kicad StepUp: ECAD MCAD bidirectional collaboration
antoniovazquezblanco
Re: kicad StepUp: ECAD MCAD bidirectional collaboration
Postby antoniovazquezblanco » Tue Oct 23, 2018 4:43 pm
easyw-fc wrote:
Tue Oct 23, 2018 4:28 pm
I can load the fp you tested without any issue...
The problem is when I add a STEP model after opening the FP.
Postby antoniovazquezblanco » Tue Oct 23, 2018 5:01 pm
I have just tested this with an older FC version:
⇢ freecad
FreeCAD 0.17, Libs: 0.17R13543 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
A3 not available
ksuWB.Activated(v 7.8.1)
PoM not present
FC Version 017-13543
no Links support
kicad StepUp version 8.1.0.9
tolerance on vertex applied
applying Materials to Shapes
your home path is /home/anton
export to STEP False
Tabified done !
done!
KISYS3DMOD=/
module_3D_dir=//../
FC Version 017
VBO status False
FootPrint Loader /home/anton/Projects/KiCad/kicad-footprints/Button_Switch_SMD.pretty/SW_SPST_Panasonic_EVQPL_3PL_5PL_PT_A08.kicad_mod
SW_SPST_Panasonic_EVQPL_3PL_5PL_PT_A08_fp
import3DModel
ReadShapeCompoundMode status False
Running the Python command 'ksuToolsImport3DStep' failed:
  File "/home/anton/.FreeCAD/Mod/kicadStepUpMod/kicadStepUpCMD.py", line 359, in Activated
    kicadStepUptools.Import3DModelF()
  File "/home/anton/.FreeCAD/Mod/kicadStepUpMod/kicadStepUptools.py", line 14923, in Import3DModelF
    ImportGui.insert(name, doc.Name)
cannot read STEP file
easyw-fc
Postby easyw-fc » Tue Oct 23, 2018 5:04 pm
No issue on my side ... which is the operation/button you are using to add the STEP file?
Can you open your STEP file without using StepUp?
easyw-fc
Postby easyw-fc » Tue Oct 23, 2018 9:25 pm
Tue Oct 23, 2018 3:45 pm
How can I improve the logging I have provided? Thanks!
I managed to replicate your 'issue'...
If you have downloaded a STEP file from github, you probably have downloaded not the raw file (the real step file) but its links to the GH page...
in this case you get an HTML page containing the STEP file and not the step file itself... then if you try to load in FreeCAD this 'html' step file you get your error log...
for example this:
https://github.com/KiCad/kicad-packages3D/blob/master/Button_Switch_THT.3dshapes/SW_Tactile_SPST_Angled_PTS645Vx31-2LFS.step
and this:
https://github.com/KiCad/kicad-packages3D/raw/master/Button_Switch_THT.3dshapes/SW_Tactile_SPST_Angled_PTS645Vx31-2LFS.step
Then the final error log message make sense:
because you are trying to import a step file parsing an HTML file.
Postby antoniovazquezblanco » Wed Oct 24, 2018 9:21 am
for example this:
and this:
Good catch! I was not using a GH downloaded file but git was doing weird things with LFS files. My file was not generated using the LFS hook in that machine and I don't know why.
It works for me now. Thank you very much!!
BTW your WB is the one I find most useful. I collaborate with KiCad from time to time and I think it will help my workflow.
I have a feature that I would love to see in your WB. My usual workflow is to import a fp to make a step file sit on it. After that I want to export the step + wrl file. If KSU picked up the name of the FP when exporting I wouldn't have to rename it. I am just extremely lazy :roll:
easyw-fc
Postby easyw-fc » Wed Oct 24, 2018 10:06 am
simply copy the FP Label to your STEP Label (removing '_fp') and then export it.
You may check if there are '-' characters inside the Label, because in FP importing those are remapped to '_'
Postby antoniovazquezblanco » Wed Oct 24, 2018 10:09 am
I will do. Thank you!
Szymix13
Postby Szymix13 » Mon Jan 07, 2019 10:46 am
Hi!
I am new here, started working with FC lately, those free mods are totaly awesome guys, thanks :)
Tried to copy project from Kicad using StepUp. When i pick file, the pop up message shows up:
... missing
/home/*****/.var/app/org.freecadweb.FreeCAD/config/FreeCAD/user.kicad_mod
... missing
/home/*****/.var/app/org.freecadweb.FreeCAD/config/FreeCAD/user.conf.kicad_pcb
What should i do?
easyw-fc
Postby easyw-fc » Mon Jan 07, 2019 4:47 pm
... missing
... missing
What should i do?
Hi @Szymix13, what do you mean with 'Tried to copy project from Kicad using StepUp'?
And 'When i pick file, the pop up message shows up:' wich kind of file are you 'picking'?
and what do you mean with 'pick'? You mean 'Open' or 'Import' or whatever?
Szymix13
Postby Szymix13 » Tue Jan 08, 2019 8:04 am
... missing
... missing
What should i do?
Ok, more detalis, sorry :)
I have added Kicad Stepup Workbench to my FreeCAD. I am trying to open a .kicad_pcb file, which is project created entirely in Kicad. After i hit open, first message i see is the one i quoted:
... missing
... missing
I press ok, and i can see a board model, the main body, but nothing else, no detalis, no connector etc.
https://ibb.co/Mn8ZXGh
https://ibb.co/1TR3M1p
