Lanz Bulldog mini tractor
un1corn
Postby un1corn » Sun Dec 02, 2018 12:41 pm
Uses flame eater type Stirling engine.
Fin 0.JPG (301.96 KiB) Viewed 2700 times
Fin 1.JPG (117.48 KiB) Viewed 2700 times
Lanz Engine and Gearbox.JPG (55.42 KiB) Viewed 2700 times
Lanz Rear Axle Assembly.JPG (62.35 KiB) Viewed 2700 times
Re: Lanz Bulldog mini tractor
Postby chrisb » Sun Dec 02, 2018 2:03 pm
Very impressive, thanks for sharing. Call yourself lucky that these engines had only one cylinder - at most!
un1corn
Postby un1corn » Sun Dec 02, 2018 3:00 pm
I also have an 8 cylinder micro Aero engine and a lorry with a 2 cylinder under-slung engine amongst many others which I will eventually post.
axel_sch
Postby axel_sch » Tue Jun 04, 2019 4:32 pm
Hello, I am building the mini tractor lanz, and I would be very useful freecad project. I would really appreciate it if you send it to my mail via pm.
Reason: removed email from post
un1corn
Postby un1corn » Wed Jun 05, 2019 6:42 am
FAO axel_sch,
Hi, plans for the Lanz mini tractor can be found here.
http://www.vapeuretmodelesavapeur.com/telechargements4/
Good luck with the project.
un1corn
Postby un1corn » Wed Jun 05, 2019 7:11 am
Hi, If you cannot locate the plans on previous posted link try this one
http://www.vapeuretmodelesavapeur.com/telechargements5/
