Radial Nurbs
looo
Radial Nurbs
Postby looo » Tue Feb 02, 2016 5:58 pm
Reading about mesh-less fem and radial base function mixing with T-splines leads to this: https://vimeo.com/153939513
No exact geometry is possible with this, but it can be used very flexible. The grid does not have to be quads, triangles... But not useful at all :D
please help with my conda-packaging efforts: https://liberapay.com/looooo/
emills2
Re: Radial Nurbs
Postby emills2 » Tue Feb 02, 2016 6:19 pm
i would think exact geometry is very possible with this, just hard to constrain. Do you plan to pin down the knot vector for the edges?
looo
Re: Radial Nurbs
Postby looo » Tue Feb 02, 2016 7:50 pm
The pinning is one problem. Because the basis funcions are radial and not uv the boarder in the "basis plane" can't be straight to get a straight edge in the mapped plane.
Closed bodies should work and the topology could be as complex as with t-splines. The problem is that cylindrical faces, straight lines ... are difficult to build. Maybe it could be used as a tool for sculpting.
emills2
Re: Radial Nurbs
Postby emills2 » Wed Feb 03, 2016 6:58 am
sounds fun! too much fun for me though :D are you sure there is no mapping to normal basis functions for th edges? that would be really sweet.
triplus
Re: Radial Nurbs
Postby triplus » Wed Feb 03, 2016 9:58 am
Looking good.
If i remember correctly not that long ago one user was asking if FreeCAD would allow him to do sculptures. Tools like seen on the video would be ideal for this task.
Chris_G
Re: Radial Nurbs
Postby Chris_G » Thu Feb 04, 2016 9:50 am
Hi looo,
Wow, how I would love to see that kind of freehand Pole Editing behaviour implemented into FreeCAD curves and surfaces.
Congratulations, it looks great !
Yesterday, I started to give a try at creating a grabbing manipulator, like in Blender, in order to edit curve poles.
Would you share your python script, please ? ( mouse events and coin are such a pain for me ! )
Chris
looo
Re: Radial Nurbs
Postby looo » Thu Feb 04, 2016 12:40 pm
My goal was also to make something similar to blender. ("g" is grab, "x" is delete, "shift" is precise drag)
I have tried this 3 times now and I am still not happy with it. https://github.com/looooo/freecad_glide ... new_new.py
For dragging Markers and Containers are used. The container store all the markers and does all the interactive stuff. There are better methods for the selection available from coin, but I haven't understood this fully.
marker = Marker([[0,0,0]], dynamic=True)
cpc = Container()    # control point container
cpc.addChild(marker)
view = Gui.ActiveDocument.ActiveView
view.getSceneGraph().addChild(cpc)
cpc.register(Gui.ActiveDocument.ActiveView)
callbacks can be added with:
cpc.on_drag.append(function)
cpc.on_drag_release.append(function)
cpc.on_drag_start.append(function)
to disable all interactive stuff do:
cpc.unregister()
The other stuff shown in the video is really simple. I used Eigen matrices wrapped to python to get a fast sparse matrix product. and a coin.SoMesh to display the result.
I have no idea for this, but maybe it is possible. The next thing I would like to try is the mapping of a 3d spher-surface to a closed body. Using spherical basis function on a sphere :D
Chris_G
Re: Radial Nurbs
Postby Chris_G » Thu Feb 04, 2016 4:30 pm
Thanks looo,
That's very interesting.
I think I barely understand how it works.
I will try to use it on a bezier curve edit tool ( and maybe also try to add Blender's X Y and Z axis constraints, as an exercise, to dig in the code ).
Thanks a lot.
Chris
looo
Re: Radial Nurbs
Postby looo » Thu Feb 04, 2016 7:28 pm
 Select all
Sorry this wasn't true. But I have added this now. You can add function which should be called during draging directly to the container or you can add them to the markers.
For the x, y, z dragging you will have to change the way how the new position is calculated. Right now for every step there is calculated a diff vector from the previous mouse position to the current mouse position. If you want the same behaviour like blender, pressing x should bring the moved point to a position on the x-line which starts at the old position when the drag was started. Otherwise the dragging is constrained to the current position of the marker.
I have tried some stuff and it should work this way: https://github.com/looooo/freecad_glide ... 033c07bd5b
Maybe you can try to add also the xy, xz, yz stuff to constrain to a plane.
Chris_G
Re: Radial Nurbs
Postby Chris_G » Thu Feb 04, 2016 10:06 pm
Hi looo,
Yes, I saw. Not that important.
I mainly read the code and tried to understand how it works. Quite a challenge for me.
OK, I noticed that also.
I will look at it. You are a much more advanced coder than I am. What seems to take you minutes to code, would take me hours ...
So ... I learn. And your code is very instructive.
Another blender feature ? I didn't know it ...
Thanks again.
Chris
