glider workbench
looo
Re: glider workbench
Postby looo » Tue Dec 26, 2017 8:15 pm
I forget to mention that pivy has to be updated. But the version we use is fully compatible with the rest of FreeCAD. Again this can be done by directly installing from github.
pip install https://github.com/FreeCAD/pivy/archive/master.zip
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
freecad-heini-1
Postby freecad-heini-1 » Tue Dec 26, 2017 9:03 pm
Collecting https://github.com/FreeCAD/pivy/archive/master.zip
  Downloading https://github.com/FreeCAD/pivy/archive/master.zip
     | 7.1MB 26.4MB/s
Installing collected packages: Pivy
  Found existing installation: Pivy 0.5.0
    DEPRECATION: Uninstalling a distutils installed project (Pivy) has been deprecated and will be removed in a future version. This is due to the fact that uninstalling a distutils project will only partially uninstall the project.
looo
Postby looo » Tue Dec 26, 2017 9:33 pm
Does this stop the installation or is it only a warning? The command should compile pivy, so you have to wait for about 5-10 minutes.
Varis
Postby Varis » Tue Dec 26, 2017 10:39 pm
After running
pip install https://github.com/booya-at/freecad_glider/archive/singleskin.zip
I get the following:
$ pip install https://github.com/FreeCAD/pivy/archive/master.zip
  Downloading https://github.com/FreeCAD/pivy/archive/master.zip (7.1MB)
    100% |████████████████████████████████| 7.1MB 156kB/s
  Running setup.py install for Pivy ... error
    Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-QtDJxs-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-z2Jbuc-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
    running install
    running build
                                _____
                         __/  __       \
                        /  \ /  \       |    ___
                      .-\__/ \__/       |      \_/\_/__..._
              _...---'-.                /   _              '.
            | `      `          .'       |     `-._         /
            \                 .'         |     ,_  `--....-'
             `.           __.' ,         |     / /`'''`
               `'-.____.-' /  /,         |    / /
                     `-.__.'|    \      |   |  |-.
                        _.._|     |     /   |  |  `'.
             '.  `'.            `-._     '.__  '-._____.'--'''''--.
               '-.  `'--._          `.__     `';----`              \
                     `'-..,_ `-.         `'-.                     /
                                ~~~ HISSSSSSSSSS ~~~
                               Welcome to Pivy 0.6.3!
                     Building Pivy has never been so much fun!
    Platform...linux2
    Python version...2.7.14
    Checking for swig...
    '/usr/bin/swig'
    Checking for SWIG version...
    3.0.10
    Warning: Pivy has only been tested with the following SWIG versions: 1.3.31 1.3.33 1.3.35 1.3.40.
    Checking for coin-config...
    not found.
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-QtDJxs-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-z2Jbuc-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-QtDJxs-build/
seems that it is missing dependencies and those are not being managed.
Anyway, I installed pivy with the OS dependency manager (apt) and running
$ pip install https://github.com/booya-at/freecad_glider/archive/singleskin.zip
succeeded.
Collecting https://github.com/booya-at/freecad_glider/archive/singleskin.zip
  Downloading https://github.com/booya-at/freecad_glider/archive/singleskin.zip
     \ 1.1MB 964kB/s
Collecting openglider (from freecad-glider==0.1.2)
  Downloading OpenGlider-0.1.tar.gz (120kB)
    100% |████████████████████████████████| 122kB 1.1MB/s
Collecting dxfwrite (from openglider->freecad-glider==0.1.2)
  Downloading dxfwrite-1.2.1-py2.py3-none-any.whl (84kB)
    100% |████████████████████████████████| 92kB 2.0MB/s
Collecting ezodf2 (from openglider->freecad-glider==0.1.2)
  Downloading ezodf2-0.2.10.tar.gz
Collecting svgwrite (from openglider->freecad-glider==0.1.2)
  Using cached svgwrite-1.1.11-py2.py3-none-any.whl
Collecting numpy (from openglider->freecad-glider==0.1.2)
  Using cached numpy-1.13.3-cp27-cp27mu-manylinux1_x86_64.whl
Collecting ezdxf (from openglider->freecad-glider==0.1.2)
  Using cached ezdxf-0.8.2-py2.py3-none-any.whl
Collecting lxml (from ezodf2->openglider->freecad-glider==0.1.2)
  Downloading lxml-4.1.1-cp27-cp27mu-manylinux1_x86_64.whl (5.6MB)
    100% |████████████████████████████████| 5.6MB 217kB/s
Collecting pyparsing>=2.0.1 (from svgwrite->openglider->freecad-glider==0.1.2)
  Using cached pyparsing-2.2.0-py2.py3-none-any.whl
Building wheels for collected packages: openglider, ezodf2
  Running setup.py bdist_wheel for openglider ... done
  Stored in directory: /home/tadas/.cache/pip/wheels/26/8b/13/a3b66eb57bdf26427677866fcdd3f5ebc51940cf886faf0fb8
  Running setup.py bdist_wheel for ezodf2 ... done
  Stored in directory: /home/tadas/.cache/pip/wheels/98/e0/43/17a8fea7bcfc44bd86f792e7890c93e6f298e159306beae903
Successfully built openglider ezodf2
Installing collected packages: dxfwrite, lxml, ezodf2, pyparsing, svgwrite, numpy, ezdxf, openglider, freecad-glider
  Running setup.py install for freecad-glider ... done
Successfully installed dxfwrite-1.2.1 ezdxf-0.8.2 ezodf2-0.2.10 freecad-glider-0.1.2 lxml-4.1.1 numpy-1.13.3 openglider-0.1 pyparsing-2.2.0 svgwrite-1.1.11
I cannot find the glider workbench in the FreeCAD workbench list though.
