Triple cylinder vertical steam engine with slide valves and reversing capability.
Designed by Mr. A Zevenhuizen, Keenskerk,
Triple cylinder vertical steam engine.
- TC 1.JPG (80.75 KiB) Viewed 2827 times
- TC 7.JPG (107.91 KiB) Viewed 2827 times
- TC 8.JPG (146.54 KiB) Viewed 2827 times
- TC 9.JPG (80.5 KiB) Viewed 2827 times
- TC 10.JPG (217.68 KiB) Viewed 2827 times
Re: Triple cylinder vertical steam engine.
very nice job
Very nice job indeed!
Very nice indeed....incredible detail.
I am curious how you created the worm gear set?
"It is a poor workman who blames his tools..."
FAO. ppemawm.
Sorry, I am unable to add the quadrant gear file for you to view as it is B.27 MB and to large include.
I will look at it again to see if I can reduce the file to be able to attach.
Is there a way to include larger files here?
No, you have to use a publicly available file service like dropbox.
FAO. ppemawm.
As promised, I attach files for quadrant and worm gears.
I have not radius-ed all the quadrant teeth to save space.
You will see the steps involved when you go through the file.
Hope this helps.
Hope this helps.
- FCFworm.FCStd
- (547.6 KiB) Downloaded 76 times
- FCFquadrant.FCStd
- (805.27 KiB) Downloaded 69 times
