Hi guys I've been working with the rebar addon and I'm trying to improve the way the objects are created. I created a tool for Wire Reinforcement Columns.
As you can see you only need to select the type of reinforcement you want,the faces for rebar and stirrup ( It also supports triangular stirrups) and edit, if you want to, the spacing, rebar diameter, rebar length, stirrup diameter,etc. So in 3 clicks you will have a reinforcement (with overlap) in your structure instead of having to create each rebar and stirrup.
I just need a little help, The Arch.makeRebar command doesn't work when the structure have an angle, maybe an error with the "Map a sketch to a face" command??
