCD_CM)
for i in LCD_CM:
for ii in i:
SSCM.append(ii)
prf('SSCM',SSCM)
for i in ONMIDOBJ:
SSCM.append(i)
# self.p=DraftTrackers.ghostTracker(SSCM) # trackers give my obj
self.p=gui_trackers.ghostTracker(SSCM) # trackers give my obj
self.p.on() # trackers on !
elif len(self.stack) == 4:
self.sg2.removeChild(self.no2) # close line
self.precs = 1
movt = self.stack[-1].sub(self.stack[-2]) # move_distance
self.CKDS()
def accept(self): # accept
self.CKDS()
def reject(self): # cancel
self.reob()
def reob(self):#close
global LCD_NM,LCD_CM,FACELIST
if self.p: self.p.off() # close tracker
FreeCADGui.Snapper.off() #close snap
FreeCAD.Console.PrintMessage("\nStretch quit...!")
self.view.removeEventCallback("SoEvent",self.c) #close Observer
prf('close self.c')
FreeCADGui.Control.closeDialog()
prf(self.presc)
if self.presc == 0:
prf('press ESC ... visibility => True')
try:
for ii in FACELIST:
prf('ii',ii)
FreeCADGui.ActiveDocument.getObject(ii[0].Name).Visibility = True
prf(ii[0].Name)
prf("LCD_CM",LCD_CM[0][0].Name)
prf("LCD_NM",LCD_NM[0][0].Name)
for i in LCD_CM:
for ii in i:
FreeCAD.ActiveDocument.removeObject(ii.Name)
for i in LCD_NM:
for ii in i:
prf("del ok..!")
except:
prf("DELERROR")
close()
def getobj(self):# sel
self.sg1 = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
ma = coin.SoBaseColor()
ma.rgb = (1,0,0)
self.coords1 = coin.SoCoordinate3()
self.lines1 = coin.SoIndexedLineSet()
self.no1 = coin.SoSeparator()
self.no1.addChild(self.coords1)
self.no1.addChild(ma)
self.no1.addChild(self.lines1)
self.sg1.addChild(self.no1)
def aline(self):# a line
self.sg2 = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
ma.rgb = (0,0,1)
self.coords2 = coin.SoCoordinate3()
self.lines2 = coin.SoIndexedLineSet()
self.no2 = coin.SoSeparator()
self.no2.addChild(self.coords2)
self.no2.addChild(ma)
self.no2.addChild(self.lines2)
self.sg2.addChild(self.no2)
def setupUi(self):
widget1 = QtGui.QWidget()
#widget1.setWindowTitle(QtGui.QApplication.translate("Form", "3D Stretch", None,QtGui.QApplication.UnicodeUTF8))
widget1.setWindowTitle(QtGui.QApplication.translate("Form", "3D Stretch", None))
self.layout = QtGui.QGridLayout(widget1)
self.layout.setSpacing(5)
self.layout.setColumnMinimumWidth(0,10)
self.form = [widget1]
self.getK = QtGui.QPushButton(widget1)
self.getK.setObjectName(_fromUtf8("getK"))
self.layout.addWidget(self.getK,1,0)
self.OK = QtGui.QPushButton(widget1)
self.OK.setObjectName(_fromUtf8("OK"))
self.layout.addWidget(self.OK,6,1)
self.label1 = QtGui.QLabel(widget1)
self.label1.setObjectName(_fromUtf8("label1"))
self.layout.addWidget(self.label1,2,0)
self.DCL1 = QtGui.QLineEdit(widget1)
self.DCL1.setObjectName(_fromUtf8("DCL1"))
self.layout.addWidget(self.DCL1,2,1)
self.label2 = QtGui.QLabel(widget1)
self.label2.setObjectName(_fromUtf8("label2"))
self.layout.addWidget(self.label2,3,0)
self.label = QtGui.QLabel(widget1)
self.label.setObjectName(_fromUtf8("label"))
self.layout.addWidget(self.label,5,0)
