Box Creator Script
christi
Re: Box Creator Script
Postby christi » Sun Jan 12, 2020 8:47 am
roerich_64 wrote:
Sat Jan 11, 2020 8:32 pm
Yes, WOW...
but where we can found BoxCreator???
Now you can find it at https://github.com/chbergmann/FreeCAD-m ... ctCreation
This location may be deleted if the macro gets merged into the official repository.
roerich_64
Postby roerich_64 » Sun Jan 12, 2020 7:45 pm
Thanks a lot Christi.
I found issues. Where can i write over them?
Walter
christi
Postby christi » Mon Jan 13, 2020 4:04 pm
You can write me a private message:
https://forum.freecadweb.org/ucp.php?i=pm&mode=compose
There is also a thread in the Help forum:
https://forum.freecadweb.org/viewtopic.php?f=3&t=37382
blue0cean
Box Creator Script
Postby blue0cean » Tue Jun 23, 2020 12:05 am
Is it possible to set the Box Creator Script so that it does not close automatically after the box has been created so that, for example, the partition walls can still be made?
Or that the last values are retained when opening?
christi
Postby christi » Fri Jul 03, 2020 8:08 am
This is a good suggestion. Update the boxcreator macro. The dialog will now stay open after clicking Create box.
Xokiru
Postby Xokiru » Sun Dec 06, 2020 5:49 pm
Hi Christi,
I was happy to find this macro, unfortunetly it is not available under the addon manager/macros. I've tried to install it manual from depository but macro was not working.
Im using 0.19, 23141(git)
Thank you!
christi
Postby christi » Sat Dec 12, 2020 9:45 am
Hi Christi,
Thank you!
There is something wrong with your FreeCAD installation. It is working with 0.19 23258.
Please make sure that your macro directory exists and is accessible (see menu Macro -> Macros... bottom line).
Splattie
Postby Splattie » Mon Mar 01, 2021 10:21 pm
Has this been removed from the Macro Add-ons in v0.19-24267?
I don't see it in the list of add-on macros anymore.
It looks AMAZING and I'm super excited about using it! I hope there's a way to in this version.
Thanks so much!
Postby chrisb » Tue Mar 02, 2021 7:31 am
It is available here. Did you switch from the workbenches tab to the macros in AddonManager?
christi
Postby christi » Sat Mar 06, 2021 6:49 pm
Here is a nice website for creating 2D outlines for many different kind of boxes. Unfortunately, this does not integrate into FreeCAD.
https://festi.info/boxes.py
