Hi Joel,
joel wrote: ↑Fri Mar 02, 2018 5:56 pm
I used your Curves workbench with a lot of satisfaction. Using Sweep_2_rails and Approximation_Curve. Would it be possible to transform
the object obtained into solid?
This is the main problem with my tools. They are approximation tools : Sweep_2_rails only generates a point cloud, that is later approximated with the approximation tool.
The only way to get a solid is to start with the "Sweep_2_rails surface" and build all the other faces around it (with precise, watertight tools) , up to a closed shell that can be converted to a solid.
You should also have a look at the surface workbench (in FC 0.17) that has a very interesting and powerful (but be careful, it can crash FC quite easily, also) "filling" tool.