self.DCL12 = QtGui.QLineEdit(widget1)
self.DCL12.setObjectName(_fromUtf8("DCL12"))
self.layout.addWidget(self.DCL12,5,1)
self.DCL2 = QtGui.QLineEdit(widget1)
self.DCL2.setObjectName(_fromUtf8("DCL2"))
self.layout.addWidget(self.DCL2,3,1)
self.label3 = QtGui.QLabel(widget1)
self.label3.setObjectName(_fromUtf8("label3"))
self.layout.addWidget(self.label3,4,0)
self.label4 = QtGui.QLabel(widget1)
self.label4.setObjectName(_fromUtf8("label4"))
self.layout.addWidget(self.label4,6,0)
self.label5 = QtGui.QLabel(widget1)
self.label5.setObjectName(_fromUtf8("label5"))
self.layout.addWidget(self.label5,8,0)
self.label9 = QtGui.QLabel(widget1)
self.label9.setObjectName(_fromUtf8("label9"))
self.layout.addWidget(self.label9,9,0)
self.DCL3 = QtGui.QLineEdit(widget1)
self.DCL3.setObjectName(_fromUtf8("DCL3"))
self.layout.addWidget(self.DCL3,4,1)
QtCore.QObject.connect(self.OK, QtCore.SIGNAL("clicked()"), self.CKDS)
QtCore.QObject.connect(self.getK, QtCore.SIGNAL("clicked()"), self.getKK)
QtCore.QObject.connect(self.DCL12, QtCore.SIGNAL(_fromUtf8("editingFinished()")), self.norgetpos)
self.DCL1.setText("0.00")
self.DCL2.setText("0.00")
self.DCL3.setText("0.00")
self.DCL12.setText("0")
self.DCL1.setEnabled(False)
self.DCL2.setEnabled(False)
self.DCL3.setEnabled(False)
self.label.setText(QtGui.QApplication.translate("Form", "Distance:", None))
self.label1.setText(QtGui.QApplication.translate("Form", "X Distance:", None))
self.label2.setText(QtGui.QApplication.translate("Form", "Y Distance:", None))
self.label3.setText(QtGui.QApplication.translate("Form", "Z Distance:", None))
self.label9.setText(QtGui.QApplication.translate("Form", "pls sel obj", None))
self.OK.setText(QtGui.QApplication.translate("reobsel", "move", None))
self.getK.setText(QtGui.QApplication.translate("reobsel", "restart", None))
def CKDS(self):
global LCD_CM,LCD_NM,SSCM,ONMIDOBJ
if LCD_CM == LCD_NM == []: return(errorDialog("please selection obj first!"))
prf("GOGOGO")
x=float(self.DCL1.text())
y=float(self.DCL2.text())
z=float(self.DCL3.text())
mov = FreeCAD.Vector(x,y,z)
FreeCAD.ActiveDocument.openTransaction("3D Stretch-move") # undo
prf('ONMIDOBJ',ONMIDOBJ)
for i in ONMIDOBJ:# move!
Draft.move(i,mov,copy=False)
ssobj(LCD_CM,LCD_NM,mov) # stretch!
self.reob()
def getKK(self): # close and open
self.reob()
showup()
def norgetpos(self):
global MD
d=float(self.DCL12.text())
cd = MD.normalize()*d
prf('cd',cd)
self.DCL1.setText(str(round(float(cd[0]),4)))
self.DCL2.setText(str(round(float(cd[1]),4)))
self.DCL3.setText(str(round(float(cd[2]),4)))
def isBoxIntersection(s1,s2):
b1=s1.BoundBox
b2=s2.BoundBox
if b1.intersect(b2):
prf("isBoxIntersection True!!!!!!")
return(True)
elif b2.closestPoint(b1.Center).sub(b1.closestPoint(b2.Center)).Length < 0.0005:
return(True)
else:
prf("isBoxIntersection False")
return(False)
def cutobj(a1=[],a2=[],a3=[],a4=[]): # give 4 vec ... make a ..Shell ... cut obj ... return 2 list...
