Sheet metal WB 2018
Joel_graff
Re: Sheet metal WB 2018
Postby Joel_graff » Sun Mar 10, 2019 10:48 pm
Added Sheet Metal WB to the 0.19 release notes.
https://www.freecadweb.org/wiki/Release ... al_Modules
-alex-
Postby -alex- » Thu Apr 11, 2019 5:33 pm
Thanks a lot Joel for adding to release notes. FYI maybe could you add this thread to the "discussion" links: https://forum.freecadweb.org/viewtopic.php?f=10&t=11303
-alex-
Postby -alex- » Thu Apr 11, 2019 6:08 pm
Here I would like to share some sheet metal stuffs.
Last months I have tested some workflows about converting 3D solid to sheet metal part.
Basicaly the process is pretty similar with the one discribed by Jaisejames in his thread "Solid Shape to Sheet metal Tutorial":
https://forum.freecadweb.org/search.php ... 9&sr=posts
The aim is to work from faces of the model. IMHO I think my workflow is sharper and allows to get smouth links beetween sheet metal parts (better for MIG welding). To get this I always start from inner faces of the shell.
I'll will talk about that later in a tutorial, because for now there is a small bug/limitation about a function of freecad witch make the workflow tricky.
Anyway, below are some pictures of the FC logo: from picture to 3D solid to 3D sheet metal to flattened sketches.
Enjoy.
Alex
Joel_graff
Postby Joel_graff » Thu Apr 11, 2019 6:20 pm
Will do!
For future reference, feel free to post any updates to your workbench in the Release Notes thread:
https://forum.freecadweb.org/viewtopic. ... 6&start=80
Postby Kunda1 » Fri Apr 12, 2019 12:40 pm
Please post your work to both the tutorial subforum and the User Showcase forum. Thanks!
meme2704
Postby meme2704 » Sat Apr 13, 2019 3:15 pm
Hi
Since I use Fc V0.19pre, my version of SheetmetalWb that was working with V0.17, does not work anymore, I can not find the links for the latest version (Windows7)
Postby chrisb » Sat Apr 13, 2019 3:53 pm
How about update in AddonManager? (Yes, there are things better than in 0.16 ;) )
meme2704
Postby meme2704 » Sat Apr 13, 2019 4:14 pm
super it's run again
thanks
Postby Kunda1 » Sat Apr 13, 2019 10:57 pm
This is a good point to have a ticket that reminds the user to update said workbench if it is obsolete
Edit: nvm, opened one a while ago: https://github.com/FreeCAD/FreeCAD-addons/issues/95 :oops: :lol:
NormandC
Postby NormandC » Sat Apr 13, 2019 11:17 pm
It is also already working! But only if you have python-git installed, or python3-git when FreeCAD is built with Python3.
