glider workbench
freecad-heini-1
Re: glider workbench
Post by freecad-heini-1 »
Hi looo,
what a nice workbench. Please can you explain me how to install it on Ubuntu.
Better to place your workbench into the addon-manager, if possible.
Thank you so much and best regards
Wilfried
looo
Post by looo »
no, it's not yet possible to install this workbench easily. This is mostly because of difficult dependencies. We are working towards an easy install with pip. Ideally installing the whole set of packages necessary for the workbench will look like this:
pip install freecad-glider
Currently we are using conda to install all the libraries. Conda is similar to pip but allows to install more difficult libraries (eg.: FreeCAD and occt) As packaging is really a time-intensive work, we are concentrating on conda and pip. All other solutions like (apt, yum...) are not suited for such a small projects.
I always said that the add-on-manager of freecad is a solution for a solved problem. But the problem why freecad couldn't use the standard python package-manager was a bad design of the workbenches. This should be solved with the new-style modules, and therefor the standard python package manager (pip) can be used. Hopefully we can integrate pip into the addon-manager for the 0.18 version.
kerekesrobert
Post by kerekesrobert »
Hi Looo! I could not install the glider filebench. It would be good to see a youtube video about its installation. Thanks, Robi
jmaustpc
Post by jmaustpc »
kerekesrobert wrote: Tue Dec 19, 2017 6:39 pm Hi Looo! I could not install the glider filebench. It would be good to see a youtube video about its installation. Thanks, Robi
Please always post your version data in the manner explain in the forum rules link above the help forum.
I deleted your duplicate post. Please post again if I missed something.
looo
Post by looo »
I recently learned that pip can install from github. So this will simplify the installation a bit. this should work:
pip install https://github.com/booya-at/OpenGlider/archive/singleskin.zip
pip install https://github.com/booya-at/freecad-glider/archive/singleskin.zip
meshpy will be compiled, so this will take some minutes...
freecad-heini-1
Error message on Xubuntu 16.04:
Collecting https://github.com/booya-at/freecad-glider/archive/singleskin.zip
  HTTP error 404 while getting https://github.com/booya-at/freecad-glider/archive/singleskin.zip
  Could not install requirement https://github.com/booya-at/freecad-glider/archive/singleskin.zip because of error 404 Client Error: Not Found for url: https://github.com/booya-at/freecad-glider/archive/singleskin.zip
Could not install requirement https://github.com/booya-at/freecad-glider/archive/singleskin.zip because of HTTP error 404 Client Error: Not Found for url: https://github.com/booya-at/freecad-glider/archive/singleskin.zip for URL https://github.com/booya-at/freecad-glider/archive/singleskin.zip
kerekesrobert
looo
Post by looo »
sorry. I think there was a typo:
pip install https://github.com/booya-at/freecad_glider/archive/singleskin.zip
freecad-heini-1
I tried to install and received an error at the end of the procedure:
Collecting https://github.com/booya-at/freecad_glider/archive/singleskin.zip
  Downloading https://github.com/booya-at/freecad_glider/archive/singleskin.zip
     \ 1.1MB 1.0MB/s
Requirement already satisfied: openglider in ./.local/lib/python2.7/site-packages (from freecad-glider==0.1.2)
Requirement already satisfied: ezodf in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: pyexcel in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: pyexcel-ods in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: svgwrite in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: numpy in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: ezdxf in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: meshpy in ./.local/lib/python2.7/site-packages (from openglider->freecad-glider==0.1.2)
Requirement already satisfied: pyexcel-io>=0.5.3 in ./.local/lib/python2.7/site-packages (from pyexcel->openglider->freecad-glider==0.1.2)
Requirement already satisfied: lml==0.0.1 in ./.local/lib/python2.7/site-packages (from pyexcel->openglider->freecad-glider==0.1.2)
Requirement already satisfied: texttable>=0.8.2 in ./.local/lib/python2.7/site-packages (from pyexcel->openglider->freecad-glider==0.1.2)
Requirement already satisfied: odfpy>=1.3.3 in ./.local/lib/python2.7/site-packages (from pyexcel-ods->openglider->freecad-glider==0.1.2)
Requirement already satisfied: pyparsing>=2.0.1 in ./.local/lib/python2.7/site-packages (from svgwrite->openglider->freecad-glider==0.1.2)
