steel structure joint, end plate
ppemawm
Re: steel structure joint, end plate
Postby ppemawm » Sat Nov 03, 2018 2:01 pm
thschrader wrote:
Sat Nov 03, 2018 11:22 am
bolts are ok ==> M20 10.9
[/quote
How did you handle the preload in the bolts? Just curious how others deal with this in FEA.
"It is a poor workman who blames his tools..." ;)
thschrader
Postby thschrader » Sat Nov 03, 2018 2:11 pm
HarryvL wrote:
Sat Nov 03, 2018 12:31 pm
Hi Thomas. Did you do an linear elastic analysis or a non-linear elastoplastic analysis?
@Harry: only linear elastic as a first start.
@Bernd: is the flange attached to a column? Or another flange/beam?
Thomas
thschrader
Postby thschrader » Sat Nov 03, 2018 2:14 pm
No prestressing of the bolts. It is only a first model. I will think about that.
Harry has used "cooling" of rebars to simulate prestressing of concrete beams.
thschrader
Postby thschrader » Sat Nov 03, 2018 2:17 pm
EDIT:
Btw: the external momentum of a prestressed bolted flange does not raising the force in the bolts (only a very little...)
ppemawm
Postby ppemawm » Sat Nov 03, 2018 2:48 pm
Ah, OK. That is how I have been doing it.
Btw: the external momentum (moment?) of a prestressed bolted flange does not raising the force in the bolts (only a very little...)
Depends heavily upon the relative stiffness between the flange, gasket, and bolt. FEA is a way of accounting for that stiffness ratio if the bolts are preloaded in the model, especially if the bolts are in bending. Critically important for fatigue or cyclic loading.
bernd
Postby bernd » Sat Nov 03, 2018 7:51 pm
according to ickby vtk supports element data out of the box. Means it should be possible to show results in integration points in paraview. https://forum.freecadweb.org/viewtopic. ... 10#p260932
bernd
Postby bernd » Sat Nov 03, 2018 7:56 pm
wow lots of answers ... I have carefully read the other topics of harryvl. great stuff ...
The bolts are 8.8 M24 Staifix ancor and the cantilever beam should be on a concrete wall. Between plate an concrete is 20 mm special stiff insulation. But not at around the bolt. I may need to make a geometric model of all ...
Seams we somehow need to attract the integration point data for these plastic analysis. This is something FreeCAD is able to analyze but most structural analysis software not :D
bernd
HarryvL
Postby HarryvL » Sat Nov 03, 2018 8:23 pm
fandaL wrote:
Sat Nov 03, 2018 1:59 pm
I use integration point stresses and strain energy density values and average them over the element or take maximal value of von Mises stress for optimization purposes. I can export them to the vtk file and display in Paraview as one color on whole element.
Exporting the maximum values for SigvM and PEEQ as a constant value for the element would be good. But no nodal averaging over adjacent elements should be applied.
PS: it's just an inherent characteristic of the FEM that stresses and strains get evaluated at integration points. So any extrapolation to the other positions within the element (like nodes) and averaging over adjacent elements for the sake of getting pretty pictures will lead to confusing interpretation and inconsistency between stress and strain. 25 years ago I implemented a more accurate method for smoothing results (one originally proposed by Clough in the 60s); but even with that small inconcistencies remain.
HarryvL
Postby HarryvL » Sat Nov 03, 2018 8:49 pm
Just a thought ... would it be possible/difficult to implement functionality where the user gets to see the smoothed, but inaccurate, results to identify area of high stress and strain and then when hovering the mouse over an element in that region gets to see tabulated values for the integration point results for that specific element? Even the 10 node quadratic tetrahedron (C3D10) only has 4 integration points, so that is not a massive amount of information.
UR_
Postby UR_ » Sun Nov 04, 2018 8:10 am
If you are using contact analysis already, one can simply achieve pretension (without *PRETENSION :( ) by design.
In this case you will have overlapping solids.
i.e. There is a gap between both plates (0,01 mm) and a "negative" gap between bolt's head and it's supporting plate (-0,3 mm)
ccx will solve this intrusion by applying as much strain as needed to accomplish the contact constraint.
FreeCAD 0.18-000097.png (191.34 KiB) Viewed 741 times
pretension_stripped.FCStd
(24.53 KiB) Downloaded 37 times
So no heating up to melting point is needed.
And therefore no firefighter needs to be present, while you are doing your calculations :lol:
