steel structure joint, end plate
Jee-Bee
Re: steel structure joint, end plate
Postby Jee-Bee » Fri Nov 02, 2018 8:10 pm
HarryvL wrote:
Fri Nov 02, 2018 7:07 pm
I ran your example. It took 20 minutes to run. :shock: The output object reports a maximum von Mises stress of 292MPa and a maximum equivalent plastic strain (PEEQ) of 0.0091. Clearly these are not consistent with your input values, where at a PEEQ of 0.02 the stress should be 240 MPa. This is because of the extrapolation of stress and strain values to the nodes.
The DAT file is too big to load into my spreadsheet tool, but I am pretty sure that a bit of Python wizardry will show that the von Mises stress in the Gauss (integration) points (to be calculated from the formula below) is perfectly in line with the PEEQ (saved to file) in the same point.
I have to learn some stuff interesting!!
HarryvL
Postby HarryvL » Fri Nov 02, 2018 8:39 pm
@Jee-Bee most of it is explained here:
https://forum.freecadweb.org/viewtopic. ... 31#p220381
and here:
https://forum.freecadweb.org/viewtopic. ... 31#p220591
and here:
https://forum.freecadweb.org/viewtopic. ... 10#p217518
but I also promised to do a tutorial, which I never did :oops:
Jee-Bee
Postby Jee-Bee » Sat Nov 03, 2018 8:34 am
thanks i'll check them out
thschrader
Postby thschrader » Sat Nov 03, 2018 9:28 am
Hi Bernd,
I checked the flange with my commercial software.
At Q=20 kN, M=46 kNm, M20 10.9 bolts I get a
utilization of 99% (without safety-factors for loading).
Thomas
report.pdf
(60.49 KiB) Downloaded 46 times
thschrader
Postby thschrader » Sat Nov 03, 2018 9:43 am
UR_ provided a nice flange-model (contact-analysis).
Maybe you can use this as a basis for your problem.
rivlet-stripped.FCStd
(48.44 KiB) Downloaded 25 times
fandaL
Postby fandaL » Sat Nov 03, 2018 10:32 am
If you would use it, I can extract the code from my scripts to convert von Mises stress from dat file to vtk format. It should not take much time.
thschrader
Postby thschrader » Sat Nov 03, 2018 11:22 am
my two cent:
loading 230 kN at top/bottom of IPE-200, gives M=46 kNm
stresses at corner/web of IPE a little too high (plastifies out :lol: )
bolts are ok ==> M20 10.9
endplate_ts.FCStd
(51.45 KiB) Downloaded 37 times
HarryvL
Postby HarryvL » Sat Nov 03, 2018 12:00 pm
Thanks @fandaL. It would be interesting to see what Paraview does with stresses at integration points. But I suspect it will also extrapolate to and average over nodes to create continuity across element edges. So this will give similar inaccuracies as the ones induces in CCX by interpolation and averaging. I will do some reading before you put in much effort.
HarryvL
Postby HarryvL » Sat Nov 03, 2018 12:31 pm
Hi Thomas. Did you do an linear elastic analysis or a non-linear elastoplastic analysis? In a linear elastic analysis you will get unrealistic stress concentrations at sharp corners. That's the paradox I talked about: "The finer the mesh, the higher the stress" In a non-linear analysis the von Mises stress should not exceed the stress strain curve you have given as input. It it does, it is due to extrapolation and averaging of the results in integration points to nodes. I would never reject the design of a statically loaded detail becuase of local stress concentration. Buckling and fatigue is of course a different matter.
fandaL
Postby fandaL » Sat Nov 03, 2018 1:59 pm
I have not found a way how to save integration point values to the vtk legacy format (I'm afraid that for displaying each integration point, one would need some other file format). I use integration point stresses and strain energy density values and average them over the element or take maximal value of von Mises stress for optimization purposes. I can export them to the vtk file and display in Paraview as one color on whole element.
