Triple cylinder vertical steam engine.
un1corn
Postby un1corn » Fri Feb 01, 2019 1:02 pm
Triple cylinder vertical steam engine with slide valves and reversing capability.
Designed by Mr. A Zevenhuizen, Keenskerk,
TC 1.JPG (80.75 KiB) Viewed 1899 times
TC 7.JPG (107.91 KiB) Viewed 1899 times
TC 8.JPG (146.54 KiB) Viewed 1899 times
TC 9.JPG (80.5 KiB) Viewed 1899 times
TC 10.JPG (217.68 KiB) Viewed 1899 times
Laurent14
Re: Triple cylinder vertical steam engine.
Postby Laurent14 » Fri Feb 01, 2019 3:37 pm
very nice job
bejant
Postby bejant » Sat Feb 02, 2019 2:38 am
Very nice job indeed!
ppemawm
Postby ppemawm » Sat Feb 02, 2019 2:02 pm
Very nice indeed....incredible detail.
I am curious how you created the worm gear set?
"It is a poor workman who blames his tools..." ;)
un1corn
Postby un1corn » Mon Feb 04, 2019 4:45 pm
FAO. ppemawm.
Sorry, I am unable to add the quadrant gear file for you to view as it is B.27 MB and to large include.
I will look at it again to see if I can reduce the file to be able to attach.
Is there a way to include larger files here?
Postby chrisb » Mon Feb 04, 2019 6:33 pm
No, you have to use a publicly available file service like dropbox.
un1corn
Postby un1corn » Fri Feb 08, 2019 1:30 pm
FAO. ppemawm.
As promised, I attach files for quadrant and worm gears.
I have not radius-ed all the quadrant teeth to save space.
You will see the steps involved when you go through the file.
Hope this helps.
FCFworm.FCStd
(547.6 KiB) Downloaded 40 times
FCFquadrant.FCStd
(805.27 KiB) Downloaded 32 times
