abdullah wrote: ↑Wed Mar 14, 2018 7:11 pm
Yes, it is correct. I would love to have drawings, but there is none. I get them from the stl.
There are lots of PDF drawings in the Thingiverse page. But they show exploded views of sub-assemblies. There are no dimensioned drawings.
There is a STEP file of the complete assembly, see
OpenRC_Truggy_Assembly.stp. STEP files are B-rep models. However, FreeCAD v0.16 hangs trying to open it, and v0.17 hard crashes with a segmentation fault.
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f0c31db24b0]
#1 0x7f0bf231e738 in Interface_EntityIterator::AddList(opencascade::handle<TColStd_HSequenceOfTransient> const&) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x1c8
#2 0x7f0bf23274e4 in Interface_Graph::Sharings(opencascade::handle<Standard_Transient> const&) const from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x44
#3 0x7f0bef9594bc in STEPConstruct_Assembly::CheckSRRReversesNAUO(Interface_Graph const&, opencascade::handle<StepShape_ContextDependentShapeRepresentation> const&) from /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7+0x1cc
#4 0x7f0bef9eba5b in STEPControl_ActorRead::TransferEntity(opencascade::handle<StepRepr_NextAssemblyUsageOccurrence> const&, opencascade::handle<Transfer_TransientProcess> const&) from /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7+0x2cb
#5 0x7f0bef9ea6ab in STEPControl_ActorRead::TransferEntity(opencascade::handle<StepBasic_ProductDefinition> const&, opencascade::handle<Transfer_TransientProcess> const&) from /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7+0x122b
#6 0x7f0bef9e6c95 in STEPControl_ActorRead::TransferShape(opencascade::handle<Standard_Transient> const&, opencascade::handle<Transfer_TransientProcess> const&, bool) from /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7+0x275
#7 0x7f0bef9e7415 in STEPControl_ActorRead::Transfer(opencascade::handle<Standard_Transient> const&, opencascade::handle<Transfer_TransientProcess> const&) from /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7+0x195
#8 0x7f0bf2345d67 in Transfer_ActorOfTransientProcess::Transferring(opencascade::handle<Standard_Transient> const&, opencascade::handle<Transfer_ProcessForTransient> const&) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x67
#9 0x7f0bf23591f6 in Transfer_ProcessForTransient::TransferProduct(opencascade::handle<Standard_Transient> const&) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0xc6
#10 0x7f0bf235c1c4 in Transfer_ProcessForTransient::Transferring(opencascade::handle<Standard_Transient> const&) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x214
#11 0x7f0bf235ca86 in Transfer_ProcessForTransient::Transfer(opencascade::handle<Standard_Transient> const&) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x26
#12 0x7f0bf23f01db in XSControl_TransferReader::TransferOne(opencascade::handle<Standard_Transient> const&, bool) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x2fb
#13 0x7f0bf23e762e in XSControl_Reader::TransferEntity(opencascade::handle<Standard_Transient> const&) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x4e
#14 0x7f0bf23e8624 in XSControl_Reader::TransferOneRoot(int) from /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7+0x34
#15 0x7f0b93852b5d in STEPCAFControl_Reader::Transfer(STEPControl_Reader&, int, opencascade::handle<TDocStd_Document>&, NCollection_Sequence<TDF_Label>&, bool) from /usr/lib/x86_64-linux-gnu/libTKXDESTEP.so.7+0x8d
#16 0x7f0b938543a9 in STEPCAFControl_Reader::Transfer(opencascade::handle<TDocStd_Document>&) from /usr/lib/x86_64-linux-gnu/libTKXDESTEP.so.7+0x69
#17 0x7f0ba06a5448 in ImportGui::Module::insert(Py::Tuple const&) from /usr/lib/freecad-daily/lib/ImportGui.so+0x348
#18 0x7f0ba06a1e9a in Py::ExtensionModule<ImportGui::Module>::invoke_method_varargs(void*, Py::Tuple const&) from /usr/lib/freecad-daily/lib/ImportGui.so+0x3a
#19 /usr/lib/freecad-daily/lib/libFreeCADBase.so(method_varargs_call_handler+0x16c) [0x7f0c33ed04fc]
#20 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8a51) [0x7f0c33978971]
#21 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7f0c33aae05c]
#22 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7f0c3396fda9]
#23 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_StringFlags+0x76) [0x7f0c339ea1f6]
#24 0x7f0c33f007e6 in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /usr/lib/freecad-daily/lib/libFreeCADBase.so+0x66
#25 0x7f0c343e44fd in App::Application::sLoadFile(_object*, _object*, _object*) from /usr/lib/freecad-daily/lib/libFreeCADApp.so+0x53d
#26 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8a51) [0x7f0c33978971]
#27 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7f0c33aae05c]
#28 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7f0c3396fda9]
#29 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_StringFlags+0x76) [0x7f0c339ea1f6]
#30 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x4c47) [0x7f0c33974b67]
#31 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7f0c33aae05c]
#32 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7f0c3396fda9]
#33 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_StringFlags+0x76) [0x7f0c339ea1f6]
#34 0x7f0c33f007e6 in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /usr/lib/freecad-daily/lib/libFreeCADBase.so+0x66
#35 0x7f0c34a1f2d0 in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x130
#36 0x7f0be5b6ad62 in WebGui::BrowserView::onLinkClicked(QUrl const&) from /usr/lib/freecad-daily/lib/WebGui.so+0x592
#37 0x7f0c3287e010 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x4d0
#38 0x7f0c2e04d615 in QWebView::linkClicked(QUrl const&) from /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4+0x35
#39 0x7f0c3287e010 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x4d0
#40 0x7f0c2e03d405 in QWebPage::linkClicked(QUrl const&) from /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4+0x35
#41 0x7f0c2e03d47c in QWebPage::acceptNavigationRequest(QWebFrame*, QNetworkRequest const&, QWebPage::NavigationType) from /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4+0x5c
#42 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0x438be7) [0x7f0c2e081be7]
#43 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa59d71) [0x7f0c2e6a2d71]
#44 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa3975d) [0x7f0c2e68275d]
#45 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa3a5fc) [0x7f0c2e6835fc]
#46 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa3b24e) [0x7f0c2e68424e]
#47 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa3b933) [0x7f0c2e684933]
#48 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa3be90) [0x7f0c2e684e90]
#49 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xa3c4f1) [0x7f0c2e6854f1]
#50 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0x820698) [0x7f0c2e469698]
#51 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0x6b10f0) [0x7f0c2e2fa0f0]
#52 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0x6c41f8) [0x7f0c2e30d1f8]
#53 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0x6afc46) [0x7f0c2e2f8c46]
#54 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0x6d49ae) [0x7f0c2e31d9ae]
#55 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xac2b75) [0x7f0c2e70bb75]
#56 /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4(+0xac72fb) [0x7f0c2e7102fb]
#57 0x7f0c2e04b926 in QWebPage::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4+0x426
#58 0x7f0c2e04c800 in QWebView::mouseDoubleClickEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4+0x20
#59 0x7f0c32ded8d0 in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2a0
#60 0x7f0c2e04d837 in QWebView::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4+0x67
#61 0x7f0c32d96fdc in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
#62 0x7f0c32d9e0d6 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x476
#63 0x7f0c349fe494 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x54
#64 0x7f0c3286990d in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
#65 0x7f0c32d9d6dd in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x14d
#66 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2493f2) [0x7f0c32e1b3f2]
#67 0x7f0c32e1ac83 in QApplication::x11ProcessEvent(_XEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x16b3
#68 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272542) [0x7f0c32e44542]
#69 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2a7) [0x7f0c2b4d2197]
#70 /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4a3f0) [0x7f0c2b4d23f0]
#71 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f0c2b4d249c]
#72 0x7f0c3289a2ae in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
#73 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272616) [0x7f0c32e44616]
#74 0x7f0c3286818f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
#75 0x7f0c328684f5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
#76 0x7f0c3286e4b9 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
#77 0x7f0c349b7270 in Gui::Application::runApplication() from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x15b0
#78 freecad-daily(main+0x8b4) [0x403834]
#79 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f0c31d9d830]
#80 freecad-daily(_start+0x29) [0x404a79]
It's a pity, it would be much easier to reverse engineer solid parts than STL meshes.
I'd be interested to know if somebody else is able to open the file.
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13407 (Git)
Build type: None
Hash: 2c2d781aa686b731f2a0e754dc30ebb76f3553e0
Python version: 2.7.12
OCC version: 7.1.0
Locale: French/Canada (fr_CA)
