glider workbench
looo
Re: glider workbench
Post by looo »
can ou try the following in the freecad console and post the output here:
import openglider
import os
dir = os.path.dirname(openglider.__file__)
os.listdir(dir)
Mx74
Post by Mx74 »
Output:
['lines', 'vector', 'glider', '__init__.pyc', 'freecad', 'graphics', '__init__.py', 'plots', 'config.py', 'utils', 'jsonify', 'config.pyc', 'airfoil']
looo
Post by looo »
ah I guess you installed the master-branch of openglider, or maybe some old pypi package.
Please try:
pip install https://github.com/booya-at/OpenGlider/archive/develop.tar.gz
Mx74
Post by Mx74 »
Ok, I just tried, but :
creating build/temp.linux-x86_64-2.7/src/cpp
  x86_64-linux-gnu-gcc -pthread -fwrapv -Wall -O1 -DNDEBUG -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-l1RrwO/python2.7-2.7.14=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DEXTERNAL_TEST=1 -DANSI_DECLARATORS=1 -DTRILIBRARY=1 -Isrc/cpp -I/usr/include/python2.7 -c src/cpp/wrap_triangle.cpp -o build/temp.linux-x86_64-2.7/src/cpp/wrap_triangle.o
  src/cpp/wrap_triangle.cpp:2:10: fatal error: boost/python.hpp: Aucun fichier ou dossier de ce type
   #include <boost/python.hpp>
  compilation terminated.
  error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
  Failed building wheel for meshpy
  Running setup.py clean for meshpy
Failed to build meshpy
I guess(hope) it's because of the former install that may cause trouble. Is there a way to clean the previous installation of OpenGlider and freecad_glider, in order to take a good start again?
looo
Post by looo »
The error says, that you have to install boost-python to build meshpy.
sudo apt-get install boost-python
but anyway, I removed meshpy dependency for openglider. So please try again installing openglider.
Mx74
Post by Mx74 »
That's weird.
I tried as you said, but "pip install https://github.com/booya-at/OpenGlider/ ... lop.tar.gz" keeps on trying to install MeshPy, despite you removed it..
I installed Boost (sudo apt-get install python-boost doesn't work for me, but sudo apt-get install boostlib-python-dev-all).
Then everything went fine installing OpenGlider, no more error message.
So it was time to install freecad_glider. No error message.
But then when I launch the workbench in FC a new error message appears:
cannot import name ParametricGlider
  File "/home/max/.local/lib/python2.7/site-packages/freecad/freecad_glider/init_gui.py", line 77, in Initialize
    from . import tools
  File "/home/max/.local/lib/python2.7/site-packages/freecad/freecad_glider/tools/__init__.py", line 13, in <module>
    from . import _glider as glider
  File "/home/max/.local/lib/python2.7/site-packages/freecad/freecad_glider/tools/_glider.py", line 9, in <module>
    from openglider.glider import ParametricGlider
I tried 2 different version of freecad_glider, master or singleskin. Same error.
Sorry for the hassle, newbee inside as you realize... :-)
Oh, I also made the test in the console, output is :
['lines', 'physics', 'glider', '__init__.py', 'freecad', '__init__.pyc', 'utils', 'mesh', 'plots', 'graphics', 'jsonify', 'config.pyc', 'vector', 'config.py', 'airfoil']
Mx74
Post by Mx74 »
I finally did everything as described in the readme of both Openglider and freecad_glider.
Git clone both, installed OpenGlider, linked freecad_glider in Freecad/Mod folder, and it seems to be ok !
No idea why pip installation doesn't work.
I'll start playing with it. Now the real questions will come :-)
Thank you a lot for your time and patience !
Mx74
Post by Mx74 »
Me again...
So the installation seemed to work fine, I can launch the workbench, create a glider.
But most of the menu actions fail.
In the first menu for example, I have only create glider, import and export glider, airfoil, lines, colors that works.
All the rest gives error message.
For example "shape":
super(type, obj): obj must be an instance or subtype of typeRunning the Python command 'ShapeCommand' failed:
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/tools/__init__.py", line 50, in Activated
    Gui.Control.showDialog(self.tool(self.glider_obj))
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/tools/__init__.py", line 200, in tool
    return shape_tool.ShapeTool(obj)
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/tools/shape_tool.py", line 30, in __init__
    self.front_cpc = ControlPointContainer(points, self.view)
  File "/usr/lib/freecad-daily/Mod/freecad/freecad_glider/tools/pivy_primitives.py", line 84, in __init__
    super(ControlPointContainer, self).__init__()
looo
Post by looo »
I guess this is an pivy issue but I have no idea why this is not working for you.
As you say lines are working, can you try the following. It would be strange if this tool work but the shape-tool not...
for moving the selected point you have to press "g".
Mx74
Post by Mx74 »
Yes, it works perfectly. I can move the points, create some new line attachment points, create lines in-between and validate.
The glider is displayed with the change in the lines.
But the others menu I mentioned just show an error and the glider disappears.