Requirement already satisfied: pytools>=2011.2 in ./.local/lib/python2.7/site-packages (from meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: six in ./.local/lib/python2.7/site-packages (from meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: pytest>=2 in ./.local/lib/python2.7/site-packages (from meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: appdirs>=1.4.0 in ./.local/lib/python2.7/site-packages (from pytools>=2011.2->meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: decorator>=3.2.0 in ./.local/lib/python2.7/site-packages (from pytools>=2011.2->meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: attrs>=17.2.0 in ./.local/lib/python2.7/site-packages (from pytest>=2->meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: pluggy<0.7,>=0.5 in ./.local/lib/python2.7/site-packages (from pytest>=2->meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: funcsigs; python_version < "3.0" in ./.local/lib/python2.7/site-packages (from pytest>=2->meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: setuptools in ./.local/lib/python2.7/site-packages (from pytest>=2->meshpy->openglider->freecad-glider==0.1.2)
Requirement already satisfied: py>=1.5.0 in ./.local/lib/python2.7/site-packages (from pytest>=2->meshpy->openglider->freecad-glider==0.1.2)
Installing collected packages: freecad-glider
  Running setup.py install for freecad-glider ... error
    Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-srIlq5-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-ChhKYf-record/install-record.txt --single-version-externally-managed --compile:
    running install
    running build
    running build_py
    creating build
    creating build/lib.linux-x86_64-2.7
    creating build/lib.linux-x86_64-2.7/freecad
    copying freecad/__init__.py -> build/lib.linux-x86_64-2.7/freecad
    creating build/lib.linux-x86_64-2.7/freecad/freecad_glider
    copying freecad/freecad_glider/init_gui.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider
    copying freecad/freecad_glider/__init__.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider
    copying freecad/freecad_glider/profiling.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider
    copying freecad/freecad_glider/glider_commands.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider
    copying freecad/freecad_glider/init.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider
    copying freecad/freecad_glider/glider_metadata.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider
    creating build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/_tools.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/merge_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/airfoil_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/panel_method.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/color_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/aoa_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/_glider.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/features.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/arc_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/table.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/pivy_primitives.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/line_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/pivy_primitives_new_new.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/shape_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/__init__.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/design_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/ballooning_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    copying freecad/freecad_glider/tools/cell_tool.py -> build/lib.linux-x86_64-2.7/freecad/freecad_glider/tools
    running egg_info
    creating freecad_glider.egg-info
    writing requirements to freecad_glider.egg-info/requires.txt
    writing freecad_glider.egg-info/PKG-INFO
    writing top-level names to freecad_glider.egg-info/top_level.txt
    writing dependency_links to freecad_glider.egg-info/dependency_links.txt
    writing manifest file 'freecad_glider.egg-info/SOURCES.txt'
    reading manifest file 'freecad_glider.egg-info/SOURCES.txt'
    running install_lib
    creating /usr/local/lib/python2.7/dist-packages/freecad
    error: could not create '/usr/local/lib/python2.7/dist-packages/freecad': Permission denied
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-srIlq5-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-ChhKYf-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-srIlq5-build/
I tried to install with sudo because of permission problem and received this error message:
The directory '/home/blabla/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/blabla/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
looo
Post by looo »
thanks for testing. I have updated freecad_glider. pip has a --upgrade option, but this will pull all the dependencies from pip. This is not good, as it will replace system version which are shipped with the distro. Better simple uninstall and install the package:
pip uninstall freecad_glider
