Architecture work in FreeCAD
bernd
Re: Architecture work in FreeCAD
Postby bernd » Wed Jun 21, 2017 4:29 am
what are the bubbles used for?
damian
Postby damian » Wed Jun 21, 2017 8:38 am
regis wrote:
Sun Apr 16, 2017 10:51 pm
The best of freecad is when all the small details begin to take shape.
The way is a little bit hard, but the reward is enormous
very nice work!
see you
regis
Postby regis » Wed Jun 21, 2017 4:53 pm
Those are filler slabs, made with clay pots in this representation, a way to create lighter concrete roofing slabs that are 2/3 the volume or full slabs, so slightly lightweight and slightly cheaper while bringing in the strength of waffle slabs, but also brings in some type of aestetic apeal to the roof.
In the design of this project, I then experimented with creating such a slab as a worth while challenge for freecad.
Once I knew I wanted to create these slabs, i thought a bit further, if this is to be built or redesigned, there will be a need to create good and accurated construction documents, so the initial model needs to be well designed with a minimum degree of errors. I then wondered if freecad could 1.) create such slabs, and how to accurately position them, modify them, 2.) how quickly can you reproduce a modified version of the project if this were a real world scenarios where changes occur on projects on a daily if not hourly basis, while executing all the boolean operations including rebar representation. Basically seing how far I can tax freecad. :D ,This was no easy fit :oops: , there were alot of crash and bugs during the trials, lots of things not behaving well, or sometimes unexpected etc different methods were very slow if you imagine having to select each clay pot and cutting the volumetric shape out of the roof so that it is accurately represented in drawing plans plans when you do detail sections. So the project size increased exponentially, so it was a good struggle to see how freecad handles such workloads, testing its limits when it comes to hard core production work.
Screenshot from 2017-06-21 11-54-58.jpg (576.87 KiB) Viewed 1822 times
bernd
Postby bernd » Thu Jun 22, 2017 6:54 pm
What system do you exactly usein your project ? BTW Is it a real project ?
As a structural engineer I use the one attached one quite often ... But I have never used it at such a small building. At the moment I do a building for an airport fire brigade The building is 75 m x 30 m There we use the system and can save hundreds of m3 concrete
regis
Postby regis » Thu Jun 22, 2017 10:53 pm
System? not sure what you are asking as I don't know alot of engineering terms. I was hoping for it to be a real built project. But is was a competition submital.
Screenshot from 2017-06-22 18-51-52.jpg (350 KiB) Viewed 1741 times
triplus
Postby triplus » Thu Jun 22, 2017 11:12 pm
Good job @regis.
Thearod
Postby Thearod » Fri Jun 23, 2017 11:12 am
@regis looking good so far. Are you still planning to realize this project?
regis
Postby regis » Sat Jun 24, 2017 3:01 am
it would be ideal to build, so yes perhaps someday when I can get the funds and a good opportunity.
but a few more options like 2bedroom or 3bedrooms should be created for it to fit various market demands.
Thearod
Postby Thearod » Wed Jun 28, 2017 10:15 am
That would be amazing if you'll get it done someday! It looks really promising, hopefully you'll get the opportunity soon.
regis
Postby regis » Sat Aug 12, 2017 11:21 pm
These pictures where dying on my desktop until i delete them, so i just thought i would share them here before
Screenshot from 2016-12-23 19-31-18.png (221.6 KiB) Viewed 1338 times
Screenshot from 2016-12-22 11-15-32.png (169.82 KiB) Viewed 1338 times
Screenshot from 2016-12-16 02-24-18.png (172.83 KiB) Viewed 1338 times
Screenshot from 2016-12-16 02-23-17.png (175.6 KiB) Viewed 1338 times
Screenshot from 2016-12-16 01-11-34.png (311.04 KiB) Viewed 1338 times
