CAD Challenge
justacec
Re: CAD Challenge
Postby justacec » Tue Jun 19, 2018 10:30 am
I am having some difficulty in understanding all the necessary dimensions from challenge 2. I have attached it to this message. How do I determine how large the vertical edges are on the ears. It says that the angle is 63 degrees in the between the two angled lines but that leaves an ambiguity. The lower edge is fixed to 19.7mm, however, there is no corresponding constraint on the upper edge?
Screen Shot 2018-06-19 at 6.22.40 AM.png (255.38 KiB) Viewed 1143 times
PrzemoF
Re: CAD Challenge
Postby PrzemoF » Tue Jun 19, 2018 10:52 am
If there is only one dimension "missing" in a chain of dimensions it's OK. A chain of dimension should no be closed.
Edit: There is more than just one dimension missing as far as I see. You could probably assume symmetry of the "ears" with the holes, but they don't seem to be symmetrical.
justacec
Re: CAD Challenge
Postby justacec » Tue Jun 19, 2018 12:24 pm
@PrzemoF Ahh ok. Thanks for recognizing the issue here. I was hopeful I was just not missing something. I looked at it for quite some time this morning... Incidentally, I notice that there are some measurements in the lower right corner. Do those describe the geometry of the gear teeth? I tried to look it up but did not find a good answer. Since there are no dimensions on the teeth themselves, how do I interpret that?
A_3
Re: CAD Challenge
Postby A_3 » Tue Jun 26, 2018 8:50 pm
Another pair of eyes see more.I'll try to fix dimension issue in next few days (or more :( ).
So, I was editing 50 drawings and I'm glad that someone find errors.
PDF file with drawings is almost ready to be published.
jona
Re: CAD Challenge
Postby jona » Mon Dec 17, 2018 8:30 pm
@A_3 Is the new version of your document just around the corner ? :)
A_3
Re: CAD Challenge
Postby A_3 » Tue Jan 01, 2019 9:03 pm
If we wait for perfection, we will never do anything. (in this case)
I apologize to all who have been waiting for these drawings for a long time.
The program is developing so fast that some of the things I want to put out are outdated.
Тhere are people who make quality tutorials, in the collection of drawing tasks there's no place for that. I gave up on it, there are only examples to be drawn. Many of the errors have remained, I will solve them, you do not produce the right part anyway, and therefore improvise.
So I'm putting the collections raw version. I still have lot drawings for processing, I hope there will be about a hundred.
Drawings serve for educational purposes only. Have a lot of fun!
Edited g_01.pdf is here!!
g_01.pdf
(483.11 KiB) Downloaded 8 times
g_05.pdf
(233.86 KiB) Downloaded 47 times
g_04.pdf
(448.56 KiB) Downloaded 22 times
g_03.pdf
(247.69 KiB) Downloaded 17 times
g_02.pdf
(395.7 KiB) Downloaded 17 times
bejant
Re: CAD Challenge
Postby bejant » Thu Jan 03, 2019 1:06 pm
In the second exercise in g_01,pdf, I don't think the keyway should run all the way to the top? It cuts through the outer wall there:
Exercise_g_01-02.FCStd
(27.36 KiB) Downloaded 2 times
PrzemoF
Re: CAD Challenge
Postby PrzemoF » Thu Jan 03, 2019 1:13 pm
The top view doesn't match the side view. There should be 4 circles, not three. So I guess you have to make the keyway shorter or ignore the 85 mm diameter part.
Edit: I'm open to correction, but there is no need for the angle 30,26 if both lengths and both diameters defining it are given
Edit2: No need for the angle, I'm sure.
Zrzut ekranu z 2019-01-03 13-37-52.png (186.98 KiB) Viewed 231 times
bejant
Re: CAD Challenge
Postby bejant » Thu Jan 03, 2019 1:53 pm
I was thinking that the piece is shown in first angle projection so the view on top is showing the bottom, and the 85 mm diameter circle isn't shown (it would be a hidden edge)?
I'm in the U.S. so I'm used to third angle projection...
I omitted that angle, but could have included it in the Sketch as a reference (blue constraint). It looks like your screen grab is from my file?
PrzemoF
Re: CAD Challenge
Postby PrzemoF » Thu Jan 03, 2019 2:31 pm
I'm in the EU :D No, the screenshot is from the attached file - I did my own version.
OK, so the side view is wrong, because the keyway protrudes through the wall.
Edit: A comment not really relevant to FreeCAD: the part would be probably finished with a lathe, so an angle + one dimension would be better than 2 dimensions. Set the knife at an angle and go as far as required...
P.S. I previously attached _your_ file :D
cad_ex_01_02.fcstd
(27.69 KiB) Downloaded 6 times