global name,lcolor,pcolor,scolor,mygroup,commonFace,FACELIST,DELII,ONMIDOBJ
DELII = []
prf('p1 = FreeCAD.Vector('+str(a1[0])+','+str(a1[1])+','+str(a1[2])+')')
prf('p2 = FreeCAD.Vector('+str(a2[0])+','+str(a2[1])+','+str(a2[2])+')')
prf('p3 = FreeCAD.Vector('+str(a3[0])+','+str(a3[1])+','+str(a3[2])+')')
prf('p4 = FreeCAD.Vector('+str(a4[0])+','+str(a4[1])+','+str(a4[2])+')')
if a1==a2==a3==a4==[]:
a1=FreeCAD.Vector(10,0,0)
a2=FreeCAD.Vector(-10,20,0)
a3=FreeCAD.Vector(10,30,0)
a4=FreeCAD.Vector(30,0,0)
shape=Part.Face(Part.makePolygon([a1,a2,a3,a4], True)) # shape
nor = shape.normalAt(0,0) # nor
dd = 200 # nor**
v1po = a1+nor*dd
v2po = a2+nor*dd
v3po = a3+nor*dd
v4po = a4+nor*dd
v1ne = a1-nor*dd
v2ne = a2-nor*dd
v3ne = a3-nor*dd
v4ne = a4-nor*dd
shape1=Part.Face(Part.makePolygon([v1po,v2po,v3po,v4po], True))
shape2=Part.Face(Part.makePolygon([v1ne,v2ne,v3ne,v4ne], True))
shape3=Part.Face(Part.makePolygon([v1po,v2po,v2ne,v1ne], True))
shape4=Part.Face(Part.makePolygon([v2po,v3po,v3ne,v2ne], True))
shape5=Part.Face(Part.makePolygon([v3po,v4po,v4ne,v3ne], True))
shape6=Part.Face(Part.makePolygon([v1po,v4po,v4ne,v1ne], True))
shape_list = [shape1,shape2,shape3,shape4,shape5,shape6]
shell_shape=Part.Shell([shape1,shape5,shape3,shape4,shape6,shape2])
BOXSHAPE = Part.makeSolid(shell_shape)
shellPt = Part.Vertex(shell_shape.CenterOfMass)
shape_sum = 0
cutobj = None
commonFace = None
mygroup = []
FACELIST = []
ONMIDOBJ = []
NUM=1
NUM1=len(FreeCAD.ActiveDocument.Objects)
bar_showup()
for i in FreeCAD.ActiveDocument.Objects: # all obj
QQ=0
setvalue(NUM*100/NUM1)
NUM+=1
if QQ == 0:
if FreeCADGui.ActiveDocument.getObject(i.Name).Visibility == True:
try:
for j in shape_list:
FreeCAD.Console.PrintMessage('\ni:'+str(i.Name)+' j:'+str(j)+' => '+str(len(i.Shape.common(j).Faces)))
if len(i.Shape.common(j).Faces) >= 1:
commonFace = i.Shape.common(j).Faces # Face
cutobj = i
objbaseshape = j
shape_sum += 1
prf('objName',cutobj.Name)
TRA = FreeCADGui.ActiveDocument.getObject(cutobj.Name).Transparency # get Transparency
scolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).ShapeColor # get shape color
lcolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).LineColor # get line color
pcolar=FreeCADGui.ActiveDocument.getObject(cutobj.Name).PointColor # get point locor
try:
C_GRP = cutobj.GROUP
C_ID = cutobj.ID
except:
C_GRP = []
C_ID = []
prf("NO~~~group id")
if cutobj.InList > 0: # get group
groupname = cutobj.InList[0].Name
mygroup = FreeCAD.ActiveDocument.getObject(groupname)
name = cutobj.Label # get name
prf("Transparency",TRA)
prf('scolar',scolar)
prf('lcolar',lcolar)
prf('pcolar',pcolar)
prf('mygroup',mygroup)
prf('name',name)# cut)obj Base_face common_face Transparency shape.. point line shape group group id
FACELIST.append([i,j,commonFace,TRA,scolar,lcolar,pcolar,mygroup,name,C_GRP,C_ID])
try: # find obj in mid
if i.Shape.common(BOXSHAPE).Area == i.Shape.Area: #in mid
ONMIDOBJ.append(i)
prf('Area SAME')
else:
prf('Area NOT SAME . . . ! ')
except:
prf('MID FIND ERROR...')
except: prf('\nNo Shape.')
if shape_sum == 0:
return(errorDialog("GET NO OBJECTS!"))
#find GROUP
C_CM=[]
C_NM=[]
CMOBJLIST = []
NMOBJLIST = []
NUM=1
NUM1=len(FACELIST)
bar_showup()
for i in FACELIST: # cut)obj Base_face common_face
NUM+=1
# i[0] = cutobj
# i[1] = objbaseshape
# i[2] = commonFace
objbase = mkObj(i[1])
objnor = commonFace[0].normalAt(0,0) # obj nor
#Extrude..
