Furniture fittings1
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Furniture fittings1
Postby babaroga » Sun Aug 14, 2016 8:19 pm
This is my first post on forum. I am folowing FreeCAD for years and using it actively for past two years.
As R&D manager in my company, I am making lot of prototypes. For one of them, lead time for fittings was too long, so I made them by myself.
It is used for "butterfly" tabletops. I draw it and 3D print from one piece. It worked perfectly.
I used FreeCAD 0.17 from Github on Ubuntu 16.04.
Here is some screenshots and FreeCAD file. Maybe someone will find it useful.
Screenshot from 2016-08-14 21-15-15.png (180.11 KiB) Viewed 5046 times
Screenshot from 2016-08-14 21-14-22.png (156.9 KiB) Viewed 5046 times
Sarnir.fcstd
(108.15 KiB) Downloaded 195 times
A_3
Re: Furniture fittings1
Postby A_3 » Tue Aug 16, 2016 8:22 am
Welcome! Nice work.
bernd
Postby bernd » Mon Aug 22, 2016 4:21 pm
Would you share the file too?
A_3
Postby A_3 » Mon Aug 22, 2016 5:32 pm
@bernd
look at attacment there is a file named Sarnir.fcstd
bernd
Postby bernd » Tue Aug 23, 2016 6:52 am
:oops: I missed this somehow. How did the fitting the pieces together worked out. The "noses" did neither break nor squeeze?
cox
Postby cox » Tue Aug 23, 2016 3:17 pm
bernd wrote::oops: I missed this somehow. How did the fitting the pieces together worked out. The "noses" did neither break nor squeeze?
It prints all in place, no need to attach the peaces afterwords, my test printed a bit fat, so i had to use quite a bit of force to brake the peaces free. Strong tight usable part, with no slop :D
babaroga wrote:This is my first post on forum. I am folowing FreeCAD for years and using it actively for past two years.
Nice model, and first post. Welcome to the forum :D
r-frank
Postby r-frank » Wed Aug 24, 2016 8:09 am
Hello.
Nice part, thanks for sharing.
One "technical" question ...
To save time/material would it make sense to add a pocket in the middle of each "flange" on the backside
or setting the filling degree to 80% or less when 3D-printing ?
[I never did a 3D print before ...]
Roland
My GrabCAD FreeCAD-Projects
cox
Postby cox » Wed Aug 24, 2016 10:03 am
r-frank wrote:One "technical" question ...
I guess, but there are so many variables when dealing with 3d-printing that there is generally no one correct answer, kind of like it is with FreeCAD. It all depends on a lot of variables where some of them are:
What is the part to be used for
Material old, new, brand, type of plastic.
Printer how well does it print on different speeds, is it properly calibrated.
Software etc.
I guess I would rather sett innfill to some lower value rather than making a pocket if your concern is soly time and material. I used ABS 20% infill and 3 0,25 mm external layers and I can not brake the part with my hands if my life depended on it.
babaroga
Postby babaroga » Wed Aug 24, 2016 6:46 pm
I am on vacation so slow on answer.
I printed it with ABS, 3 solid layers top/bottom, 3 perimeters, 0,5 mm nozzle and 0,2 mm layer height.
Infill was 15% rectilinear.
Everything was sliced with slic3r.
Distance between moving parts is 0,2 mm. I printed it with nozzle on 215 degrees to prevent too much sticking of parts.
Material used was some low quality chinese ABS. It was not wery hard to break this pieces, but i have very well calibrated printer.
I will also post drawings of whole table. It is also made in freecad.
Fabionjoe
Postby Fabionjoe » Sat Aug 25, 2018 12:51 pm
Pretty old post but I am facing problem in fitting of my one of armchair design. I am not doing job but I am using freecad as my hobby and living in Sydney Australia. I am trying to learn it and not really expert. I am facing problem in measuring the length of the 4 legs. unable to get the balance. The fittings giving me problem!
Vida and Co Furniture https://www.aushoppinghub.com/brand/vida-co/ Online Australia.
