A toy brick macro
vectronic
A toy brick macro
Postby vectronic » Fri Jan 18, 2019 11:42 pm
Hello All,
I've been working on this macro for a while with the following aims:
  • Get to grips with FreeCAD and concepts for parametric modelling: sketches, constraints, datum planes etc.
  • Use Python scripting with FreeCAD
The real challenge I gave myself was to use Python scripting with the PartDesign workbench: I wanted to end up with a parametric model fully based on sketches and datum planes.
I've learnt and discovered various things on this journey:
Example images below. Check it out and let me know what you think!
The latest macro code, brief overview and instructions are available at:
https://github.com/vectronic/freecad-legify-macros
The very first v0.1.0 cut is available at:
https://github.com/vectronic/freecad-le ... tag/v0.1.0
roerich_64
Re: A toy brick macro
Postby roerich_64 » Sat Jan 19, 2019 9:18 am
Wow, a children's dream comes true :)
Thanks for sharing :)
Can we have a look to the tree view?
BR
Walter
vectronic
Postby vectronic » Sun Jan 20, 2019 9:13 pm
With pleasure :-)
fosselius
Postby fosselius » Mon Jan 21, 2019 3:25 pm
Awesome! I am going to build a WB for building legos, is it ok if i include your script as well?
I am building a parts library for lego pieces.
See end of this thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=11610
vectronic
Postby vectronic » Mon Jan 21, 2019 9:51 pm
I like what you have done!
You are absolutely welcome to make use of this if you wish.
Zolko
Postby Zolko » Tue Jan 29, 2019 12:27 pm
nice ! But side holes don't work for me, only side studs.
installable with Tools > Addon Manager, new version 0.6.3. Simple tutorial here
vectronic
Postby vectronic » Wed Jan 30, 2019 10:03 am
Sorry, should have pointed to the TODO items from the readme in GitHub:
https://github.com/vectronic/freecad-legify-macros#todo
  • Confirm some dimensions
  • Pin Rendering
  • Technic Hole Rendering
  • Support modern tile where the bottom has a small outside pocket (and check if fillet is also required)
  • Support rib variation in modern 2x1 tile and 2x1 technic brick with 2 non-offset holes
  • Determine a replacement for internal brick ribs if side hole studs exist
  • Determine if the inner edge of open studs and hole studs should be filleted
Hoping to tackle the first 3 in the next month or so...
Zolko
Postby Zolko » Wed Jan 30, 2019 12:28 pm
... this —> please
vectronic
Postby vectronic » Mon Feb 18, 2019 9:35 am
Initial version of technic holes has been pushed to GitHub, together with some bug fixes and cleanups. Correct measurements for some of the hole features are pending as well as support for axle-shaped holes...
Zolko
Postby Zolko » Tue Feb 19, 2019 7:42 pm
nice ... and what's more, it's completely compatible with the my Assembly Without Solver. I'm thinking about launching a Lego challenge