EXT = FreeCAD.ActiveDocument.addObject("Part::Extrusion","Extrude")
EXT.Base = objbase
EXT.Dir = objnor*0.0001*-1
EXT.Solid = (True)
FreeCAD.ActiveDocument.recompute()
#CUT
mycut = FreeCAD.ActiveDocument.addObject("Part::Cut","Cut")
mycut.Base = i[0]
mycut.Tool = EXT
DOW = Draft.downgrade([mycut],delete=True)
prf('DOW',DOW ) # cut obj
T_CM=[]
T_NM=[]
for ii in DOW[0]:
prf('common der Face:',len(BOXSHAPE.common(ii.Shape).Solids))
if len(BOXSHAPE.common(ii.Shape).Solids) ==1:
T_CM.append(ii) # MOVE
prf("MOVE")
else:
T_NM.append(ii)# NO MOVE
prf("NO MOVE")
C_CM.append(T_CM)
C_NM.append(T_NM)
for ii in DOW[0]:
FreeCADGui.ActiveDocument.getObject(ii.Name).Transparency = i[3] # give Transparency
FreeCADGui.ActiveDocument.getObject(ii.Name).ShapeColor = i[4] # give shape color
FreeCADGui.ActiveDocument.getObject(ii.Name).LineColor = i[5] # give line color
FreeCADGui.ActiveDocument.getObject(ii.Name).PointColor = i[6] # give point locor
prf('del objbase',objbase.Name)
FreeCAD.ActiveDocument.removeObject(objbase.Name)
#~ prf("i[0].Name",i[0].Name)
DELII.append(i[0].Name) # find the objs will stretch
prf("EXT.Name",EXT.Name)
FreeCAD.ActiveDocument.removeObject(EXT.Name) # remove
prf("C_CM",C_CM)
prf("C_NM",C_NM)
close()
return(C_CM,C_NM)
def ssobj(CO_CM,CO_NM,MOV):
prf("FACELIST",FACELIST)
num=0
DELLIST=[]
KED = 0
LENN = MOV.Length
LEN = MOV.Length+0.0015
objnor = MOV.normalize() # obj nor
MMOV = objnor*LENN
bar_showup()
NUM=1
NUM1=len(FACELIST)
for ii in FACELIST: # N [ [obj,obj,[face,face,face],tra,pc,lc,sc,group,name,grp,id] , [...] , [...] , [...] ]
NUM+=1
CLOUD9=[] # obj need to Fuse
TPA=[]
for i in ii[2]:# commonface
TPA.append(mkObj(i))
AEXT = FreeCAD.ActiveDocument.addObject("Part::Extrusion","Extrude") # Face __ Extrude
AEXT.Base = TPA[-1]
AEXT.Dir = objnor*(LEN)
AEXT.Solid = (True)
for j in CO_NM[num]: # Judge cut or fuse
if AEXT.Shape.common(j.Shape).Area > 0.1:
KED = 1
CLOUD9.append(AEXT)
Draft.move(AEXT,objnor*-0.0005,copy=False)#stretch obj avoid ..0.0005..
# CM obj move ..
Draft.move(CO_CM[num],MMOV,copy=False)
prf('MOV',MOV)
if KED == 1: # cut
prf("cut")
if len(CLOUD9) > 1:
MuCut = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","myEXXXX")
MuCut.Shapes = CLOUD9
else:
MuCut = CLOUD9[0]
MuCut.Label = 'myEXXXX'
DELLIST.append(MuCut.Name)
if len(CO_NM[num]) > 1: # CUT BASE
SECut = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","CUTBAS")
SECut.Shapes = CO_NM[num]
else:
SECut = CO_NM[num][0]
SECut.Label = 'CUTBASE'
DELLIST.append(SECut.Name)
C9Cut = FreeCAD.ActiveDocument.addObject("Part::Cut","Cut") #cut!
C9Cut.Base = SECut
C9Cut.Tool = MuCut
DELLIST.append(C9Cut.Name)
Draft.move(C9Cut,objnor*-0.0012,copy=False)
COO = [] # fuse_obj
COO.append(C9Cut)
for k in CO_CM[num]:
COO.append(k)
Mu = FreeCAD.ActiveDocument.addObject("Part::MultiFuse","Fusion")
Mu.Shapes = COO
#~ if ii [9] <> []:
#~ from GsCad.c1_std import addpro
#~ Mui = addpro.addpro(Mui,ii[8],ii[9],ii[10],' ',[[0,0,0]],ii[5],ii[6],ii[4])[0]
#~ else:
Mui = mkObj(Mu.Shape)
Mui.Label = ii[8] #name
if ii[7]: mygroup.addObject(Mui) #grp
FreeCADGui.ActiveDocument.getObject(Mui.Name).Transparency = ii[3] # Transparency
FreeCADGui.ActiveDocument.getObject(Mui.Name).ShapeColor = ii[4] # shape
FreeCADGui.ActiveDocument.getObject(Mui.Name).LineColor = ii[5] # line
FreeCADGui.ActiveDocument.getObject(Mui.Name).PointColor = ii[6] # point
DELLIST.append(Mu.Name) # fuse_obj
for iii in CO_NM[num]:
CLOUD9.append(iii)
for iii in CO_CM[num]:
CLOUD9.append(iii)
for ww in CLOUD9:
DELLIST.append(ww.Name)
for ww in TPA:
DELLIST.append(ww.Name) # face
num+=1
else: # stretch
prf("stretch")
for i in CO_NM[num]:
CLOUD9.append(i)
for i in CO_CM[num]:
CLOUD9.append(i)
Mu.Shapes = CLOUD9
#~ if ii [9] <> []:
#~ else:
if ii[7]: mygroup.addObject(Mui) # grp
DELLIST.append(Mu.Name) # fuse obj
for ww in TPA:
for ww in CLOUD9:
DELLIST.append(ww.Name) # face obj_A obj_B
num+=1
close()
prf("DELLIST",DELLIST)
for i in DELLIST:
try:
FreeCAD.ActiveDocument.removeObject(i)
except:
prf("DEL repeat!")
prf("DELII",DELII)
for i in DELII:
try: FreeCAD.ActiveDocument.removeObject(i)
except: prf("DELII no",i)
def showup():
global reobsel
reobsel = Ui_reobsel()
FreeCADGui.Control.showDialog(reobsel)
def isPtOnEdge(pt,edge) : # find is point on edge
v = Part.Vertex(pt)
d = v.distToShape(edge)
if d:
if d[0] < 0.01:
return True
return False
def mkObj(shape): # make obj
obj = FreeCAD.ActiveDocument.addObject("Part::Feature",'Temp')
obj.Shape = shape
return(obj)
def errorDialog(msg): # message
unicode_str = unicode(msg,'utf-8')
diag = QtGui.QMessageBox(QtGui.QMessageBox.Warning, 'Error MessageBox', unicode_str)
diag.setWindowModality(QtCore.Qt.ApplicationModal)
diag.exec_()
def prf(m,p=0):
if p==0: FreeCAD.Console.PrintMessage('\n'+str(m))
else: FreeCAD.Console.PrintMessage('\n'+str(m)+':'+str(p))
class Ui_Bar():
def setupUi(self, MainWindow):
MainWindow.setObjectName("MainWindow")
MainWindow.resize(240, 138)
self.centralWidget = QtGui.QWidget(MainWindow)
self.centralWidget.setObjectName("centralWidget")
self.progressBar = QtGui.QProgressBar(self.centralWidget)
self.progressBar.setGeometry(QtCore.QRect(10, 40, 211, 23))
self.progressBar.setProperty("value", 0)
self.progressBar.setObjectName("progressBar")
self.label = QtGui.QLabel(self.centralWidget)
self.label.setGeometry(QtCore.QRect(30, 10, 267, 17))
self.label.setObjectName("label")
MainWindow.setCentralWidget(self.centralWidget)
self.menuBar = QtGui.QMenuBar(MainWindow)
self.menuBar.setGeometry(QtCore.QRect(0, 0, 240, 25))
self.menuBar.setObjectName("menuBar")
MainWindow.setMenuBar(self.menuBar)
self.mainToolBar = QtGui.QToolBar(MainWindow)
self.mainToolBar.setObjectName("mainToolBar")
MainWindow.addToolBar(QtCore.Qt.TopToolBarArea, self.mainToolBar)
self.statusBar = QtGui.QStatusBar(MainWindow)
self.statusBar.setObjectName("statusBar")
MainWindow.setStatusBar(self.statusBar)
self.retranslateUi(MainWindow)
QtCore.QMetaObject.connectSlotsByName(MainWindow)
screen=QtGui.QDesktopWidget().screenGeometry()
size=MainWindow.geometry()
MainWindow.move((screen.width()-size.width())/2, (screen.height()-size.height())/2)
def retranslateUi(self, MainWindow):
MainWindow.setWindowTitle(QtGui.QApplication.translate("MainWindow", "A progress bar", None))
self.label.setText(QtGui.QApplication.translate("MainWindow", "please wait...", None))
def close():
bbbarui.close()
def setvalue(v):
Barui.progressBar.setProperty("value", v)
bbbarui = QtGui.QMainWindow()
Barui = Ui_Bar()
def bar_showup():
Barui.setupUi(bbbarui)
bbbarui.show()
00:44:41 <class 'AttributeError'>
00:44:41 Traceback (most recent call last):
00:44:41 File "/home/watsug/Documents/freeCAD/stretch_u8.py", line 50, in action
00:44:41 self.point = FreeCADGui.Snapper.snap(info["Position"],lastpoint,info["ShiftDown"],info["ShiftDown"],True) #snap
00:44:41 AttributeError: module 'FreeCADGui' has no attribute 'Snapper'
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.22882 (Git)
Build type: Unknown
Hash: aebf568eaec7f62b95b29037851c04d1a6f65d47
Python version: 3.8.5
Qt version: 5.12.8
