Virtual Test Bench with Heavy Wall Pipe
HarryvL
Postby HarryvL » Fri Feb 02, 2018 10:00 pm
Hi all,
I analysed a heavy wall pipe with FEM work bench.
With this set up I aim to create uniform bending moment in the center span. This is just a first test before I try to analyse composite pipe-in-pipe assemblies. The work flow of creating Booleanfragments, Compoundfilter, etc. etc. I explain in a Tutorial, here:
https://www.freecadweb.org/wiki/FEM_She ... site_Block
So far the results are encouraging.
The displacements are within 2% of what I get with simple beam theory.
Please forgive me, but I still use Paraview to get the really glossy pictures.
Above picture shows uniform bending stresses in the central span ... hooray ... and next picture shows stresses that are in line with bending theory.
Next challenge, real pipe-in-pipe on this virtual test bench :D
As always, comments and suggestions welcome :!:
Harry
thschrader
Re: Virtual Test Bench with Heavy Wall Pipe
Postby thschrader » Sat Feb 03, 2018 8:35 am
Hi Harry,
the "virtual test bench" is a nice idea. Would be interesting to see how a
test-case behaves with the different solvers/meshes and on different
machines/OS. Why have you put the vertical loadings nearby the fixings
into the model?
Thomas
HarryvL
Postby HarryvL » Sat Feb 03, 2018 8:56 am
Hi Thomas,
Yeah it would be fun to test different models and solvers.
I put loads at the free surfaces (faces) of the support in equilibrium with the "external" loads to prevent stress concentrations at the fixed supports. The supports need to hinge at both sides and slide at one. This means that I can only fix the edges of the supports. So if I don't apply reaction forces then all the load is transferred to the edge of the support and this would create huge stress concentrations, spoiling all the stress plots and causing spurious deformations.
HarryvL
Postby HarryvL » Tue Feb 06, 2018 8:38 pm
Thanks to help received from HoWil (https://forum.freecadweb.org/viewtopic. ... 7&start=20), I now have a robust work flow for assigning properties to internal regions. So I finally managed to model and analyse the pipe-in-pipe assembly (two concentric pipes bonded together with grout) :D
Mid-span stresses in the outer tube are reduced from ~34MPa to ~25MPa due to the contribution from the inner tube. This is in line with what I get from beam theory, using a composite second moment of inertia.
... but near the ends of the inner tube, stresses are fully transferred back to the outer tube. Again, stresses are in line with beam theory. The behavior of the assembly in the transition zone near the end of the inner tube and the length of this zone can only be obtained from FEA.
Radial stresses in the grout can also be extracted from the model (not shown here).
All-in-all a fun learning experience !
sgrogan
Postby sgrogan » Wed Feb 07, 2018 1:15 am
@HarryvL did you see this thread? https://forum.freecadweb.org/viewtopic.php?f=8&t=26759
Your work would be excellent to show FEM :)
This illustrates FreeCAD FEM's integration with other FOSS projects!
HarryvL
Postby HarryvL » Wed Feb 07, 2018 4:39 am
Thanks @sgrogan, I am happy to support ...
By the way, here a few more pleasing pictures. First a combined view of model and deformation
and a few to show the integration with CalculiX CGX pre-processor in my work flow, which I use to review the quality of internal meshes before running the analysis. The file names give the context.