OS: Ubuntu 17.10
FreeCAD 0.16
Fresh OS VM for testing the glider workbench.
What could be the issue that the glider workbench is not showing up in the list?
Thanks!
jmaustpc
Postby jmaustpc » Wed Dec 27, 2017 9:24 am
FreeCAD 0.16
It says here
https://github.com/looooo/FCGear
That you need FreeCAD version greater than 0.16. I don't know if looo means "greater or equal to" or litterally "greater". If the second then you need FreeCAD 0.17 the development version.
Perhaps someone could clarify this?
freecad-heini-1
Postby freecad-heini-1 » Wed Dec 27, 2017 10:16 am
looo
Postby looo » Wed Dec 27, 2017 1:15 pm
wrote:What could be the issue that the glider workbench is not showing up in the list?
jmaustpc wrote: That you need FreeCAD version greater than 0.16. I don't know if looo means "greater or equal to" or litterally "greater". If the second then you need FreeCAD 0.17 the development version.
0.16 doesn't support pip installed workbenches. While there is a branch which is written to work with 0.16, I don't think it makes any sense to support older releases of FreeCAD.
UI-file doesn't exist
strange it should be installed with the latest version. Have you uninstalled and installed the freecad_glider library? there should be a file freecad/freecad_glider/ui/preferences.ui
Mx74
Postby Mx74 » Fri Mar 23, 2018 11:51 am
I'm interested in this workbench, but I struggle with the installation process.
I have freecad-daily.
As explained I tried to install your version of Pivy, but I got the following error:
 Platform...linux2
    Python version...2.7.12
    '/usr/bin/swig'
    3.0.8
    calling: cmake .
    error: [Errno 2] No such file or directory
  Rolling back uninstall of Pivy
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-ZpBwhF-build/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-AVSFtD-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-ZpBwhF-build/
I try to install anyway,
but then while installing OpenGlider , I have a pb with MeshPy:
building 'meshpy._triangle' extension
    creating build/temp.linux-x86_64-2.7
    creating build/temp.linux-x86_64-2.7/src
    creating build/temp.linux-x86_64-2.7/src/cpp
    x86_64-linux-gnu-gcc -pthread -fwrapv -Wall -O1 -DNDEBUG -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DEXTERNAL_TEST=1 -DANSI_DECLARATORS=1 -DTRILIBRARY=1 -Isrc/cpp -I/usr/include/python2.7 -c src/cpp/wrap_triangle.cpp -o build/temp.linux-x86_64-2.7/src/cpp/wrap_triangle.o
    src/cpp/wrap_triangle.cpp:2:28: fatal error: boost/python.hpp: Aucun fichier ou dossier de ce type
    compilation terminated.
    error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-01lMbB/meshpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-gqLiJF-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-01lMbB/meshpy/
And as a result, when I try to open the Glider workbench in FC, "cannot import name mesh"
looo
Postby looo » Fri Mar 23, 2018 12:03 pm
regarding pivy:
can you create an issue @https://github.com/FreeCAD/pivy/issues
+ adding as much information from your system as possible ;)
regarding meshpy:
this is another very difficult library. I will add a python replacement to openglider to get it working without meshpy. But the performance will suffer a bit.
Mx74
Postby Mx74 » Tue Mar 27, 2018 6:26 am
Following you advice on pivy issues, I finally installed pivy 0.6.2.
Then install of freecad seems to works, I can see the workbench in FC, but when I click on it, it says "cannot import name mesh".
In the termnal I have the following:
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/init_gui.py", line 77, in Initialize
    from . import tools
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/tools/__init__.py", line 13, in <module>
    from . import _glider as glider
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/tools/_glider.py", line 8, in <module>
    from openglider import mesh
