Traction engine
un1corn
Traction engine
Postby un1corn » Sun Mar 24, 2019 1:02 pm
Designed by Julian DeWaal, other images available........
JD 4.JPG (259.94 KiB) Viewed 1970 times
JD 9.JPG (466.95 KiB) Viewed 1970 times
JD 7.JPG (399.23 KiB) Viewed 1970 times
JD 3.JPG (396.36 KiB) Viewed 1970 times
HarryGeier
Re: Traction engine
Postby HarryGeier » Sun Mar 24, 2019 5:34 pm
Impressive work !
Congrats...
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
EvilSpirit
Re: Traction engine
Postby EvilSpirit » Tue Mar 26, 2019 5:31 am
Can you show superheater in details?
un1corn
Re: Traction engine
Postby un1corn » Tue Mar 26, 2019 8:08 am
Does not have a 'Super heater' per se, so have posted the boiler assembly FYI, hope it helps.
Boiler assy.JPG (158.7 KiB) Viewed 1503 times
EvilSpirit
Re: Traction engine
Postby EvilSpirit » Tue Mar 26, 2019 12:32 pm
Such simple? I excepted to see something like many pipes with huge area of surface for better heat exchange.
herbk
Re: Traction engine
Postby herbk » Tue Mar 26, 2019 12:59 pm
This technique has come only several years later... ;) ;)
Gruß Herbert
GeneFC
Re: Traction engine
Postby GeneFC » Wed Mar 27, 2019 3:34 am
Such simple?
Julius de Waal (not Julian) is a very prolific designer who has created hundreds of Solidworks models of varying complexity. This model, the Julian Traction Engine, is intentionally designed to be quite simple. Some others, such as his Allchin design, are full featured and quite complex. Many designs are not original, but instead are CAD versions of older paper designs. The Julian is loosely based on a Case prototype, but it basically freelance.
The point of un1corn's work and posting here is to showcase the use of FreeCAD to make the same models that have been made in Solidworks.
If you are interested in more designs from Julius de Waal the most complete location can be found at
http://www.vapeuretmodelesavapeur.com/i ... index.html
[Edit -- I noticed that this is my 1000th post in the forum.] 8-)
Gene
Re: Traction engine
Postby chrisb » Wed Mar 27, 2019 4:38 pm
Congratulations Millenium-Gene. I always highly appreciate your contributions! Spot on for on- and off-topics. If I would ever had programmed FORTRAN I would have said: continue!
Jee-Bee
Re: Traction engine
Postby Jee-Bee » Wed Mar 27, 2019 5:48 pm
If you had programmed python you could say that as well
https://www.tutorialspoint.com/python/p ... ontrol.htm
un1corn
Re: Traction engine
Postby un1corn » Sat Mar 30, 2019 10:30 pm
Apologies to Julius for mispronouncing and spelling his name.
In fact I have a passion for steam driven vehicles and machinery, and NO I am not living in the past, these engines have a character and strength of their own.
